Model TZ45 Z-Wave Thermostat Connection
Help - I can't get my new TZ45 Z-Wave Thermostat to connect to my isy99
Here are the instructions from the thermostat userguide.....
Z-Wave controllers from various manufacturers may support the Z-Wave Thermostat General V2 Device class used by the RCS Z-WAVE Thermostat. The following procedure will allow the thermostat to be added to a Z-Wave network.
General Programming Procedure (for controllers supporting the thermostat device class):
1. Set your primary controller to Include mode, to add the thermostat as a node on your network
(see your controller’s user manual for detailed instructions).
2. In the Thermostat’s Main Menu, scroll down to the ZWave Install item. Select the item.
3. Press the YES button in the ZWave Install screen.
Your controller will indicate the thermostat was successfully added to its network (see your controller’s user manual for details).
Also you can check if the thermostat was successfully added to the network by checking the ZHID (Home ID) and ZNID (Node ID) located in the Thermostat Info screen.
My thermostat info page reports My ZHID = d0.3e.ba.8f & my ZNID = 000
Is this thermostat compatible?
Thanks for your speedy reply...,
So, are there any thermostats that are compatible with isy?
D
i have the isy99 -but would consider upgrading ... are there other reasons to consider the 994iZ
