Not getting a text notofication
I was getting a text from a program but then deleted the text part of the program. So I'm pretty sure I have the text set up correctly in the configurations tab. With that said the following program is not sending me a text and was wondering if anyone knew what I was doing wrong...
       Time is Sunset  - 30 minutes
   And Status  'Kristen's Garage - Sensor' is Off
       Send Notification to 'My text' content 'Kristen's Garage Door'
       Wait  5 minutes
       Set 'Kristen's Garage - Relay' On
I tested the program tonight by leaving the garage door open and this program did close it but it didn't send me a text and I'm not sure if it waited 5 minutes. Anyone know what I'm doing wrong?
I just realized I posted the question in the wrong forum. Can someone move it to the Q and A forum? Thanks!
jmed999-
Right click the program and select "Run Then". Lets see if you get the text then. If not, we need to look at the customized message that your sending. Its possible you haven't specified a subject and/or body in which case the message may be getting rejected by the SMTP server.
-Xathros
