ISY-99i and a fanlinc - issue
So I've got a fanlinc that I recently installed and I think there is an issue. I'm controlling the fan speeds through a 6 button keypad. The keypad seems to be setup correctly. I am using a ISY-99i to control everything. Each button is set up to control the speeds via a scene. The issue is I think the fanlinc isn't switching from low to med to high speeds. It all seems to be high. Any suggestions? Thanks
A separate issue is that my fan has no manual direction switch. I can only switch it using their remote and their IR receiver. Since Fanlinc doesn't have the direction control built in, has anyone figured out a way to get around this?
Each ISY Scene that has a KeypadLinc Secondary button as Controller and the FanLinc Motor as a Responder will have a different Responder On Level. Below the ISY Scene name is the name of the Controller Secondary KeypadLinc button. Click on the KPL button name and set the Responder On Level (for the FanLinc Motor) to the desired speed. This has to be done for each of the 3 or 4 Scenes being used for FanLinc Motor speed.
All of the responder levels were set correctly already.
Run Diagnostics | Show Device Links Table against the FanLinc Light node and post the results including the Insteon address of a KeypadLinc that does not set the speed correctly. That will show whether the links have been set correctly.
Here is the address for the
fanlinc motor:14 CA B 2
fanlinc light:11 E4 24 1
keypad :11 E4 24 3
Not sure if I ran the diagnostics correct but here is the fan light:
<?xml version="1.0"?>
-Device Links Table : Nursery Fan Light / 14 CA B 1--40881620183436616719617 -40801620183436616719618 -407216224183436616719618 -40641623117251616719618 -405616225183436612525314 -40481624117251616719618 -40401622618343664136706 -40321625117251616719618 -40241622718343667938 -401616228183436616719617 -40081621117251616719617 -40000000
Mon 09/03/2012 12:56:17 PM : [All ] Writing 0 bytes to devices
Mon 09/03/2012 12:59:26 PM : [All ] Writing 0 bytes to devices
Mon 09/03/2012 01:05:53 PM : [All ] Writing 0 bytes to devices
Mon 09/03/2012 01:18:29 PM : [All ] Writing 0 bytes to devices
Mon 09/03/2012 01:19:57 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2
Mon 09/03/2012 01:19:57 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 06 (00)
Mon 09/03/2012 01:19:58 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:19:58 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:19:58 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F FF 00 A2 00 1B FD 7E FF 1F 01 6B
Mon 09/03/2012 01:19:58 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:19:58 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA
Mon 09/03/2012 01:19:58 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F F7 01 00 00 00 00 00 00 00 00 CA 06 (00)
Mon 09/03/2012 01:19:59 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:19:59 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:19:59 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F F7 00 A2 00 1B FD 7E FF 1F 02 72
Mon 09/03/2012 01:19:59 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:19:59 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2
Mon 09/03/2012 01:19:59 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F EF 01 00 00 00 00 00 00 00 00 D2 06 (00)
Mon 09/03/2012 01:20:00 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:00 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:00 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F EF 00 A2 18 1B FD 7E FF 1F 02 62
Mon 09/03/2012 01:20:00 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:00 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA
Mon 09/03/2012 01:20:00 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA 06 (00)
Mon 09/03/2012 01:20:01 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:01 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:01 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F E7 00 A2 03 11 E4 24 FF 1F 02 FC
Mon 09/03/2012 01:20:01 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:01 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F DF 01 00 00 00 00 00 00 00 00 E2
Mon 09/03/2012 01:20:01 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F DF 01 00 00 00 00 00 00 00 00 E2 06 (00)
Mon 09/03/2012 01:20:02 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:02 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:02 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F DF 00 A2 19 1B FD 7E BF 1F 02 B1
Mon 09/03/2012 01:20:02 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:02 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F D7 01 00 00 00 00 00 00 00 00 EA
Mon 09/03/2012 01:20:02 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F D7 01 00 00 00 00 00 00 00 00 EA 06 (00)
Mon 09/03/2012 01:20:03 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:03 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:03 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F D7 00 A2 04 11 E4 24 FF 1F 02 0B
Mon 09/03/2012 01:20:03 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:03 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F CF 01 00 00 00 00 00 00 00 00 F2
Mon 09/03/2012 01:20:03 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F CF 01 00 00 00 00 00 00 00 00 F2 06 (00)
Mon 09/03/2012 01:20:04 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:04 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:04 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F CF 00 A2 1A 1B FD 7E 3F 1F 02 40
Mon 09/03/2012 01:20:04 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:04 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 FA
Mon 09/03/2012 01:20:04 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F C7 01 00 00 00 00 00 00 00 00 FA 06 (00)
Mon 09/03/2012 01:20:05 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:05 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:05 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F C7 00 A2 05 11 E4 24 FF 1F 02 1A
Mon 09/03/2012 01:20:05 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:05 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F BF 01 00 00 00 00 00 00 00 00 02
Mon 09/03/2012 01:20:05 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F BF 01 00 00 00 00 00 00 00 00 02 06 (00)
Mon 09/03/2012 01:20:06 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:06 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:06 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F BF 00 A2 1B 1B FD 7E 00 1F 02 8E
Mon 09/03/2012 01:20:06 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:06 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A
Mon 09/03/2012 01:20:06 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F B7 01 00 00 00 00 00 00 00 00 0A 06 (00)
Mon 09/03/2012 01:20:07 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:07 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:07 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F B7 00 A2 1C 1B FD 7E FF 1F 01 97
Mon 09/03/2012 01:20:07 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:07 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 12
Mon 09/03/2012 01:20:07 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F AF 01 00 00 00 00 00 00 00 00 12 06 (00)
Mon 09/03/2012 01:20:08 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:08 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:09 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F AF 00 A2 01 11 E4 24 FF 1F 01 37
Mon 09/03/2012 01:20:09 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:09 PM : [iNST-TX-I2CS] 02 62 14 CA 0B 1F 2F 00 00 00 0F A7 01 00 00 00 00 00 00 00 00 1A
Mon 09/03/2012 01:20:09 PM : [iNST-ACK ] 02 62 14.CA.0B 1F 2F 00 00 00 0F A7 01 00 00 00 00 00 00 00 00 1A 06 (00)
Mon 09/03/2012 01:20:09 PM : [iNST-SRX ] 02 50 14.CA.0B 1B.FD.7E 2B 2F 00 (00)
Mon 09/03/2012 01:20:09 PM : [standard-Direct Ack][14.CA.0B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Mon 09/03/2012 01:20:10 PM : [iNST-ERX ] 02 51 14 CA 0B 1B FD 7E 11 2F 00 00 01 0F A7 00 00 00 00 00 00 00 00 00 1A
Mon 09/03/2012 01:20:10 PM : [Extended-Direct][14.CA.0B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Mon 09/03/2012 01:20:10 PM : [All ] Writing 0 bytes to devices
The ISY Scene Responder On Levels for the FanLinc Motor have been set correctly.
The KeypadLinc as Controller Responder On Levels for the FanLinc Motor are NOT set correctly.
For each ISY Scene, below the ISY Scene name is the node Name of the KeypadLinc button as Controller. Click the KeypadLinc node Name below the ISY Scene name and set the appropriate Responder On Level for the FanLinc Motor. Currently the FanLinc Motor On Level is set for High for all three KeypadLinc buttons.
0FF8 : A2 00 1B.FD.7E FF 1F 01
0FF0 : A2 00 1B.FD.7E FF 1F 02
0FE8 : A2 18 1B.FD.7E FF 1F 02 ISY Scene – Motor High
0FE0 : A2 03 11.E4.24 FF 1F 02 KeypadLinc button A (6 button) – Motor High
0FD8 : A2 19 1B.FD.7E BF 1F 02 ISY Scene – Motor Med
0FD0 : A2 04 11.E4.24 FF 1F 02 KeypadLinc button B ( 6 button) – Motor High
0FC8 : A2 1A 1B.FD.7E 3F 1F 02 ISY Scene – Motor Low
0FC0 : A2 05 11.E4.24 FF 1F 02 KeypadLinc button C ( 6 button) – Motor High
0FB8 : A2 1B 1B.FD.7E 00 1F 02 ISY Scene – Motor Off
0FB0 : A2 1C 1B.FD.7E FF 1F 01
0FA8 : A2 01 11.E4.24 FF 1F 01
0FA0 : 00 00 00.00.00 00 00 00
Device Record Count : 12
Does anyone have any suggestions about lack of a physical direction switch
Theoretically (I have not attempted), I believe one could come up with a solution based on an ISY program. It may require variables to define fan speeds, but I see this encompassing multiple programs with logic something like:
if
status fan is off
and control switch set on
then
set fan to low
if
status fan is low
and control switch is set to on
then
set fan to medium
etc....
oberkc
The OP is asking how to reverse the rotation of the Fan Motor (Does anyone have any suggestions about lack of a physical direction switch).
The OP is asking how to reverse the rotation of the Fan Motor.
Well, then. Clearly I misunderstood. Ignore my suggestions.
Thanks for pointing this out.
LeeG is correct I am trying to reverse the direction of the fan even using a fanlinc despite the fan itself not having a physical reverse button/switch. I called the fan manu as well and they suggested turning the fan on high and then flipping the breaker. The said to try this a few times and eventually the fan would change directions. Seemed weird but I tried it 5 times and the results did not change the fan direction. I stopped trying because it I was getting tired of walking up and down the 3 flights of stairs.....
Anybody else have an idea?
No direct experience with this. I saw a suggestion to use a sacrificed RF remote control, where an I/O Linc Relay would be connected in parallel with the RF remote button that would normally be used to reverse the Fan direction. I use the same principle with my garage doors as they are RF operated only. No normal wired button. Has worked well for the garage doors. The RF remote is already mounted on the wall so it was easy to connect a pair of wires to the door controller button that opens/closes the garage door. No idea if the same concept would work for the Fan Motor. Do not remember seeing any post back whether the suggestion worked for the other user.
