Can you set Variables or Notifications via REST?
I was wondering if it was possible to set variables or the content of notifications remotely. Say for example, I wanted to send an alert to an Elk keypad and I have the Network Module ping a page for data. Is there a way to get that data into the system via REST or the Network module? Been scouring the forums and haven't seen anything about it.
Steve
Hi Steve-
As long as the data is Integer, you can /REST it to a var then use that var in a custom notification. No String type vars yet. If there are a limited number of possible string values, you could create separate customized notifications for each then pass an integer index to select a notification.
-Xathros
Hi Steve-
-Xathros
Thanks Xathros. Do you know the path structure for variables? I could not find it in the wiki.
Steve
Xathros,
Found it in another post by Chris Jahn
Yes, the variables are available through REST:
/rest/vars/set/// -- set the value of a variable
/rest/vars/get// -- get the value of a variable
1 - Integer, 2 - State
ID of the variable
e.g. Set integer variable 3 to 28
/rest/vars/set/1/3/28
viewtopic.php?t=5987
Steve
