Is there a countdown timer function in the isy ?
I want to be able to start a timer and read it's status in a small program.
satwar-
No. But this functionality can be achieved with a few small programs depending on the resolution you are looking for. Anything more granular than 1 second is unlikely. Minutes are easy.
Here is an example:
Define a state var for your timer value
s.Timer = 10
Program: Timer Countdown
If s.Timer > 0
  wait 1 minute
  s.Timer =- 1
The value of s.Timer will decrement once per minute.
Program: Timer Expired
If Status LampLincDimmer is On
  And s.Timer =0
  Set LamplincDimmer Off
-Xathros
satwar-
I should point out that the Wait function is really a countdown timer but unless used in conjunction with a counter variable as in the example above, there is no way to check on it's progress. I could have achieved the same result with:
If Status LamplincDimmer is not Off
  Wait 10 minutes
  Set LampLincDimmer Off
Only difference here is that we can't tell how much of the timer remains during the 10 minute delay.
-Xathros
Your first example was perfect for my project. I run a macro in mControl which writes a starting value (60 minutes) for S.Timer in ISY. ISY executes the countdown function. ISY uses countdown timer value to make further decisions.
Worked perfectly.
