KSaccullo Posted October 9, 2012 Posted October 9, 2012 Had another shot showing the weather module had disappeared. I clicked on "Then" came back to if and the module was not their Quote
sanders2222 Posted October 9, 2012 Posted October 9, 2012 KSaccullo said: Had another shot showing the weather module had disappeared.These attachments are the 'Programs' tab. What does the screen look like under the 'Configuration' tab? Quote
Michel Kohanim Posted October 9, 2012 Author Posted October 9, 2012 Hello KSaccullo, Thanks so very much for taking the time and not only emailing the screenshots to us but also posting them. Indeed appreciated. Thanks to your input, we found the bug and it's fixed in 3.3.4. With kind regards, Michel Quote
AlX Posted October 9, 2012 Posted October 9, 2012 andyf0 said: Michel Kohanim said: Hello AIX, You should have two nodes for humidity. From a poster in the 2441ZTH thread. He shows an image of the nodes for the 2441ZTH and there are no humidity nodes. While I think AIX was talking about the 2441TH the manual for the 2441ZTH shows Humidity High and Low settings. While yes, I was talking about 2441TH, I, indeed, have exactly same picture. Although I can see Status triggers for humidity if I use thermostat in if clause in programs. Quote
Michel Kohanim Posted October 9, 2012 Author Posted October 9, 2012 Hello AIX, I am so very sorry ... I meant: You should have NO nodes for humidity (not two). With kind regards, Michel Quote
andyf0 Posted October 9, 2012 Posted October 9, 2012 Michel Kohanim said: Hello AIX, I am so very sorry ... I meant: You should have NO nodes for humidity (not two). With kind regards, Michel Personally I don't use humidity but I could see where high and low humdity nodes could be useful. If you have a humidifier or de-humidifier that is controlled independantly of the HVAC you might want to turn on or off these devices based on a high or low humidity value as described in the manual. I suppose you can always add these devices to the thermostat locally. Quote
KSaccullo Posted October 10, 2012 Posted October 10, 2012 sanders2222 said: These attachments are the 'Programs' tab. What does the screen look like under the 'Configuration' tab? Looks ok under configuration tab. But as Michel noted he found a bug and plans on squashing it. Quote
RLIKWARTZ Posted October 10, 2012 Posted October 10, 2012 I'm still continuing to see the problem about the Socket Open Failed java.net.socket timeout. It appears to happen randomly during normal operation and the RX and PWR are on constantly and all the others are off. Then the ISY is hung and I have to cyce the power. If I revert back to 3.3.2 everything is fine. During startup when the ISY is getting statuses it will sometime hang after cycling the power and I'll see the Socket error. I've tried reseting the ISY and the modem still nothing. Going back to 3.3.2 seems to do the trick. Quote
Michel Kohanim Posted October 10, 2012 Author Posted October 10, 2012 Hi RLIKWARTZ, Thanks so very much. Questions: 1. You never have this problem with 3.3.2? 2. Do you have DirecTV? With kind regards, Michel Quote
RLIKWARTZ Posted October 10, 2012 Posted October 10, 2012 I've had 3.3.2 running since yesterday evening and no problem. 3.3.3 would have hung by now. I don't have direct tv. Quote
andyf0 Posted October 10, 2012 Posted October 10, 2012 Here's a couple of problems I found. 1. Added 2441ZTH fine. Tried to drag and drop it into my THERMOSTATS folder and it wouldn't go. I could drop it into some folders but not others. Right Click and select Add to Folder works fine. 2. I can't drag and drop the Main node of any of my thermostats into a new scene. Right click and Add to scene works for the Venstars but I get an error something like This scene already contains this device when I try to add the 2441ZTH to a new scene. Quote
Michel Kohanim Posted October 11, 2012 Author Posted October 11, 2012 Hi Andy, andyf0 said: Here's a couple of problems I found. 1. Added 2441ZTH fine. Tried to drag and drop it into my THERMOSTATS folder and it wouldn't go. I could drop it into some folders but not others. Right Click and select Add to Folder works fine. Can you use Add to Folder on "any" folder? Even to those that you could not drag/drop to? andyf0 said: 2. I can't drag and drop the Main node of any of my thermostats into a new scene. Right click and Add to scene works for the Venstars but I get an error something like This scene already contains this device when I try to add the 2441ZTH to a new scene. You should NOT be able to do that. That configuration is not supported Quote
andyf0 Posted October 11, 2012 Posted October 11, 2012 Michel Kohanim said: Hi Andy, andyf0 said: Here's a couple of problems I found. 1. Added 2441ZTH fine. Tried to drag and drop it into my THERMOSTATS folder and it wouldn't go. I could drop it into some folders but not others. Right Click and select Add to Folder works fine. Can you use Add to Folder on "any" folder? Even to those that you could not drag/drop to? andyf0 said: 2. I can't drag and drop the Main node of any of my thermostats into a new scene. Right click and Add to scene works for the Venstars but I get an error something like This scene already contains this device when I try to add the 2441ZTH to a new scene. You should NOT be able to do that. That configuration is not supported. 1. Yes, I can use Add to Folder on any folder, even the ones I couldn't drag it to. 2. I currently have scenes with my Venstar thermostats (2) where I dropped the thermostat MAIN node into the scene. I use the scene to set mode and setpoints just by sending ON to the scene. They still work. I just can't create a new scene and drop the thermostats MAIN node into it anymore. It certainly did work at some point in time during 3.2 beta Quote
Michel Kohanim Posted October 11, 2012 Author Posted October 11, 2012 Hi Andy, We will look into folders. Are you referring to 2441 or 2491 (Venstar)? I was referring to 2441. With 2491, the main node can be a controller in ONE scene only. With 2441, the main node cannot be part of any scenes. With kind regards, Michel Quote
andyf0 Posted October 11, 2012 Posted October 11, 2012 Michel Kohanim said: Hi Andy, We will look into folders. Are you referring to 2441 or 2491 (Venstar)? I was referring to 2441. With 2491, the main node can be a controller in ONE scene only. With 2441, the main node cannot be part of any scenes. With kind regards, Michel Well that's interesting. I have 2 2491 thermostats. One of them is wired to the HVAC, the other is supplied power in another room only. For the one that is wired to the HVAC I have three scenes that set: 1. Cool-82 Heat-74 Mode-Auto (Settings when home) 2. Cool-84 Heat-65 Mode-Auto (Settings when away) 3. Cool-60 Heat-90 Mode-Off (When the other Venstar is controlling temperature via Insteon messages through ISY) For the one in the bedroom that only has power I have 2 scenes that set: 1. Cool-82 Heat-72 Mode-Auto (Settings while sleeping) 2. Cool-82 Heat-74 Mode-Off (During the day when not in use) I actually found this capability to be very useful. Ah! Wait, I see my lack of important information. In my scenes the MAIN node of the thermostat is a responder not a controller. Can the 2441 be a responder in a scene? If so, then I still can't add it to a scene as a responder. Quote
RLIKWARTZ Posted October 11, 2012 Posted October 11, 2012 I think the hanging problem is related to the console being up. When it's down everything is fine. So I checked my firewall and everything is fine. I then went into my Cisco EA4500 router and made the ISY high priority and so far no hangs. I'll let you know if it changes. Quote
andyf0 Posted October 11, 2012 Posted October 11, 2012 Michel Kohanim said: Hi Andy, We will look into folders. Are you referring to 2441 or 2491 (Venstar)? I was referring to 2441. With 2491, the main node can be a controller in ONE scene only. With 2441, the main node cannot be part of any scenes. With kind regards, Michel I hate to say it but the folder thing is a non-issue. I was using the floating box to point to the folder to move to instead of the pointer. If I use the pointer it works fine. Sorry! My error also caused the thermostat drag and drop into a scene for the 2491s. The 2441 still didn't work but I'm returning it so it doesn't bother me any more. Quote
Michel Kohanim Posted October 11, 2012 Author Posted October 11, 2012 Hi Andy, You should be able to put 2491 as responder in scenes. Does it not work? Hi RLIKWARTZ, Can you tell me whether or not your E4500 has the latest firmware? I know for a fact that older firmware have a problem negotiating down to 100 Mbps. Also, what activities are you doing when the Admin Console is up? With kind regards, Michel Quote
andyf0 Posted October 11, 2012 Posted October 11, 2012 I can add the 2491 into scenes, but not the 2441ZTH as a responder. Quote
RLIKWARTZ Posted October 11, 2012 Posted October 11, 2012 I'll look into the firmware. I'm not doing any activity in admin console. I just have it up and displaying the main device screen in most cases. Quote
RLIKWARTZ Posted October 11, 2012 Posted October 11, 2012 I checked and I have the latest and greatest firmware loaded into the EA4500. I'm really puzzled becaue if I go back to 3.3.2 it's totally stable. If I load 3.3.3 and start using it at some point it hanges wih that socket open failed java.nt.socket timeout exception. No other changes. Quote
Michel Kohanim Posted October 12, 2012 Author Posted October 12, 2012 Hi RLIKWARTZ, When you click on File menu, do you see Enable Internet Access or Disable Internet Access? With kind regards, Michel Quote
Michel Kohanim Posted October 12, 2012 Author Posted October 12, 2012 Hi RLIKWARTZ, Thank you. Can you please: 1. Send me your error log (support@universal-devices.com) 2. Let me know if your ISY is setup with DHCP, DHCP with Reservation, OR static? With kind regards, Michel Quote
