AT&T to end email-to-text ×
Using variables to Arm ELK Troubles
sanders2222
I put together some routines to allow me to push a KPL button, hop in the car and drive off. The routines would arm the ELK and set the house up in the 'Away & armed mode'.
The problem I was having was controlling program execution and folders with a variable (iAway). I found the ELK would only arm half the time, sometimes it would arm then disarm right away, and sometimes would not arm at all. The control was:
            Control 'Utility Room / Util KPL G Away 10.9D.73.G' is switched On
        And Control 'Utility Room / Util KPL G Away 10.9D.73.G' is not switched Off
   And $iAway is 0
       Set Scene 'Lights Upstairs' Off
       Set Scene 'Lights Down' Off
       Run Program 'IsArmed' (Then Path)
The arming program was this:
       Status  'Utility Room / Util KPL H Vacation 10.9D.73.' is Off
       Set Elk Area 'House Main' Arm Away
       Wait  10 seconds
       Run Program 'Away Set' (Then Path)
       Set Elk Area 'House Main' Arm Vacation
       Wait  10 seconds
I was pulling my hair and really frustrated after spending 2 half days trying to get the program to work. Finally, I decided to utilize the features in the ELK module and not use variables at all. I replaced the '$iAway is 0' with:
    And Elk Area 'House Main' 'Arm Up State' is Ready To Arm
Now the same code executes correctly 100% of the time. And removing the variable simplified the lines of code and how folders were controlled as well. This is not the first time I have experienced questionable results using variables. I would be surprised if others aren't experiencing issues using variables as well.
