Program Associative Property...Like Algebra?
I'm having problems with my program below. It isn't only working after sunset and before sunrise. It works 24 hours per day....what do I have wrong? Do ISY programs follow the associative property like in algebra (the order of the and & or doesn't matter)?
       Elk Zone 'Front Door' is Violated
    Or Elk Zone 'Garage Entry Dr' is Violated
   And From    Sunset
       To      Sunrise (next day)
       Set 'Insteon Bulb' Fast On
       Wait  2 minutes
       Set 'Insteon Bulb' Fast Off
To achieve the effect, ANDing the time range with either of the other conditions, add the parens as follows
   And From    Sunset
       Wait  2 minutes
There is an order of precedence which is described in the Wiki
EDIT: The original Program without parens is the same as coding
    Or
     And From    Sunset
       Wait  2 minutes
Ok...I now have...
       From    Sunset
   And (
       Wait  2 minutes
It seems to be working correctly except it isn't turning off after 2 minutes of turning on. I want it to come on when the doors open the turn off 2 minutes later regardless of the doors being open or closed. Any ideas? Thanks!
The Elk zone is not staying violated. During the Wait the zone changes state causing the Program If section to be reevaluated to False driving the Else clause so statement(s) after the Wait are not executed.
The most reliable method would be to make a SECOND program with no if clause.
The wait statement and the turn off would be the THEN clause of the second program.
Have the THEN clause of the first program execute the THEN clause of the second program.
Sent from my iPad using Tapatalk HD
Actually both are equally reliable with subtle differences.
Using the else clause restarts the timer when the door closes. Mostly an academic issue since exterior doors are usually not left open for long. But if you are carting a few things through the door it gives you the full 2 minutes of light once you are done and close the door.
Using the else clause restarts the timer at sunrise if you happened to open/close the door within 2 minutes of sunrise. This will rarely come into play and shouldn't make any difference to anyone anyway.
Using one program is a touch less confusing and saves space. But again not much difference.
I'm now using the following program...
       From    Sunset
   And (
       Wait  2 minutes
       Wait  2 minutes
The light still comes on before sunset. Today it came on at 4PM when I opened the door. It then turned off 2 minutes later.
What am I doing wrong?
The Else clause should not turn the light On.
Anytime the Elk zones are violated outside the desired time range the else clause runs turning the light On.
