Help Newbie with programming
Hi there I have an ISY-99i and so far have just programmed a few timer programs (ie Lights on at sundown).
I wanted to control my counter lights with very specific conditions:
If 20 minutes before sunset comes before 6:00pm then turn counter lights on at 5:00pm weekdays
But I am having difficulty visioning the program. I thought of this:
Create a Variable EarlySundown=0, then these programs
       On Mon, Tue, Wed, Thu, Fri
       From    Sunset  - 20 minutes
       To       6:00:00PM (same day)
       $EarlySundown  = 1
       $EarlySundown  = 0
       Time is  5:00:00PM
   And $EarlySundown is 1
       Set 'Counter Lights' On
But to me the first program would only run after the second if Sundown-20min came between 5pm and 6pm which fails my conditions, am I right?
If so how would one write a program for this?
Thanks very much for any help!
Hi Iceman68,
I believe you can accomplish what you want with the following one program:
From Sunset - 1 hour and 20 minutes
To 5:00:00PM (same day)
And Time is 5:00:00PM
Good luck!
