Get rid of extra ON commands.....
I have a 2842-2 motion sensor that sends extra on commands when the light
is already on. So something is awry in my logic?
Sensor is set to 1 minute delay.
ISY adds 4 minutes, and that part works fine.
It's just the extra on commands I'd like to get rid of. How do I do that?
Control 'MS2_UpBed-Sensor' is switched On
And Status 'MS2_UpBed-Sensor' is not On
Set 'Upstairs / Upstairs Bedroom / UpBed Lites' On
Send Notification to 'Somebody' content 'UpBed-LitesOn'
Wait 4 minutes
Set 'Upstairs / Upstairs Bedroom / UpBed Lites' Off
Send Notification to 'Somebody' content 'UpBed-LitesOff'
Is Sensing Mode option checked or unchecked. If Sensing Mode is On the Motion Sensor sends On commands for every motion detected.
If not Sensing Mode the Motion Sensor sends On commands only after timeout interval has expired.
How long between Motion On messages?
I'm using 3.3.3beta under osx 10.8.2
The email timing is as expected. The next On command comes after the 1 minute Motion Sensor Timeout interval. Either the Motion Sensor Timeout value has to be increased or the Program logic adjusted to not send an email while in the 4 minute Wait.
Doing the programs as below will prevent you from getting more than 1 notification per light turning on. The second program will trigger only when the lights status changes to on. So if it is already on, the program won't trigger even if it gets another on command. It has to change, and it has to change to on. Of course you will get an email every time the light turns on no matter how it got that way. Also, you will get an email if someone manually dims it, then turns it back to full on. But I am guessing that this is not really how you expect to use the light.?
Wait 4 minutes
Status 'Upstairs / Upstairs Bedroom / UpBed Lites' is on
empty
Thanks Guys. I'll look at the tips provided and work on my programming.
Yeah, the email timings looked according to plan.
Apostalaski - No...I don't mind the extra emails, I can always delete the lines.
What I'm actually doing is using my bedroom light and emails as a test
ground while I learn isy programming and work with behavior of insteon products.
In actual practice it seems like most of these programming concepts will apply
to just about any real world scenario. There is a great write up over in the
wiki about motion sensing bathroom lights so I'll back and re-read that too.
Thx.
