Cannot communicate with motion sensor...
nowandthen
I get this error message every time I log on to the ISY console. It interrupts what I am doing (like replace with) which is very annoying. Can you make it not interrupt the procedure in process?
I changed the battery a few months ago, but continue to get this message. The motion sensor is communicating just fine as every time I enter the dining room the lights come on, then go off after the time out. So there isn't a communication error, yet the ISY continues to think there is.
Any ideas as to what the problem is?
i have other motion sensors with no issues.
Motion sensor is the 2420.
Hi nowandthen,
There's something wrong either with the motion sensor or the way it's registered in ISY. It's basically sending a NACK to ISY and thus the error you see.
You might want to remove it and then add it back.
Thanks Michel!
I removed the motion sensor and added it back, with some frustration.Iit seems to be working OK.Hopefully it will not complain anymore. :)
Thanks for the help!
Todd
I've had this problem - much more frequently in the past than now. As Michel says, it just indicates that the MS says it had a comm problem.
But with which particular device(s) is hard to know, unless it is only linked to the ISY. That's one of several reason I almost always use programs rather than scenes for motion sensors. (Updating scenes is another.)
In my case - when it was happening a lot - it was a symptom of a bigger Insteon comm. issue with certain devices and branch circuits. That problem got fixed with a newer rev dual-mode PLM, and then placing that PLM behind a filterlinc so it is forced to use only RF to communicate out. Reliability went back to nearly 100% and I rarely see these MS pop-ups now.
A few things I've found helpful in individual cases when I keep seeing this message for a particular MS:
1) Replace its battery (duh).
2) Do a "restore device" on the MS and also all devices that are linked in scenes to it.
3) If you can, move the MS to a location where the RF has a better shot at any nearby AP or dual-mode device.
Now I did have this as a chronic problem in my kitchen area for a while, where there were a pair of older MSen to cover it. But I simply couldn't figure out what the problem was. Even a factory reset on the MSen and all of the above didn't make any difference.
I finally replaced both with new ones (rev 2 or whatever they are) and there are no problems now. Of course I can't believe both devices failed, but who knows? It was either spend the $70 or the rest of my life trying to figure it out. I opted for the former.
I don't link anything to my motion sensors. I use programs as you suggest.
Like you there are times I just want to buy my way out of a problem. :)
It's been several days and it's working fine since removing and adding back (knock on wood).
      377k
