Phantom keypad signals
A keypad that was installed about 12 mo ago and working without a problem has developed phantom signals. For example when I turn on a table lamp on button C a ceiling light on bottom A will briefly turn on/off. I have performed a restore which will only correct the problem temporarily.
Any suggestions?
ISY 99. V 3.3.4.
Hi flsenior,
The first thing I recommend to check your Program Summary tab and see whether or not any programs get activated. I suspect you have programs that are being activated/deactivated.
Secondly, you would want to do a restore ON THE DEVICE that's turning on/off randomly.
And, finally, if KPL version is 2A or 2D, then it's the KPL itself and it must be replaced.
