994iz / ir pro + Honeywell Z wave T-stat TH8320ZW1007 ??
I'd like to know if anybody knows if these 2 will communicate properly?
I've got a 99i that I'd like to upgrade to a 994iZ if so. I've got a house full of the non-Z wave Honeywell thermostats and these would be a simple replacement with no re-learning required by the family.
I have a number of Insteon programs in my 99i and hopefully I can now include control of the thermostats based on various conditions ?? I assume that programming mode now includes a "Z Wave" option in addition to "Insteon" for setting up actions or checking status ?
Thanks for any help!
Is there any disadvantage (aside from extra cost) to getting the 994iZ ? Will it support the Z Wave dongle also and can the Zigbee radio be "disabled" or just not used?
What is the ETA for the Z wave dongle solution ?
Or for home use with various Z wave thermostats (hopefully including the Honeywell) MUST I get the non-Z version of the 994i ?
Thanks for your help!
So to be clear, the 994i-Z is a 994i with a zigbee radio installed, (which I presume works with something out there now)
And when the Z-wave dongle is ready, I can remove the zigbee radio card from the 994i-Z and install the new Z-Wave "dongle" in its place? That simple ?
Thanks for your time, as I just ordered the 994iZ model and need to know if I should cancel - I don't mind the extra expense if that would be the only issue.
