Resolved: Network Resource Prowl error
A recent upgrade to an ISY994i/IR PRO (thanks UDI!) has been working well except for my Prowl network resources. Several other network resources are working fine; only my Prowl resources seem to have problems.
After the upgrade to the 994 running 3.3.5, no prowl notifications are being received. A Test on the prowl network resource returns a popup message: "Error: Request Failed , along with 'Network Response: N/A" and the Event Viewer shows: "Net-Resource: Failed connecting to api.prowlapp.com"
The prowl API key tests OK from the prowl site and the prowl resources configurations are the same as in the old ISY99. A test configuration example is shown below, with the Body content:
apikey=&application=ISY&event=TEST ONLY&description=Test Notification\n
The resources in the new ISY994 were copied from the ISY99 using the Restore ISY operation from the 99 backup file. All other resources, except Prowl, seem to be working properly.
Suggestions on what to look at to identify the problem will be greatly appreciated. Thanks.
edit: after careful examination of the Dashboard Network settings, my tired old eyes noticed a faint, grey check in the HTTPS Verify checkbox. After UNchecking that box and rebooting the ISY994, all is well now - Prowl is working fine once again.
  • 5 months later...
I think I have the same trouble with my eyes, where is located this box ? could you put the print screen ?
Regards
Plau,
Launch the ISY Dashboard and login, then under settings (the wrench icon), you should see the Verify checkbox under the section "HTTPS Server Settings."
