Can't Access MyISY - Plugin Blocked
Safari updated the Java plugin and now it says "Plugin Blocked" when I attempt to launch My ISY. Is there a workaround? Or, if necessary, is there a way to revert back to the last Java plugin?
My problem is that Apple has already disabled the Java plugin and the fix states to disable the plugin after I've downloaded the Admin Console and the ISY Dashboard.
What do I do now?
Thanks. Got it to work with Admin Console now. But ISY Dashboard was no longer available for download. Did they take it off the site?
it was a bad link, look at the link when you copy it and you will see it says 99, instead of 99i like the admin link does. fix it and you can get the dashboard.
