March 20, 200818 yr I've been trying to use the html pages from my iphone browser but when executing the form submissions i get a "lost network connection" (NSURLErrorDomain:-1005) error. A brief web search for this error seems to point at a server side problem with sessions or other issues. Please let me know if you have any ideas on how to resolve this. Thanks.
March 21, 200818 yr Hello az1324, Currently, our auto configuration (UPnP) opens only port 443 (https). If you wish, you will have to open the HTTP port (80) to access it via HTTP. We strongly recommend against this since your credentials will be sent in the clear. With kind regards, Michel UPDATE: it works through https but not http.
March 21, 200818 yr Author Well right now it does work over http from firefox on my computer, just not on mobile safari. Both are connected over LAN.
March 23, 200818 yr az1324, That's really amazing ... you do not get anything on your mobile safari? Nothing at all? With kind regards, Michel Well right now it does work over http from firefox on my computer, just not on mobile safari. Both are connected over LAN.
April 8, 200817 yr My https: also works fine, but http: doesn't. I would like to have port 80 open as I am trying to access my lighting from within my LAN and not externally. I am using the WiFi built into my iPhone. Regards Geoff
April 9, 200817 yr CompKing, You do NOT need to open port 80 on your router to access ISY locally on the LAN. All you need is to figure out what's your ISY's local LAN IP address. So, please do not open the port 80 on your router. With kind regards, Michel My https: also works fine, but http: doesn't. I would like to have port 80 open as I am trying to access my lighting from within my LAN and not externally. I am using the WiFi built into my iPhone. Regards Geoff
April 12, 200817 yr My https: also works fine, but http: doesn't. I would like to have port 80 open as I am trying to access my lighting from within my LAN and not externally. I am using the WiFi built into my iPhone. Regards Geoff I observed the following on my iPhone: 1. When connected to the local LAN via wifi, I can navigate to the device page for any device using HTTP and get the device status, but the change status buttons ("On", Off", "Dim", etc.) do not work. The HTTP response times out. 2. HTTP interface also does not work via an Internet connection (with port 80 open on the firewall). But who wants to open their private network to insecure traffic anyway? 3. HTTPS interface works fine when iPhone is connected to the LAN via wifi. 4. HTTPS interface does not work over the Internet until a self signed SSL certificate is installed on the ISY. With the default certificate, iPhone gives the user an "invalid certificate" warning. Even if you click the Continue button to ignore the warning, iPhone will give a "network connection lost" error. If you install a valid self-signed certificate, the warning goes away and the interface works perfectly. Since the HTML UI is so lightweight anyway, I don't notice any performance difference between connecting over the LAN or Internet, so I just bookmarked the public address and access my ISY from there, whether I'm in my house or out. -Jim
April 13, 200817 yr Hello Jim, Please do be kind enough to let me know you still experience #1 below when you install 2.6.4 (due out by the end of next week). Thanks and with kind regards, Michel I observed the following on my iPhone: 1. When connected to the local LAN via wifi, I can navigate to the device page for any device using HTTP and get the device status, but the change status buttons ("On", Off", "Dim", etc.) do not work. The HTTP response times out. 2. HTTP interface also does not work via an Internet connection (with port 80 open on the firewall). But who wants to open their private network to insecure traffic anyway? 3. HTTPS interface works fine when iPhone is connected to the LAN via wifi. 4. HTTPS interface does not work over the Internet until a self signed SSL certificate is installed on the ISY. With the default certificate, iPhone gives the user an "invalid certificate" warning. Even if you click the Continue button to ignore the warning, iPhone will give a "network connection lost" error. If you install a valid self-signed certificate, the warning goes away and the interface works perfectly. Since the HTML UI is so lightweight anyway, I don't notice any performance difference between connecting over the LAN or Internet, so I just bookmarked the public address and access my ISY from there, whether I'm in my house or out. -Jim
April 24, 200817 yr Hello Jim, Please do be kind enough to let me know you still experience #1 below when you install 2.6.4 (due out by the end of next week). Thanks and with kind regards, Michel I observed the following on my iPhone: 1. When connected to the local LAN via wifi, I can navigate to the device page for any device using HTTP and get the device status, but the change status buttons ("On", Off", "Dim", etc.) do not work. The HTTP response times out. 2. HTTP interface also does not work via an Internet connection (with port 80 open on the firewall). But who wants to open their private network to insecure traffic anyway? 3. HTTPS interface works fine when iPhone is connected to the LAN via wifi. 4. HTTPS interface does not work over the Internet until a self signed SSL certificate is installed on the ISY. With the default certificate, iPhone gives the user an "invalid certificate" warning. Even if you click the Continue button to ignore the warning, iPhone will give a "network connection lost" error. If you install a valid self-signed certificate, the warning goes away and the interface works perfectly. Since the HTML UI is so lightweight anyway, I don't notice any performance difference between connecting over the LAN or Internet, so I just bookmarked the public address and access my ISY from there, whether I'm in my house or out. -Jim Retested iPhone with firmware 2.6.4. Confirming no more timeout issues. -Jim
April 24, 200817 yr Jim, Thank you so very much. With kind regards, Michel Retested iPhone with firmware 2.6.4. Confirming no more timeout issues. -Jim
