Different brightness levels for on and fast-on
propman07
Post the current Program issuing the Adjust Scene statements.
Need to know the ISY Scene name
and the name of each Controller
Confirm this is an ISY Scene with two additional Controllers
LeeG-
Here is the program:
       From     3:00:00PM
       To      Sunrise -  1 hour  (next day)
       In Scene 'Hardware / Family Room Light' Set 'Hardware / Family Room Light' 30% (On Level)
       In Scene 'Scenes / Family Room Lighting' Set 'Hardware / Family Room Light' 30% (On Level)
       In Scene 'Hardware / Family Room Light' Set 'Hardware / Family Room Light Slave' 30% (On Level)
       In Scene 'Scenes / Family Room Lighting' Set 'Hardware / Family Room Light Slave' 30% (On Level)
       In Scene 'Hardware / Family Room Light' Set 'Hardware / Family Room Light' 100% (On Level)
       In Scene 'Scenes / Family Room Lighting' Set 'Hardware / Family Room Light Slave' 100% (On Level)
       In Scene 'Hardware / Family Room Light Slave' Set 'Hardware / Family Room Light Slave' 100% (On Level)
       In Scene 'Scenes / Family Room Lighting' Set 'Hardware / Family Room Light' 100% (On Level)
The ISY Scene name is Family Room Lighting
Controller one is Family Room Light (connected to load, hot and neutral)
Controller two is Family Room Slave (connected to hot and neutral, load wire capped)
Hopefully, I've got all the info correct. Let me know if you need something else. Thanks for the help.
I may not understand the problem. The Responder values for when the ISY is turning the Scene On/Off are being set. Those statements are in Red
From 3:00:00PM
What is not being set is the Local On Level values in both switches. These are the values that affect what the switch does where the paddle is being pressed.
My last post was wrong. The Local On Levels are being set. What is not being set is what the Responder switch does when the paddle is pressed in the other switch. Sorry for the confusion. The Folder names, which are actually very good, got me moving in the wrong direction.
Perhaps if you identify the issue you are having. There are two more Adjust Scene statements needed but I want to be sure we are working on the same problem.
Here are the six adjust scene statements. It would be good to expand on the issue because the adjust scene statements may not be the issue
From 3:00:00PM
In Scene 'Hardware / Family Room Light Slave' Set 'Hardware / Family Room Light Slave' 30% (On Level)
In Scene 'Hardware / Family Room Light Slave' Set 'Hardware / Family Room Light' 30% (On Level)
In Scene 'Hardware / Family Room Light Slave' Set 'Hardware / Family Room Light' 100% (On Level)
Hi LeeG-
Thanks. I'm at work, so I will enable the program when I get home later today, run it, then post the results.
I created a folder for the switches (Hardware) in an attempt to keep things organized. This way, when I add a new device, I move it to the folder once I've added it to a scene, or written a program for it.
Thanks again for the help.
      38k
      379.1k
