Insteon Wireless Thermostat 2441ZTH and the ISY
Hi,
I recently converted my Thermostat over to an Insteon thermostat and got it all set up and working with an ISY-994i. Then, I added a wireless Thermostat 2441ZTH. I can't seem to figure out how to control the wired thermostat with the wireless via the ISY. Is it possible yet? How do I switch which controller is master via the ISY?
Also...is there any listing of what the node definitions are for either the 2441TH or ZTH? I am trying to set up a notification of status and would like to include temperature and humidity as the device is reading them.
Chris
Michel,
Thanks for your reply.
Do you know of an example program where the two are used in a scene? The only thing I can think of at the moment is to use the up/down 1deg function. I am thinking that an get tricky with all of the lag in the system.
Chris
