simonw Posted February 6, 2013 Share Posted February 6, 2013 Greetings, Trying to recreate the functionality of a simple Elk rule on the ISY and needing some help, please ... I had an Elk rule that would email me if a gate opened while my Elk was armed. The rule was something basic like "Whenever GATE is OPEN AND Elk Area 1 is Armed Away ...". Nice thing was that if the gate was already left open when the system armed, it __did not__ generate an email at the time of arming. It only triggered and sent the email if the gate was closed and then re-opened while armed. In the ISY, a simple program I thought would be equivalent like "If zone violated AND armed away ..." gives me instant emails when the system arms if the gate is already open. I prefer the Elk's approach to this situation, I only want to capture a "fresh" zone violation, so how can I mimic the Elk rule's behavior on the ISY? Thanks in advance, and cheers, Simon Link to comment Share on other sites More sharing options...
apostolakisl Posted February 6, 2013 Share Posted February 6, 2013 This is because ISY programs will trigger on every line of a program, Elk rules only trigger on the first line. So whenever zone violates and system armed away only triggers on a zone violation, then it checks if armed away. In ISY, you would need to use 2 programs to elliminate the arming as a trigger. The second program contains the armed away check and is disabled so it won't self trigger. If elk zone gate violates then run program 2 if program 2 (which is disabled) If Elk armed away Then send email Link to comment Share on other sites More sharing options...
