Question about control
I have a Toggle Linc setup in my garage to turn on two lights on the outside of my house at a certain time.
Presently I have a program setup as follows:
Program: Garage Light ScheduleIf
From Sunset
To: 11:30pm (same day)
and (
Status of Garage Light is off
then
set Garage Light On
else nothing
I then have a seperate program to turn the lights off:
Program Turn off - Garage Lights
If time is 11:33 pm
and status of Garage Light is on
then
set garage light off
My question is, how can I set this up be overrided should someone manually turn on the switch. Let's say for example that we have people coming over and I don't want to have the lights shut off at 11:33pm. I've played with the control variable
Program Manual Lights on
control garage light is switched on
and program - garage light schedule is false
then
$LightsManual = 1
else
$LightsMaual = 0
It never seems to evaulate properly when I do this however.
Any direction you can provide would be much appreciated!
thanks in advance,
Craig
The manual override should only happen between Sunset and 11PM? That is the effect of using the Program True/False state and that can be impacted by whether the garage light was already on at Sunset.
Also the Variable is not used in any of the Programs that actual control the light so it would seem the latest Program is not posted.
Start with
and control garage light is not switched Off
then
$LightsManual = 1
else
$LightsMaual = 0
Now the Variable reflects true manual switch operation. It should be an Integer Variable. It can now be used to prevent the automatic turn Off at 11:33 PM
If time is 11:33 pm
and $LightsManual = 0
then
