Xathros
  1. Xathros replied to alambertus's topic in Blink
    @Panda88 Up and running here again with 0.6.5. Thank you -Xathros
  2. Thanks @bmercier , PG3 is up and going and I can access its console just fine. I opened Safari's console and tried for eisy-ui as suggested. Looks like a problem with a certificate. I tried again with http and am able to login fine. -Xathros
  3. Yessir I am. Looks like an invalid certificate. -Xath
  4. Hello everyone, I attempted to install eisy-ui 0.7.2 this evening. After running the update, I can no longer log in to the eisy-ui web app.. I get to the login screen but when submitting my credentials it just says network error in red beneath the password field . I have rebooted, stopped and started the eisy-ui service but still unable to login. I AM still able to log into the portal and the admin console normally. Any ideas? Thanks in advance. -Xathros
  5. Not working for me either. Doesn't like the old auth key and can't seem to prompt Blink to send a new one. -Xathros
  6. Hello Jimbo, I recently deployed a few EP25 plug modules. These or the WiFi,Bluetooth, HomeKit supported variety. The KASA app recognizes them as do Apple HomeKit, Alexa and Google. The KASA Plugin for PG3 does not seem to see them. Could support for these be added without too much trouble? Thanks in advance and let me know if there is anything I can provide to assist. -Xathros
  7. Xathros replied to roho's topic in YoLink
    I’m interested but will need the new hub first. -Xathros
  8. Hi Panda88, After a power outage yesterday, my YoLink plugin is sending Fail/reconnect messages about every 10 seconds. In addition, the plugin behavior on the dashboard is strange. If I stop the plugin, PG says it stopped but after a few seconds, the dashboard shows it as connected again - although log activity stops and the fail/reconnect messages stop. Subsequent attempts to stop the plugin result in a message saying it can't be stopped because it isn't running. Here is an excerpt from my YoLink log that shows the failure cycle: 2025-02-16 08:46:36.291 MQTT udi_interface.interface INFO interface:_disconnect: MQTT Unexpected disconnection. Reason code: Unspecified error. Sent by server: False. Retry in 10 seconds. 2025-02-16 08:46:39.127 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:46:43.130 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:46:46.300 MQTT udi_interface.interface INFO interface:_disconnect: MQTT: Reconnect successful 2025-02-16 08:46:47.131 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:46:47.348 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success 2025-02-16 08:46:47.348 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:xx:xx:xx:xx_5 - MID: 103 Result: 0 2025-02-16 08:46:47.392 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 103. Reason codes: ['Granted QoS 0'] 2025-02-16 08:46:51.132 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:46:55.144 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:46:58.330 MQTT udi_interface.interface INFO interface:_disconnect: MQTT Unexpected disconnection. Reason code: Unspecified error. Sent by server: False. Retry in 10 seconds. 2025-02-16 08:46:59.145 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:47:03.147 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:47:07.153 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:47:08.340 MQTT udi_interface.interface INFO interface:_disconnect: MQTT: Reconnect successful 2025-02-16 08:47:09.389 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success 2025-02-16 08:47:09.389 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:xx:xx:xx:xx_5 - MID: 105 Result: 0 2025-02-16 08:47:09.430 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 105. Reason codes: ['Granted QoS 0'] 2025-02-16 08:47:11.155 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:47:15.167 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:47:19.178 Thread-7 (start) udi_interface DEBUG udi-YoLink:addNodes: Waiting for node MotionSensor-Basement Motion Sensor to be ready 2025-02-16 08:47:20.369 MQTT udi_interface.interface INFO interface:_disconnect: MQTT Unexpected disconnection. Reason code: Unspecified error. Sent by server: False. Retry in 10 seconds. Unlike my previous issues, this seems to be a local connection issue with MQQT rather than broker issues with the YoLink cloud service. I have deleted and reinstalled the plugin with the same outcome. I'm on IoX 5.9.1, PG3 3.3.18 Any idea what's going on here? Thanks in advance. -Xathros
  9. I did. Seems my Unifi controller sees it as a new device after the upgrade. Had to reset the reservation. No big deal, just unexpected. -Xath
  10. Upgrade completed with no problem. Only issue I encountered is the eisy got a different dhcp IP assignment after upgrade. Entire process took about 15 minutes. -Xathros
  11. elight started following Xathros
  12. Hi @Panda88 All was working great till this morning. UDM notifications indicated that the Yolink poly along with other polys disconnected and reconnected overnight. I suspect that's the point where it began failing. I have verified my UAID and Secret key. Neither have changed. All the Yolink stuff is still working within the Yolink app. I'll PM my full log. Thanks. -Xathros
  13. Hello all, Seem to be having some issues this morning with Yolink. The Yolink app is working just fine but the poly fails to get current statuses. Log show the following repeating every 4-5 seconds: 2024-05-07 08:55:49,723 Thread-7 udi_interface INFO yoLink_init_V3:connect_to_broker: Connecting to broker... 2024-05-07 08:55:49,723 Thread-7 udi_interface DEBUG yoLink_init_V3:request_new_token: yoAccess Token exists : True 2024-05-07 08:55:49,723 Thread-7 udi_interface INFO yoLink_init_V3:connect_to_broker: Retrieving YoLink API info 2024-05-07 08:55:49,723 Thread-7 udi_interface DEBUG yoLink_init_V3:retrieve_device_list: retrieve_device_list 2024-05-07 08:55:50,160 Thread-7 udi_interface DEBUG yoLink_init_V3:retrieve_device_list: device_list : [{'deviceId': 'd88b4c0100074ca9', 'deviceUDID': '2957d90d375544aea49991785390e155', 'name': 'Barn Motion Sensor', 'token': '8A47DACB92276044A076C5CFD8D7018D', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c02000ca3e4', 'deviceUDID': '2fc6f498d94d4a699f9fbe38d12ec50e', 'name': 'Basement Door Sensor', 'token': '122D727B7F4E92B4E92A858A23F6A511', 'type': 'DoorSensor', 'parentDeviceId': None, 'modelName': 'YS7704-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c01000757db', 'deviceUDID': 'aa818c60c8cf4be7aa7e6fbdfd8e1d0e', 'name': 'Basement Motion Sensor', 'token': 'A60A9E9F9D9C2480D7CF32A1A1322065', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100075033', 'deviceUDID': '74f560ea575148cfa02173b5d50492ad', 'name': 'Basement Stairs', 'token': '257A5324CAAD9E3011E964C09A27CC47', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c010004c458', 'deviceUDID': 'e2abd27375a34fa5b6f80fdf3a2fedba', 'name': 'Garage Fridge', 'token': 'C3A3488CC2342C8A15083BEE319B9F39', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8003-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100074bcd', 'deviceUDID': 'f26d5bc3da734588aca9e91da2c8b5b7', 'name': 'Garage Motion', 'token': 'B58BD964F3F29CF97065CD99143ABD34', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c020005ca60', 'deviceUDID': '06326306a9794126aba60770f8482e2d', 'name': 'Garage Temperature', 'token': 'B60C1EA7F4198D4CD89BF418F166A0D8', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8003-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100063524', 'deviceUDID': '3a9fddd9f1a343488f6b897e344d17e3', 'name': 'Kitchen Fridge', 'token': '39126021820D4D92100F11C9A829D7F0', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8003-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100090d2e', 'deviceUDID': '71fee28929174bb095b6e05766583f2a', 'name': 'Machine Shop Motion Sensor', 'token': '4C4B5760F769A8C8345E3DE106764D48', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0200076baf', 'deviceUDID': '1d3e9b6beca14bffa54f4c8c5d7eb470', 'name': 'Screen Porch Temperature', 'token': '960D33529B3526CF469515F41B371D5E', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8003-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c02000ca0f2', 'deviceUDID': '2635e0da3439452c8015244725f856cb', 'name': 'Shop Stairs Door Sensor', 'token': '498AA52AE154E138723BA81259A01289', 'type': 'DoorSensor', 'parentDeviceId': None, 'modelName': 'YS7704-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100075378', 'deviceUDID': 'b436e639361943b4bd5e5d3e541723e6', 'name': 'shop Stairwell', 'token': 'A3C1FC53C868B5E36BEF8AE6D3271F89', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c010004cbd9', 'deviceUDID': 'a5d4448c0a9e46419f3468ea5f407d3b', 'name': 'Spider Lake', 'token': 'E7496CC5BD1034D4409AFDC51869E44D', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8004-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c02000ca156', 'deviceUDID': 'f0b85664f2fd449898156d720649c41d', 'name': 'Tool Room Door Sensor', 'token': '7EE37DFFEC0CB7D836BA62B3A3F1B2C0', 'type': 'DoorSensor', 'parentDeviceId': None, 'modelName': 'YS7704-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100090c6b', 'deviceUDID': '4f321b5b28c24589aae2d585209268b7', 'name': 'Tool Room Motion Sensor', 'token': '840E59ABFD0B7FB04215EB9DA5CB8288', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100098c15', 'deviceUDID': 'f52d9cd79c0741e38c2a933f5d211363', 'name': 'Water Pump Outlet', 'token': '3BCAAF2A4C317104520910A29A3D41A0', 'type': 'Outlet', 'parentDeviceId': None, 'modelName': 'YS6803-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0200078fe5', 'deviceUDID': 'dd73bd9582c64324923143ac61198d8a', 'name': 'Well House Temperature', 'token': '2D31986E331744DA9A41F3A07B90AE12', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8003-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c010007495a', 'deviceUDID': 'e0729530911d4c708aa7bd5b367a6064', 'name': 'Woodshop Motion', 'token': '348BE8EF533A99B8ECDAB3E2BE9A79A6', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100063a2c', 'deviceUDID': '243ee4d7b8544760951022fab7f3ea0d', 'name': 'WoodshopTemp Humidity', 'token': 'F548FDEC2774416B7BC0CE4F1DB8008C', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8003-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100075618', 'deviceUDID': 'c76a871c1bce40c99ff67a6b6dd8dd5e', 'name': 'Workshop Motion', 'token': 'D48ABA71859E471754556E1440891338', 'type': 'MotionSensor', 'parentDeviceId': None, 'modelName': 'YS7804-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c0100063078', 'deviceUDID': '21d928ed95f64391a7d61b5d614f37ec', 'name': 'Workshop Temp and Humidity', 'token': '0B958957F1FC17F684D13C1EE562F062', 'type': 'THSensor', 'parentDeviceId': None, 'modelName': 'YS8003-UC', 'serviceZone': 'us_west_1'}, {'deviceId': 'd88b4c1603025463', 'deviceUDID': '16a35a2e0e4942839ec187c5553b345b', 'name': 'YoLink Hub', 'token': 'DAB5E188D4A5DFB563BA10BD77350942', 'type': 'Hub', 'parentDeviceId': None, 'modelName': 'YS1603-UC', 'serviceZone': None}] 2024-05-07 08:55:56,263 Thread-7 udi_interface ERROR yoLink_init_V3:connect_to_broker: Exception - connect_to_broker: timed out Any thoughts? Thanks oin advance. -Xathros
  14. Hi All, Just to add myself to the pool here. Contact sensors not triggering Alexa routines for me either. Been out for maybe about a week (Not sure exactly when it stopped working). I see the correct contact state in the Alexa app and it changes in nearly real time. I don't believe this is a UDI skill or portal problem at this point. Looks like Amazon just broke their stuff. Probably happened around the time they added the floor plan smart home feature. HMMM - I set up a floor plan to play with in the Alexa app maybe around the time the routines stopped triggering. Anyone else or is that just coincidence? -Xathros
  15. Hello @JMC, Log into Openweathermap.com with your account credentials. Click API Keys at the top of the page. In another browser window/tab log into Polyglot. Click on details on the Openweathermap node server, scroll down to custom configuration parameters and compare the API key listed there with the one in Openweathermap.com window/tab. In addition, on the Openweathermap node server, you can select the log tab and set log level to INFO. Stop and start the node server and watch the log for any info that might clue you in to what's going wrong. Hope this helps. -Xathros
  16. 3.1.2 Running fine for me as well. I had installed 3.1.1 after the 5.71 IoX upgrade with no problems as well. -Xathros
