tome
Everything posted by tome
  1. Paulbates suggestion worked, after factory reset and restore the Leak Sensor started registering heartbeat again. Thanks for the info and suggestion of the YoLink, I will look into it. Thanks, Geddy for the further info. I did some brief reading and if I understand correctly Home Assistant seems to be the way many people are moving for home automation. I see that HA can integrate in with the ISY or newer UD systems as well as a host of others. I assume that's the idea, one ring to rule them all...? Seems like HA should be the next step I should take and I can keep my ISY if or until I decide to decommission it and it's devices and move to something else. If I have the wrong idea on things please correct me. Thanks again for all who helped. -Tom
  2. Ok, I factory reset the device, put it in linking mode and did Restore Device. I also rebooted the ISY for the fun of it. Now the programs for this misbehaving leak sensor are also showing "Running Then" and a Next Scheduled Run time as well. So hopefully it is back in sync. Thanks for your help, -Tom
  3. I suspect you are saying I should do a factory reset on the device first (remove battery, hold set button, install battery) and THEN "restore device"? Also, I noticed in the Program Summary that my other working leak sensors show "Running Then" in the Activity field for the Variable Control 2 program and have a Next Scheduled Run set for tomorrow for the Variable Control 3 program, whereas this (not working) sensor doesn't show "Running Then" or have a Next Scheduled Run time set... -Tom
  4. Thanks. I just did restore device (before I read your message) just for kicks. Is factory reset different or the same as Restore Device? -Tom
  5. I have a 2852-222 leak sensor that has been working for many years. I replaced the battery a couple months ago with a Lithium AA battery. A week ago it missed heartbeats for a couple days. I went and checked, and the battery is good. I put it back in it's place figuring removing the battery would reset any issue. It didn't, still missing heartbeat every day. I went and got it today to test it. When I view it in the ISY it shows Wet Off/Dry On as it should, and Heartbeat is On. If I set it on a wet paper towel it shows Wet On/Dry Off. So it appears to be working. Is there a way to test the heartbeat? I was planning to leave it upstairs with me for a day or two and see it resolves, but not sure why it is suddenly missing hearbeat...? Also, I have wondered for a while, what are people using for Leak Sensors these days? Should I be looking for a different solution, wifi ones, or what? I don't have a ton of Insteon devices but I have enough that I should be thinking of a migration strategy to something that is supported, but havent been following the state of the art in home automation for quite a few years now... Any advice is appreciated. -Tom
  6. That was it! I clicked the Save Changes button in the Program Details tab and they all saved and all seem to be back to normal. Many thanks for your help. -Tom
  7. Yes, I noticed that "not saved" in the status field but didn't know what it meant. I didn't see anything in the update instructions on re-saving anything. Or I missed that if it was in there.. Definitely (100% sure) the UI and firmware are the same version. There is no yellow in the summary. I checked for that immediately after the update while disabling a few programs that got re-enabled in the update. -Tom PS: I guess the last part of this instruction could be interpreted as re-save: "Please ensure your device nodes and programs are correct; in some cases you may need to update them."
  8. I did clear the cache after the update and did verify UI and firmware match. I will try your suggestion of saving each program again this eve. Thanks, -Tom
  9. Yes, I see that it is now that I checked my Programs! These programs are enabled so not sure why they aren't working...
  10. Im having some strange SwitchLinc behaviors after my update to 5.3.4. I have 2 SwitchLincs (call them east and west) that operates my entry lights. A physical single tap on either one turns on/of the lights (this is working). A double tap on the west one turned on/off my driveway lights before the update, now not working. Not sure if double-tap ever worked on the east one as I wouldn't normally do it from that location. But in any case that isn't working there either if it did. Also, when I go into the admin onsole and use software to control the switches, east works to turn on/off entry lights. But west goes on (I hear relay and leds indicate on) but the lights don't actually come on, and the east switch leds don't change state (which they use to do to indicate on). At first I thought it was just this one set of switches, but I also have one in my lower level that double tap would turn on lights in an outbuilding. That too seems to not be working. Is there a way in the ISY to tell if this behavior is programmed? Or to re-program it? I think I programmed these switches manually when I installed them so many years ago, but I would not sear to that, too long ago. Oh, and I ran Restore Devices in the console, but that didn't help the situation. -Tom
  11. Ok, thanks to both of you. I don't really need more than one user, just habit. I must have changed the admin user name to one of my own last time. -Tom
  12. Geddy, Thanks that was it! One other question. It appears to have removed my userid. Did it always have 9 users you were able to define? I don't recall that before. Also, when I enter my name and set a password, it prompts me if I want to change the password for my new user. I say yes and the prompt goes away. But it doesn't seem to be creating that user. If I go look at user1 again the fields are blank and it doesn't let me log in with the values I just set. I can, of course, get back in with Admin and my newly set admin password... -Tom
  13. I updated to 5.3.4 followig the instructions on the 5.3.4 Current Release thread as well as advice in the thread below. The update seemed to go fine but when I cleared my java cash, follow the link for the new admin console and try to log in it says Failed Retry Authenticating My Lighting. I know I am entering the correct userid and password. What can I do? -Tom
  14. Interesting. I have two versions of the leak sensors: 2852-222 v.41 and 2852-222 v.00 I left all 4 of them in the "wet on" mode after testing and all of them reset themselves back to "dry on" ("wet off") by themselves. I didn't reset them or do anything other than setting them back down on the floor... -Tom
  15. Yes, Insteon leak sensors. Thanks! Out of curiosity, if I leave the mode in the wet position, it will clear itself at some point yes? -Tom
  16. I recently upgraded my ISY to 4.9. Unbeknownst to me the previous version (which I had been running for a very long time) default smtp server apparently didn’t work and I was not getting notifications. Once I upgraded to 4.9 I got notifications of missed heartbeats on 4 of my leak sensors. I figured it was batteries since they have been in place for many years. I replaced the batteries yesterday afternoon and figured that would solve the issue. It didn’t. I got missed heartbeats again this morning. Checked contacts, etc when changing batteries so I’m pretty sure all that is fine. My question is what is a quick and easy way to see if the leak sensors are still working? -Tom
  17. 4.9 was indeed uneventful. Will do the next step when I have time to troubleshoot any issues (just in case any arise). Thanks again, -Tom
  18. Many thanks for the reply! I do not have any Z-wave and don't see a Z-wave menu item. I updated to the 994 when they first came out and were discontinuing the older hardware. I don't think Z-wave was an option at the time, or I didn't want to use it so didn't get that option anyway. So do I go to 5.3.4 or to 5.0.16C? I don't think I am using "Adjust scene" in any of my programs, but I did copy all the programs so I have them and will take a look. -Tom
  19. My ISY994 is on 4.8.0 and it's been a long while since I've done anything with it. It is telling me that 4.9.0 is available to upgrade to. Should I do that? I see that 5.3.4 (I think) is out and just wondering if I should just skip 4.9.0 and go to 5.x? I see that upgrading to 5.x will require some tweaking of programs and things so I will put it off until I have time to fully understand the steps and be able to fix things that break. I don't have z-wave and am not really doing anything new but I usually don't like to get too far behind the latest release. -Tom
  20. tome replied to eas1205's topic in ISY994
    Not that this is your issue, but I just wanted to emphasize what tmorse305 said: "new brand of LED light bulb". I have a long saga which I won't go into here but be aware that many LED light bulbs are incredibly noisy both in external radio frequency interference as well as power line induced noise. I spent weeks debugging an odd problem with remote garage door openers (even replacing a garage door control module) that I eventually discovered, using a software defined radio turned into frequency analyzer, that new LED light bulbs I had installed were generating a huge amount of noise in exactly the frequency range of the remote openers. In my case it was external RF, but I put a scope on the power line and it was there as well. After testing a number of different brand bulbs I ended up using Cree bulbs sold at Home Depot (which were cheaper anyway) and replacing many expensive Sylvania and Philips bulbs I had in my house/garage. That was about 4 years ago so perhaps those brands are better now, but I learned my lesson! If I have Insteon or RF issues new light bulbs are the first place I look now.
  21. I have a Lamplinc that seems to work fine when I command it On/Off or push the button on the side of it. I also have it controlled by a keypad button that also turns it on/off just fine. I have it in a Scene with several other LampLincs to control some LED Christmas lights. I have a program that turns the scene on at dusk and off at midnight. I've noticed that when shut off by the program this one Lamplinc doesn't turn the LEDs all the way off. If I go into the ISY and command the Lamplinc On and then back Off it shuts off all the way. I thought maybe it had something to with using Set Scene Off in the program so last night I changed the program to command each individual Lamplinc and turned them on/off one at a time with 5 seconds between them just to see what happened. Nothing changed. They all cycled off except for this one that was very slightly on. I launched the ISY interface and looked at the status to see if it showed that it was partially on but it wasn't. Status showed as Off and the slider showed it all the way at zero yet the LEDs were still glowing ever so slightly. A manual On/Off and it's fixed. Any ideas why this might be happening? By the way, all the Lamplincs were purchased at the same time (years ago) so are all the same version, etc. The software I am running is the last 4.8 variant (4.8.0 I think). The load on this particular Lamplinc may be a tiny bit higher than the others, but that is probably splitting hairs. The other lamplincs have a single string of small led xmas lights on them. This one has 3-4 strings of lights. And again, manual off works every single time, programmed off fails every single time. -Tom
  22. Ah yes sorry. It is the countdown keypad timer thing that I have. I do have a Timerlinc in a box but haven't actually used that...
  23. I have 4 TimerLincs in my house. This one that died has been a thorn in my side for many years. I have had to reset it (pull out the little switch and push and hold for reset) many times over the years. But it has always come back to life after doing that. What I would see is that it would just stop sending commands to the ISY. If you pushed a button it would light up and act as if it worked (timer progressively counted down and lit each button) but it wasn't triggering anything. After a reset it would come back to life. I thought that is what it was doing again and I was tired of it so rather than reset it again I ordered a new regular Switchlinc On/OFF switch to replace it. It was a long time before I got to replacing it. When I finally got around to installing the SwictchLinc I discovered the reason the TimerLinc wasn't working, it was completely fried. The inside had clearly caught fire, there were char marks in the electrical box and the plastic housing was melted. I lost a neutral line into my house a while ago and that event wreaked havoc in my house. I lost many devices (10's of thousands of dollars in damage). This was one I thing hadn't checked... -Tom
  24. I was going to ask next the question (you answered) regarding "not switched off". Thanks for the clarification on these issues! -Tom
  25. Agreed, I think we are saying the same thing. I was just saying the Ecobee itself is only time control, the ISY can do more than that as you have pointed out... -Tom
