TUhl01
Everything posted by TUhl01
  1. TUhl01 replied to DennisC's topic in YoLink
    All good now on my UD Mobile sync. Thanks for the fix.
  2. TUhl01 replied to DennisC's topic in YoLink
    YoLink plugin was updated this AM as well as the UD Mobile.
  3. TUhl01 replied to DennisC's topic in YoLink
    This is the error i am getting when synchronizing UD Mobile.
  4. TUhl01 posted a topic in OpenWeatherMap
    The plug-in variable, GV19 for each forecast, is displaying the numeric value for the day versus the day name. This just happened in the last couple of days.
  5. Totally puzzled. Did not have time to look into what I experienced last night with the device offline message and authenticate message stated on the Ring plugin that I viewed on UD Mobile. Viewing this morning on AC, all devices are online, and no messages are shown on the Ring plugin. All is well at this time. Thanks@bmercier for the quick action taken to resolve the RING problem.
  6. Updated as stated to 1.2.6 4 hours ago and just got an offline message for 1 of my Ring devices. The Ring plug-in has a message to authenticate. Any suggestions.
  7. Re-authenticating worked for me for a short period of time. Have done many times without permanent success.
  8. Having the same problem here. Deleted Ring plug-in and reinstalled as well as doing a reboot of EISY. Did not help correct this problem.
  9. TUhl01 replied to TUhl01's topic in UD Mobile
    Not available in Apple App Store or TestFlight at this time.
  10. TUhl01 posted a topic in UD Mobile
    Where can this be found to update UD Mobile?
  11. Why do I continually see this message, when currently on 1.2.3. for this plugin? Version 1.2.2 of this plugin is available.
  12. I just downloaded the beta version in TestFlight that is ready to install. Will the current functionality be impacted? All is working great and don’t want to get into trouble. I just did a backup. Did you have any issues upon installing the beta version with the current functionality?
  13. Got the same error when synced UD Mobile. Could be due to not having the Matter function in the app. Would like to know when IOS update will be available.
  14. It's under the Z-Wave tab on the Admin Console.
  15. I have not seen the new version in the Apple App Store. What is the version shown. I'm on Version 1.1.88.
  16. Same here. Glad to hear I'm not the only user not seeing Matter in either application. A ticket has been submitted on my end. Just received this reply regarding my ticket on Matter not appearing: Javier Refuerzo wrote: Hi Thomas, Beta versions are awaiting approval from both Google (Android) and Apple (iOS). Usually gets released in 24-72 hours.
  17. Installed about an hour ago. Do not see a tab to add a Matter device. Other, all seems to be as before update.
  18. Any progress on this problem?
  19. After updating to 1.3.3, all my user defined audios were scrambled with the default audios. In turn, the programs that included AudioPlayer code were updated with the audio that now resides in that slot. Each program had to be reviewed and changes made to play the right audio. A ticket has been submitted.
  20. TUhl01 replied to chris.com's topic in AudioPlayer
    I can get to my HP Printer and Denon AVR with no problem using a IP address, not the eisy.
  21. TUhl01 replied to chris.com's topic in AudioPlayer
    Using Edge and that address is what is stated on the router for EISY.
  22. TUhl01 replied to chris.com's topic in AudioPlayer
    This is what I get, even when turning off Firewall.
  23. TUhl01 replied to chris.com's topic in AudioPlayer
    @Michel Kohanim How do I get my udx version?
  24. TUhl01 replied to chris.com's topic in AudioPlayer
    Not able to play sound from Bluetooth connection. I'm paired to a Bose Bluetooth speaker. Is there another command that I need in the program? Also, not showing the AudioPlayer custom configurations in drop down, only mp3's for different sounds. If I restart the AudioPlayer, I do hear 2 click on speaker for the stop and start of the plugin.
  25. Yolink has 1 that works with EISY. You need a Yolink hub and the Yolink PG3 Plugin. I am using the thermometer and 6 water sensors. All work great and have problems with developing programs to interface with the devices. Many other devices are also available.
