ase
Everything posted by ase
  1. ase replied to CPrince's topic in Polisy
    As we have discussed for literally days at a time. Both Polisy and Eisy are X86-64 PCs, just like you have sitting on your desk. They are simply smaller format. Polisy OEM was pcengines(https://pcengines.ch) all of the accessories like wifi and Bluetooth cards are available at that site, even wall mounts. Eisy OEM is MELE(https://www.mele.cn/). The OS for both is FreeBSD. In terms of why you were not able to use the backup directly is most likely because your windows based computer probably didn't have the needed options to mount an ext3/4 filesystems. For the best experience when working with systems like Polisy it is best to be working from a Linux or BSD system(windows sucks anyway). In terms of backup you can easily transfer any files with sftp and for full backups simply use dd to make an image. If in the future you want to use either as something other than a home automation controller, you can reflash the bios (I don't know if Eisy is a custom bios) and install OS and software you want.
  2. ase replied to jkraus's topic in Polisy
    The hardware is from pcengines and is world renowned for reliability. After reading you past posts, I think there maybe some issues with your power source. The processor used in polisy is a passive cool model and is mounted on the bottom of the board. AMD white papers don't have any design for active cooling on the processor. Polisy shouldn't ever get hot enough to cause any issues. However, just like any electronic device it is sensitive to voltage drops and spikes. Also note that any computer processor is vulnerable to different type of electrical waves. You may want to do some line quality checks.
  3. Try sudo -i to enter root and reissue commands without sudo
  4. I think you may be stuck in a cycle of over thinking. Break down each think into a smaller program and then have a master program set to run each of the programs. It may take some trial and error. But, I find breaking it down into smaller bits helps to find what does and doesn't work and the adjustments are easier.
  5. Do you have a z-wave dongle plugged in? If you do try unplugging it and rebooting the unit. If the error goes away it is likely your z-wave dongle is not responding. This is a known bug in the previous z-wave firmware release. You may need to follow the firmware update procedure posted on this forum.
  6. ase replied to sndflea's topic in ISY994
    According to the Insteon Troubleshooting graph, this is most likely caused by excessive noise on the line. I suspect that your new heat pump may be the reason. Compressor motors like those use in heat pumps are known for being rather noisey. Moving this device over to a comparable Z-wave device maybe the only real option at the moment.
  7. You don't need both. http 8080 is fine if you are just using it on your lan.
  8. May have just been a mistake. Each of Polisy's interfaces have a different mac. They may have just used the wrong one on the sticker. You can use the ifconfig command in the shell and it will display each address. The one used for uuid should be ig0 but it is possible they put ig1's or ig2's on the sticker.
  9. Had the same error. Had to use the trial option. Then it updated the uuid.
  10. Virtual Box works well for this kind of thing. Just make sure to install extensions and allow the usb device to be used buy the guest os.
  11. ase replied to jlamb's topic in Polisy
    You can use sudo -i to work within the root user.
  12. You're not allowed to go anywhere. Lol. You're too important. Seriously though Thank you for all you've done over the last 17 years.
  13. No one is proposing a database of every parameter for every device ever made. You seem to have an Issue with reading into things whatever you want. There is a difference in parameters that are of use within the software and many of the device setting based parameters. Those "thousands of parameters" you refer to are often for hard coded items that no users are going to change, nor are they intended to be modified by a user. Many of them cannot be modified via software anyway. There would be no reason to deal with those. Say a thermostat has a parameter to modify temp tolerance, this is set and validated, users are never going to need that in a nice drop down interface. Next your not going to bother tracking parameters for devices that are not currently produced. You also wouldn't track parameters of "low quality" manufacturers. Many of these devices don't have quality documentation. Next most manufacturers assign the parameters across their entire product line. Take zooz for instance every single one of their dimmers use the same parameters to assign dim speed. So once that pattern is established, unless the manufacturers makes a change, the parameters can be applied across their product lines. As for why I referred to UDI in a proactive manner is because as stated above UDI would need to make a few small changes to ISY to allow for either an external database to be imported by users or allow for custom parameters to be added within a device. Either way I have begun contacting manufacturers to get full copies of how they assign parameters. I guarantee you that each manufacturer has a methodology. Now if you have suggestions on how I should format the resulting data I would love to hear it. It doesn't doesn't matter if UDI uses the data or not. There isn't a comprehensive listing of parameters for the commonly used Z-wave devices and most of them have documentation that includes this information but not presented in an understandable format for most. I have helped author some of the world's most used database driven CMSs, I am well aware of how to deal with large data sets. All the best.
  14. I guess what I am alluding to is if we had a database of these parameters, and if UDI were to build this idea into ISY. A customized pull down menu could be created. This way you would simply look up the parameters and then create the relevant pull downs. This puts no work or major changes on to UDI and still allows the user to create the UI the way they want.
  15. No one suggested UDI maintain the database. A database is very simple each person simply adds the parameters as they find them. This requires zero effort for UDI. This concept is called crowd souce. It is how many companies support complex products. I am personally tempted just to host the database on my servers. Further no one has suggested that ISY or Polisy are for non tech people. There are however different levels technical understanding. I don't know your level however, I have written software, designed hardware, administrated networks for f500 companies as well as run my own IT firm. I am willing to bet that I see things very differently than the home grown hobbyist. I would in fact advocate that professionals install home automation due to the technical and electrical aspects. However, the fact remains that will often not be the case. That being the case I believe that professional methods should be taught to those who are looking for guidance. After all the methods are built around safety and future troubleshooting. Part of providing that support as a community is to build out information for common use by users at all technical levels. Nobody expects UDI to step up support, they expect the community to step up, after all they are the ones that derive benefits from it. A community is also an optional thing. The community isn't even just this one, it is people in the home automation community in general. A database of z-wave parameters would help all of the different home automation users. The only real question for me is what format should be used.
  16. This is one of the major drawbacks to z-wave. Each manufacturer is free to implement things as they see fit. In order to convert these parameters into readable menu options would require a team of people just inputting the information. This is one of the big reasons why I believe in documentation of everything. Once you get out of the Insteon only realm things can get very tricky, very quickly. You really need to plan out ahead and have an idea of the technical aspects before you even buy. This is very much at odds with the buy an Insteon device and just know it will work. My advice to UDI would be to harness this community to start to buildout a database of these parameters. JMHO
  17. One of the tricks I used when I was having issues with this was in the past was to setup a Gmail account just for notifications from my ISY, then set up ISY to use that account to send from and also as the primary address for receiving. Since the E-mail is being sent directly from that account on gmail and to that account, there is zero lag time. Then I set up push notifications for that e-mail account. You can send as text to a phone, but text from an E-mail account always goes though additional Procmail filters to filter as much spam as possible. So this slows the delivery at that point, and larryllix pointed out text is always a lower priority as well. So E-mail to Text is just kinda a crapshoot. UD's E-mail server has been very quick as of current so I just have it send to that same Gmail account and keep the push notifications set on that account. I had set both text and E-Mail and E-Mail won every single time.
  18. My god SMH. I am sad for you. ?
  19. They really are awesome aren't they.
  20. I certainly not trying to aggravate anyone. However, there seems to be some tender egos here(to be nice I won't call anyone what they are called in other forums) Geeky stuff. Looking forward to poking around your new geeky additions. lol On a serious note, lock these boxes down tight, you have done way too much work to let someone reverse engineer them. You don't want someone cloning them. I know you guys aren't making much on them and the programming is golden. I know a lot of people here don't understand how much work that is but I do. And I appreciate how much time and work you have done. I am sure that the me Running VM of Polisy is a bit alarming to you. I am not out to clone, just keep my inlaws off my ***, can't give them any instability or I will never hear the end of it. Have A Great Day
  21. You could use a Z-wave controller with RGBW type LEDs. I don't know how well they would work as I have never tried it myself. I would search Amazon and see. If you have a Z-wave module in your ISY994i you do have some options.
  22. Not interesting at all. The point of my deleted post is that the answer is in plain sight if one looks. Just like putting it all on a VM, it is something a toddler with a PC can do. Too much of this "support" is people who just don't know, giving poor advice. Either way I am done with that, let them screw things up, hopefully they learn from their mistakes. To get the system on A VM is pretty basic just install a FreeBSD VM SFTP all of the files from Polisy over to your pc then upload the files into the proper directories in your FreeBSD VM. Make sure to create the proper pools. Bingo Bango, it will run. Of course if you want full functionality of the software you need to use a PLM and pass the ports, you will also need to edit the network configs to match the VM, but nothing complex. Obviously you can't install any portals or anything, but you can test software stability this way. I am sure this is how they test the software at UDI, it would be much faster than loading to real hardware everytime. lol. Have a great day.
  23. Delete Done With trying to help anyone here! All I get is harassed for helping with the proper ways.
  24. I don't think Insteon is going out of business, at least not liquidation. They are owned by a Capital Investment company at this point, if anything they will gut out the IP and sell it. I am more concerned with them closing down more avenues of access for third party usage than I am about them going under. That said the Idea of Polyglot and Polisy was to make UDI less dependant on Insteon for customers and bring in a more diverse home automation group. ISY is very powerful software and shouldn't be strapped by support for a certain brand. However, the time tested and solid method of allowing users to create their own interactions. It is a very solid method for tech savvy users. Unfortunately the market on the hardware side is just rattled with little more than snake oil products. The a fact in the market right now is that an uninformed newbie doesn't stand a chance of navigating the product selection at the moment. To be brutal, navigating away from Insteon right now only has only real solid path, and that is Z-wave. None of the Nodes on Polyglot are going to give you the peace of mind for the future in terms of compatibility with Polisy or ISY even if UDI implemented a certificate or QC system. Compatibility can only be achieved if the manufacture maintains some local API that is usable to create a node. If the company decides to stop doing that, than game over. So moving away from Insteon it is just better to look at the protocols rather then the brands themselves. Insteon was just the marriage of both a brand and a protocol that worked for most people that were doing this kind of thing. Unfortunately they were a bit ahead of the curve on the consumer front and when the consumers were ready Insteon just didn't do a good job at pitching itself. Myself I think for most things Z-Wave will work great, on the Polyglot side I am going to look at the manufacture and deciding based on what I see as to what I will buy knowing that while it works for me now, an Update of firmware may break that compatibility. So I think for me anyway It will come down to how open is the company with their users. If they are tight lipped like say apple than no go, If they are open then yes.
