jaycanter
Everything posted by jaycanter
  1. jaycanter replied to jaycanter's topic in ISY994
    Thank You that worked. Still don't understand how power failure changed username and password. Also changed port back to 80. But got in and changed login and port back, Now just have to get wireless working.
  2. jaycanter replied to jaycanter's topic in ISY994
    Ok today i rebooted everything then checked on some stuff. all my programs are running that are time based. It's the wireless that's not working. I can find it on the network and is connected in the portal. It's on the network with the right address, I can see it. Link to start up video below It just will not take my login info to access the console. I don't understand how login info changed. Any thoughts how to get in without wiping everything?
  3. jaycanter posted a topic in ISY994
    Had a power failure last night was out till around noon today. I noticed my motion sensors aren't working so i tried to login to the isy and keeps telling me Failed. Retry Authenticating My Lighting. What could be messed up? No matter what i can't login. Thanks
  4. It says expired 8/1/2019 I got Polisy 12/2019 and it comes with 2yrs subscription of portal. Guess i need to check with UDI Support why it is gone. Thanks
  5. I got the portal add on when i purchased Polisy, Logged into portal it says access license is not active. I can not find where subscription is? I have emails from before when i had it but not since i purchased polisy. Over the weekend Google stopped controlling lights and i found isy didn't have internet enabled. Not sure how it changed over the weekend. I enabled internet access and trying to set up ud mobile and it keeps failing. Is it failing cause of the access license is not active?
  6. Thanks paulbates I'll try that
  7. jaycanter posted a topic in UD Portal
    My portal expired couple days ago. I did order a Polisy PRO that comes with 2 years of the portal. does anyone know if i renew it now will the 2yr start after the year of my renewal? trying to decide if i renew if it'll be only covering the 2 months till i get the Polisy PRO or will i end up with full 3 years from date of renewal. Thanks
  8. jaycanter replied to jaycanter's topic in ISY994
    @giesen the plm is about a year old. I need to fiqure out how to test the plm's i have about 8 of them and not sure which 1's work.
  9. jaycanter replied to jaycanter's topic in ISY994
    well finally after few resets it started working. went back and checked and back in march when it started acting up and posted error log it was said possibly memory card. I'm gonna replace it but can't find where it list the sizes that can be used. the smallest i have is a 64gb. Will it work in the Isy?
  10. jaycanter replied to jaycanter's topic in ISY994
    Tried removing and reinstalling micro sd and no change.
  11. jaycanter posted a topic in ISY994
    I have had my Isy running for years but in the last yr or so it would just stop working with error led on. a reboot and worked again. tonight same thing couple lights didn't turn on and when i checked it only the power led was on. so tried logging in the isy launcher and it couldn't find it. i don't remember address so logged into network to check the address it says last seen about an hr ago. I tried logging into that address and nothing so i rebooted the isy. usually the lights only flicker for a few seconds on startup but now the stay on for a while then the error light came on and blinked. Not sure what next step is to try never had the leds do this. see attached video. https://youtu.be/ZARvaJuvOGs
  12. jaycanter replied to jaycanter's topic in ISY994
    not sure if i have a recent backup i usually don't think about the isy since it just runs. might have 1 from when plm was replaced 6 months ago. Can i just do a backup and replace the card? Thanks
  13. jaycanter replied to jaycanter's topic in ISY994
    i just found the error log, Not sure what it means but the date starts around Christmas. everything is just run together in a text file is there a way to sort it? also heres some of there errors the last few days Sat 2018/03/10 02:54:26 PM System -170001 [Network-DNS][Task=22] Failed DNS 1346/rc=6 Sat 2018/03/10 02:54:26 PM System -140000 my.isy.io Sat 2018/03/10 02:54:30 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:54:35 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:54:40 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:54:45 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:54:50 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:54:55 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:00 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:01 PM System -170001 [Network-DNS][Task=22] Failed DNS 1347/rc=6 Sat 2018/03/10 02:55:01 PM System -140000 my.isy.io Sat 2018/03/10 02:55:05 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:10 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:15 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:20 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:25 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:30 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:35 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:36 PM System -170001 [Network-DNS][Task=22] Failed DNS 1348/rc=6 Sat 2018/03/10 02:55:36 PM System -140000 my.isy.io at 2018/03/10 02:55:40 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:45 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:50 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:55:55 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:00 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:05 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:10 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:11 PM System -170001 [Network-DNS][Task=22] Failed DNS 1349/rc=6 Sat 2018/03/10 02:56:11 PM System -140000 my.isy.io Sat 2018/03/10 02:56:15 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:20 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:25 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:30 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:35 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:40 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:45 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:46 PM System -170001 [Network-DNS][Task=22] Failed DNS 1350/rc=6 Sat 2018/03/10 02:56:46 PM System -140000 my.isy.io Sat 2018/03/10 02:56:50 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:56:55 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:57:00 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:57:05 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:57:10 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:57:15 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:57:20 PM System -100 [DHCP] state=RENEW Sat 2018/03/10 02:57:21 PM System -170001 [Network-DNS][Task=22] Failed DNS 1351/rc=6 Sat 2018/03/10 02:57:21 PM System -140000 my.isy.io Sat 2018/03/10 02:57:45 PM System -5 Start Sat 2018/03/10 02:57:50 PM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Sat 2018/03/10 02:57:51 PM System -110022 /CONF/UXT.BIN Sat 2018/03/10 02:57:51 PM System -110012 /CONF/UXT.BIN Sat 2018/03/10 02:57:52 PM System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Sat 2018/03/10 02:57:52 PM System -7123 ID 0013 :err=0, tag='control', num=6, nest=4, o Sat 2018/03/10 02:57:54 PM System -170001 [Network] Established Sat 2018/03/10 02:57:52 PM System -80004 n/a Sat 2018/03/10 02:58:53 PM System -5012 26 Sat 2018/03/10 02:58:54 PM System -5006 uuid:26 Sat 2018/03/10 02:58:57 PM System -5006 uuid:26 Sun 2018/03/11 03:00:03 AM System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Sun 2018/03/11 03:00:04 AM System -7123 ID 0013 :err=0, tag='control', num=6, nest=4, o Sun 2018/03/11 03:57:51 AM System -100 [DHCP] state=RENEW Sun 2018/03/11 10:00:50 AM System -170001 [UDSockets] RSub:42 error:6 Sun 2018/03/11 10:07:12 AM System -5012 29 Sun 2018/03/11 10:07:15 AM System -5006 uuid:29 Sun 2018/03/11 10:07:17 AM System -5006 uuid:29 Sun 2018/03/11 03:57:54 PM System -100 [DHCP] state=RENEW Sun 2018/03/11 03:58:29 PM System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Sun 2018/03/11 03:58:29 PM System -7123 ID 0013 :err=0, tag='control', num=6, nest=4, o Mon 2018/03/12 03:57:59 AM System -100 [DHCP] state=RENEW Mon 2018/03/12 01:53:03 PM System -170001 [UDSockets] RSub:42 error:6 Mon 2018/03/12 01:53:08 PM System -170001 [UDSockets] RSub:42 error:6 Mon 2018/03/12 01:53:13 PM System -170001 [UDSockets] RSub:42 error:6 Mon 2018/03/12 01:53:14 PM System -5012 31 Mon 2018/03/12 01:53:25 PM System -5006 uuid:31 Mon 2018/03/12 01:53:27 PM System -5006 uuid:31 Mon 2018/03/12 02:01:42 PM System -5 Start Mon 2018/03/12 02:01:47 PM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Mon 2018/03/12 02:01:47 PM System -110022 /CONF/UXT.BIN Mon 2018/03/12 02:01:47 PM System -110012 /CONF/UXT.BIN Mon 2018/03/12 02:01:48 PM System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Mon 2018/03/12 02:01:48 PM System -7123 ID 0013 :err=0, tag='control', num=6, nest=4, o Mon 2018/03/12 02:01:50 PM System -170001 [Network] Established Mon 2018/03/12 02:01:49 PM System -80004 n/a Mon 2018/03/12 08:40:37 PM System -170001 [UDSockets] RSub:42 error:6 Tue 2018/03/13 02:01:46 AM System -100 [DHCP] state=RENEW Tue 2018/03/13 12:55:49 PM System -170001 [TCP-Conn] -1/-140002, Portal-Dispatch Tue 2018/03/13 12:56:29 PM System -170001 [TCP-Conn] -1/-140002, Portal-Dispatch Tue 2018/03/13 05:47:05 PM System -5 Start Tue 2018/03/13 05:47:10 PM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Tue 2018/03/13 05:47:10 PM System -110022 /CONF/UXT.BIN Tue 2018/03/13 05:47:10 PM System -110012 /CONF/UXT.BIN Tue 2018/03/13 05:47:11 PM System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Tue 2018/03/13 05:47:11 PM System -7123 ID 0013 :err=0, tag='control', num=6, nest=4, o Tue 2018/03/13 05:47:13 PM System -170001 [Network] Established Tue 2018/03/13 05:47:12 PM System -80004 n/a Tue 2018/03/13 08:08:58 PM System -5 Start Tue 2018/03/13 08:09:03 PM System -110022 /DEF/F6/I1/NLS/EN_US.TXT Tue 2018/03/13 08:09:03 PM System -110022 /CONF/UXT.BIN Tue 2018/03/13 08:09:03 PM System -110012 /CONF/UXT.BIN Tue 2018/03/13 08:09:04 PM System -7153 ID 0002 :err=0, tag='/group', num=20, nest=5, o Tue 2018/03/13 08:09:05 PM System -7123 ID 0013 :err=0, tag='control', num=6, nest=4, o Tue 2018/03/13 08:09:06 PM System -170001 [Network] Established
  14. jaycanter replied to jaycanter's topic in ISY994
    Hi Michel, It was just the memory light the last time i reset it. I don't remember times before that. Just when my bathroom or laundry motions don't work i was just unplugging it to reset. Didn't pay attention to the lights thought maybe a fluke. Yesterday my blinds didn't close and outdoor lighting didn't execute. blinds 1/2 hr before sunset and lights at sunset. I checked there was no error lights. but i used the mobile linc app and run the programs and everything worked.
  15. jaycanter posted a topic in ISY994
    My systems been in for years working fine except losing the smarthome device and having to replace. But for the last month or so i notice motions not running and check the Isy and find the red led blinking. reset power to it and everything works again for a day maybe up to a week then happens again. Is that a sign of the memory card going bad? What should i look for? Can i just change it? or is there certain steps to follow? searching i found it to be memory but it doesn't do it all the time. Thanks Jay
  16. I am running a 65 ft cable between mine in the walls then another couple cables from the wall outlets to the isy and plm so I am Probably over 70 ft with no problem I think somebody said the cable shouldn't be over 50 ft but I didn't have a choice. Jay Sent from my Galaxy Nexus using Tapatalk
  17. OK Thanks Jay
  18. jaycanter posted a topic in ISY994
    I upgraded and don't understand variables so i am trying to read up on these i havn't tried anything yet but my event viewer shows this every time i open it and don't know what it is or matters Sat 03/12/2011 05:54:18 PM : [FileOpen ] Open failed for [/CONF/INTEGER.VAR] ® Sat 03/12/2011 05:54:18 PM : [FileOpen ] Open failed for [/CONF/STATE.VAR] ® Sat 03/12/2011 05:54:18 PM : [FileOpen ] Open failed for [/CONF/INTEGER.VAR] ® Sat 03/12/2011 05:54:18 PM : [FileOpen ] Open failed for [/CONF/STATE.VAR] ®
  19. jaycanter posted a topic in ISY994
  20. I knows they say that your not supposed. To go over 50ft on a run but I was running out of options I had to recheck and redo seeveral times cause I had stuff in the connections wrong. If I remember right I had to use a meter to check continuity across the cable to verify the right wires were on the right pins at each end sorry for the spelling I am on the road
  21. I had to run mine from my panel back to my living room to use the infared, and my total run between the isy and the plm is 75 ft and has worked perfect since december. i would double check your connections. I had the same situation but i could not find the culprit causing my noise. but never thought about the projector cause it's on it's own circuit and was all ways off.
  22. i use the File | Enable Internet Access to enable remote access and my time server has a exclamation point. so i enabled it and the exclamation point didn't go away so i rechecked and it was internet access was disabled. everytime i enabled and went back and looked it was disabled. i was using my laptop online reaserching new phones when the auto update popup happened. now today internet access shows enabled.
  23. i am also getting a autoupdate status popup saying authorization failed every hr or so after i clear it
  24. I just upgraded from 2.8.14 and lost internet access. when i click on enable internet access it says failed enabling internet access. I can see it on my network and access it no problems ip is the same it was before the upgrade.
  25. got home any reinstall 2.8.13 and everything working that quit with the upgrade. Still don't understand why when i change the port # i loose the isy and have a heck of a time getting back in then set it back to 80 and works fine. Any Ideas would be helpful Thanks Jay
