Everything posted by jerlands
We don't value Daylight around here
There are many areas of the country which do not observe DST and I suspect eventually it'll go away all together. I believe this could be considered a bug report and I'm sure UDI will address it. Jon...
Java 2+ Required - Tried All Suggestions...
You might try using java application (admin.jnlp, download from release thread for your firmware version.) The java applet (launches from browser) uses browser resources so to use it you may have to clear the browser cache to use it. Jon...
This is really hard for me... where do I begin?
You'd have to decide that. Alexa affords control of devices, programs and scenes via voice so can you make use of that feature? People use it in a variety of ways but just as HA isn't necessary either is Alexa. Jon...
49/180= 27% Here's Wiki instructions for setting up the portal and for setting up echo. Jon...
IsY down ?
What make and model of router do you have? Someone might be able to help in discovery. Jon...
IsY down ?
It's not possible for two devices to share the same IP. 00:21:B9 <<-- see Wiki Accessing the router's lan table should be your easiest and most reliable method for finding ISY and if it doesn't show there I don't think ISY then is communicating with it. Are you certain the ethernet cable connecting ISY and the router is good? Looking at where the cable connects to ISY and the router do you see green blinking LED lights? I might reseat each connection? Jon...
Alexa from a Smartphone
That seems to be one of the quirky features... you have to tap for reply or they'll compile Jon...
Issues with status updates on 2441ZTH Thermostat
Thanks, Gen5 looks like a marked improvement. Z-Wave's growing like a monster Jon...
I don't believe Gen5 is fully supported yet but seems like a good choice. Re: Gen5 - Is this going to require a firmware upgrade to the dongle? Jon...
Simple notification program not working
Use "Control" for battery operated devices Jon...
IsY down ?
You do want to download the correct UI version for the 994i however. Jon...
There are various Z-Wave devices that monitor temp. Also an ongoing thread on the 2441ZTH Jon...
IsY down ?
It looks to me you have 8 devices connected MWareman is in IT so hopefully he'll chime in. Have you power cycled ISY (remove power for 30 sec. then plug in.) afterwards do the arp -a again You could also open a ticket with UDI Jon...
IsY down ?
From what I can tell ISY isn't seen on your network. You seem to have subnet address' of 224.0.0 (x) while your main network is 192.168.1.(x) I'm trying for understand what the other devices are that are connected to your network. No matter though.. either ISY isn't communicating on the network or it's behind one of the subnets. Jon...
IsY down ?
What I meant to say is.. How is your network setup? Jon...
IsY down ?
Is ISY behind the router i.e., 224.0.0.x? Jon...
IsY down ?
Another note... "Early ISY's will have a MAC address which begins with the segments 00:03; these MAC addresses are from NetBurner" Jon...
IsY down ?
Here's Wiki Instruction to "Finding ISY IP address." Jon...
IsY down ?
You'll need the IP address. One way in Windows is to open the command prompt (Run > cmd) and type in arp - a and you're looking for a MAC address that starts with 00:21:b9 Here's an instructional video (don't bother deleting certs.) Jon...
Upgrading 99i/IR PRO to ISY994i?
No.. click on Purchase Modules in admin console (help > purchase modules) I'm not certain that it isn't effective immediately. Jon...
IsY down ?
I think your problem was in using the wrong address. Jon...
IsY down ?
Your ISY is the 99i? This device is no longer supported so your bound to run into future issues but I think I'd download the application (.jnlp) rather than use the applet (browser based.) Clear Java Cache First! Jon...
Yes, just download and install the app then follow the directions you see in the browser to input phone number and you'll be routed to connecting with your amazon account. Jon...
It's not connected to Echo but communicates directly with Alexa (cellular or wifi.) Try it.. its FREE! Jon...
Yes I haven't played with all of the features but currently only use it for Alexa control Jon...
