Temp/Humidity sensor temp units wrong in programming
OK - I'll release the version
you should be able to install on top of your existing one - and see if it fixes the issue - or is there no beta store with the new system Maybe migrate back - install beta in PG3 and test - if OK, I'll release production and you can install that and migrate back
I put 1.8.66 in the non-production store - give it a try - if is does not work, can you describe how you test it (so I can do the same) If you need the local version, let me know - you should be able to install on top of your existing one (and revert back if needed) Mine has been running for half a day without issues
Got it - I think I found the issue - eisy does not read the node definitions the same way - the program goes for the initialized value - not the current value Working on a fix Can you help test once I believe it is working - I can release a beta version
Let me take a look - What version of eISY0UI are you running ?
Panda88 started following Vue will not start after upgrade of IoX , Temp/Humidity sensor temp units wrong in programming , No data being received and 2 others
Can you send me the log - Benoit says the server works
I'll ask them to take a look again
New Release
A new release is provided - moves to the new API - Read documentation on how to obtain keys from the website - the serialnumber no longer works A few additions is also included including time reporting
NEW RELEASE
Hi Nodeis updated to use the latest API - MQTT - it lowers requirements on eISY quite a lot. A new summary node is introduced, and power is now the main parameter of each node. NOTE - A NEW LOGIN procedure is required - it is described in the documentation
Thanks - yes, I never looked before so worried about the ERROR I think it is ok now - there was something going on yesterday BTW - you need to update the store version - still shows 1.0.27 (but installs 1.0.28) Thanks
I am seeing the same issue - I migrated to the new eisy.ui and after that it failed. I did try reinstall, but it does not see to clear memory - My credential remain after I reinstall in same slot LOG 2026-10-26 14:31:34.867 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode 2026-10-26 14:31:34.867 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode 2026-10-26 14:31:34.867 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS addnode message {'id': '413964', 'uuid': '00:21:b9:02:6f:52', 'profileNum': 8, 'address': '413964', 'name': 'VUE Tahoe Main Panel', 'nodeDefId': 'controller', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '413964', 'isPrimary': 1, 'enabled': 1, 'private': None, 'timeAdded': 1793050266685, 'timeModified': 1793050294859, 'dbVersion': 1} from Polyglot 2026-10-26 14:31:34.867 Command udi_interface.interface DEBUG interface:_handleAddNode: add node response: {'id': '413964', 'uuid': '00:21:b9:02:6f:52', 'profileNum': 8, 'address': '413964', 'name': 'VUE Tahoe Main Panel', 'nodeDefId': 'controller', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': '413964', 'isPrimary': 1, 'enabled': 1, 'private': None, 'timeAdded': 1793050266685, 'timeModified': 1793050294859, 'dbVersion': 1} 2026-10-26 14:31:34.872 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message setController 2026-10-26 14:31:34.873 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING setController 2026-10-26 14:31:34.873 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS setController message {'success': True} from Polyglot 2026-10-26 14:31:34.873 Command udi_interface.interface DEBUG interface:_handleInput: connection status node/driver update 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: dev.channels is <class 'list'> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310cfab8290> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2170250> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d22125d0> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d22123d0> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212590> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212450> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212490> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212290> 2026-10-26 14:31:35.130 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212390> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212410> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d22122d0> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212310> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212350> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212150> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212250> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface ERROR vue:discover: 413964 channel <pyemvue.device.VueDeviceChannel object at 0x310d2212190> 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: GID: 413964 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Manufacturer: SXF2438A001A1C6920E302A4 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Model: WAT001 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Firmware: None 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Name: VUE Tahoe Main Panel 2026-10-26 14:31:35.131 Thread-2 (parameterHandler) udi_interface INFO vue:discover: Found channel: 1 - Heat Tape (None)
ST-NuHeat Node Server broke after reboot
Can you retrieve the profile files again?
upgrade fails in eisy ui
I saw there just was a new release of the UI - maybe try that before anything else I would try to delete and reinstall - I believe they are really the same
There are no errors in the Yolink log - Maybe try to reboot the system or reinstall the nodes - there are other nodes with errors as well
can you send me a log and I can take a look
Panda88
Joined
Last visited
