gdntx
  1. By the way - to fix the issue, I rebooted my EISY.
  2. I had similar problems replacing a switch last week. Seems the java console has some issues. Open the relatively new "UD Mobile" app on your smart phone and I bet you'll see the switch. Might have been able to see the old one there too.
  3. This sounds like a familiar problem. Are you in the Java console? If so, it was changed some time back, but not well documented. The Write Changes button doesn't do much. After making your adjustment, click on the actual button "On Level" or "Ramp Rate" after making your adjustments. It will write your changes.
  4. Likely issues with the scene - if ISY gets the command from Alexa, Alexa did its part and triggered. Its up ISY and your switches to react to and execute the scene.
  5. Alexa has been pretty solid for many years for setting up and using the spokens. I don't think I could live without it. Having said that, I'm tired of Amazon having all of my information. As soon as the new Apple TV is out, I'm upgrading and going to attempt to move to HomeKit as the heart of my automation to get rid of Alexa. I've had HomeAssistant in place for about a year, but have done very little with it. I did investigate enough to find it has an integration back to ISY and can be used for voice commands. Home Assistant will likely be what I use to pull in more devices in the house - alarm, Sonos, etc and enhance my routines beyond lighting which has been my focus for many years.
  6. No add ons running against my EISY other than Mobilinc Pro. I opened a case. No issues found so far, but next time it hangs, I'll check with SSH before I reboot. If I can connect, Michel has given me some commands to check a few things. Looks like trying to ensure systems are still running - isy, udx, and checking ports. I had another problem tonight, in the Java console. I had to replace a switch. Went through the normal motions, add switch, replace switch, and it appeared to work, but no matter what I did it would not show up in the list of switches, making it look like it had not worked. Every time I opened the Java console, it showed up in a dialog box saying new switch. I opened UD Mobile and it was there fully replaced and operational. It operated in my programs and macros. I finally rebooted the EISY (it had only been a couple days) and it now shows up - new switch, fully replaced the old one.
  7. gdntx replied to dblee1950's topic in eisy
    Ddi you have any feedback? Open a case? You are not alone, there are other threads. I'm running the new beta. Mine has locked up or stopped running a handful of times since upgrading. The next time it happens I need to remember trying SSH before pulling the plug to see if the device and base OS are active and it was just ISY/Insteon that failed.
  8. My device just hung overnight again. 100% unresponsive (I do wish I had tried SSH before unplugging, but didn't think about that at the time)I had previously looked for OS dumps as noted above and didn't have any. I just opened ticket 28286 with UD.
  9. I've come to research and note the same thing. I've had to reboot 4 times as it is unresponsive from all aspects, the App, Alexa, etc. It is usually pretty dang hot - I unplug and let it boot back up and all is good. The first time was about a month ago and I found the 0.7.2 update, so I updated and it has happened twice again in the last 2 weeks. Figured there might be others in the same situation. I've not made updates, no new programs or fundamental changes - only the new GUI. Guessing I'll open a ticket if nothing comes of this thread. Seems more like a runaway process on the device causing it to heat up and become unresponsive.
  10. Yep - glad things are back up. Working in IT I get what it takes to have a major outage anytime, let alone a holiday. But, tongue in cheek, let's just say - AUTOEXTEND.
  11. Is the firmware in the PLM undateable? I've searched and looked on Insteon's page and I don't find any instructions on how that is done. I have a new PLM and EISY, so I shouldn't need to update, but just curious for sometime in the future to keep the system all tuned up and running well.
  12. gdntx replied to dbwarner5's topic in ratgdo
    I saw a RATDGO forum over at Home Assistant. You might find more help there.
  13. What "Span" size did you use to get 3 wide? I can't seem to get 3 icons to one row.
  14. gdntx replied to SJK's topic in eisy
    Does BSD have a cron tab? Set up a weekly reboot from the OS.
  15. I believe the way the Portal and all components work you don't ever truly have to worry about this - you can use DHCP. The portal knows your Eisy by Mac address and how to find your home network. There is magic that allows the portal to connect. I'll call it magic, because I don't fully know what protocols are used and how it allows the traffic into your home network. Maybe someone will clarify that for me too. What I can note and help with is how to get a static IP address for the Eisy if you prefer the static. I used to do that by hardcoding the IP in my ISY and turning off DHCP, but I've learned is that a "Reservation" in the router seems to be preferred these days. So I've switched to the reservation when I upgraded to Eisy. If you pull up the console for the router, look for Advanced Config, then LAN you'll find the IP reservation section. You'll see all connected devices and will show the Mac address of each including your Eisy. Find the Eisy, select it and add the reservation - choose the static IP address you want and assign it, save it. Then reboot your Eisy. It will always get that same IP address now when rebooted.
