Jimbo.Automates
Everything posted by Jimbo.Automates
  1. It has a persistent connection to the elk which reads and processes all the changes. IF you experience that issue then download log package and PM that to me the before midnight on the day it happens.
  2. I get no response from their support, so I can not give a timeframe, the error is on their side.
  3. Why are the left pointing arrows a problem? I gave you a workaround for the PyISY issue so it is solved for you. The PyISY version used in PG3 is old, and requires a lot of work to upgrade since it is called by PG3 and not my plugin. If I charged a price for the plugin that actually paid for the time I spent creating it and supporting it then it would be very expensive. It's a side job I do to help the community.
  4. The ELK Plugin does not poll the Elk, it connects to the Elk the exact same way the old ISY Elk module did, so it can't make the Elk to busy to do it's job. From your description this does not involve the Eisy and/or Elk Plugin at all, and reviewing your logs there is nothing of interest. I am the developer so you can PM me at anytime, but usually better to post on the forum to allow other users to answer if possible. If you go to the PG3x plugin page for the Elk Plugin and change logging mode to Debug+Modules it will log more information, then if you experience the issue again note the time and download log package before midnight the same day and send that to me with the time. I'll review the log and see if it happened to be going crazy.
  5. It's not a problem, it's just the icons chosen. Also, please stop YELLING.
  6. So that did fix it. It was a bug in a shared library PyISY that we use. Your welcome.
  7. For some reason it won't let me edit my post above. After the last "Save", also hit "Save" at the bottom of the window. There are NO error logs, the errors were in the debug.log.
  8. I don't think this will fix it, but please try this: Open Admin Console with IoX Launcher and login Click "Configuration" Tab Click "Netowrking" Tab Click "Network Resources" Tab Click "Add" button at bottom Hit Enter to accept Name as Name.1 Click the "- Select to Edit Content -" in the URL Column In the new window enter "somehost" for the Host Click "Save" So you'll have this Then restart the plugin for the PG3x UI, and if the errors still show go to the Log for the ELK Plugin and "Download Log Package" and PM that to me.
  9. Looks like you found the page, that's the PG3X page showing the error, and I see you attached the log, I'll try to review this today.
  10. The Node Server errors should show up on the PG3X page for the plugin. I don't see a screenshot of the PG3x ELK Plugin page, only a screenshot of the Admin Console. If you restart the plugin do the errors get cleared?
  11. Yes, this is an issue with anyone trying to add a new one. I've emailed and created a ticket with the vendor with no response. I'm setting up a new eisy in my new home and trying to bring back to life an older wireless tags hub but have not been successful yet.
  12. The red exclamations are because as shown on your screen "Node Server Errors" = 1. The debug.log doesn't show the error since it rolls over each night. Is there an error shown on the PG3x Page for this plugin?
  13. This issue has been reported to wireless tags by myself and another developer and they claim there's no issue. I will have to deauthorize mine to test and risk not being able to authorize again... Support from that company has gone from bad to worse. Sent from my Pixel 8 Pro using Tapatalk
  14. I build heartbeat into all my plugins which is used to confirm the plugin is still functional and connected to polyglot and polyglot connection to IoX is good. That is different from API authorization which can fail but heartbeat is still good. Sent from my Pixel 8 Pro using Tapatalk
  15. Yes, ecobee knows if the API authorization succeeded. Sent from my Pixel 8 Pro using Tapatalk
  16. AC is admin console,.it is subscribing to the eisy to capture real time device changes happening on the eisy. Sent from my Pixel 8 Pro using Tapatalk
  17. The subscription is for the live updates,. without it you won't see changes in the AC as they happen. Sent from my Pixel 8 Pro using Tapatalk
  18. That has nothing to do with the elk plugin. It's the UI trying to connect to your eisy. Sent from my Pixel 8 Pro using Tapatalk
  19. If you manually deleted a node, restarting the plugin should add the node back. Sent from my Pixel 8 Pro using Tapatalk
  20. Yes, you should never use that menu to modify a plugin or it's nodes. The plugin handles it's own nodes. Sent from my Pixel 8 Pro using Tapatalk
  21. On startup the plugin must poll all to set initial values. I'll have to review the code but it should wait the defined time to poll again, but it might try more frequently after a failure. But really you shouldn't need to restart IoX every day. Sent from my Pixel 8 Pro using Tapatalk
  22. You can't re-add the node manually. If the configuration is correct then restarting the plugin should add back the node. Sent from my Pixel 8 Pro using Tapatalk
  23. Did you follow all the instructions in the plugin configuration page? https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/blob/master/configdoc.md ELKID This works by right-clicking on a node in the ISY and adding a note with "ELKID=n" where n is a unique integer Then click on the "export" link provided below which will appear once your ELK is synced Note: Depending on how many devices on your IoX it may take a while to process and generate the export file. Once the file is downloaded, open ElkRP connect to your System, then right click on Automation -> Lighting and import the file.
  24. Nothing happening in the logs, Benoit has stated it's not a plugin issue. Sent from my Pixel 8 Pro using Tapatalk
  25. As I said in my email to you: I have one nagging issue with the beta that I can't resolve with one of my plugs, but if it's working for you then I can promote beta to production. Personally I do not use Kasa plugs or switches for anything that needs to be controlled by IoX, only light strips and power strips. But in the end I would hope that connecting the new Kasa devices to IoX via Matter will be the best solution. But I've not dived into the Matter world at all yet..
