jwagner010
Everything posted by jwagner010
  1. For what it’s worth I periodically have issues with Alexa+ that pop and then resolve themselves. For example this happened last night, I have a light with spoken of ‘Dining room light’ and another device called ‘Living Room Shades’. Last night when I would say ‘Alexa turn off Dining Room Light’ instead of the dining room light going off the living room shade would go down. Checking / changing / refreshing the UD portal and everything else does nothing. It’s an Alexa+ issue, how do I come to that conclusion, when I say ‘Alexa turn off Dining Room Light’ to an old (cannot be upgraded to Alexa+) echo device the dining room light goes off, when I say ‘Alexa turn off Dining Room Light’ to one of my newer echos upgraded to Alexa+ the living room shade goes down. I think Alexa+ is Amazon’s version of AS (artificial stupidity) versus AI. Anyway this morning things are back and working as normal, just another glitch, there will be more with Amazon Alexa+ AS.
  2. Hi, is the Roomba node server compatible with the Roomba 205 DustCompactor Combo Vac and also the Roomba Max 705 Vac?
  3. I have iOS 18 and don’t see how to add faceid to open the app. Can you provide instructions?
  4. Same on iOS, can lock edits, looking for a pin/Face ID to open the app given some of things that are controlled by the app.
  5. Can we look to have a pin/faceID to open the UD Mobile app in the future as an option for those that want a greater level of control and security over the app?
  6. Ok. Pity, but understand the rationale. Perhaps a GenAI powered ticket system and a GenAI powered forum can remove these costly tickets from the need for UD humans to respond to them. 😀
  7. Is it possible to hide a controller on the home screen? I know it was possible in earlier versions, I have multiple controllers and would be helpful to be able to hide an entire controller from the homescreen.
  8. Curious, the web server available through the admin console under the configuration and networking tab, (I have a POLISY), am I able to add php scripts that I can call remotely on the polisy web server?
  9. Would be nice if you could select a different attribute for the advanced config than what is displayed in the tile. So you can show for example the temp in the tile but change the icon color if the hvac is actually cooling, heating or idle.
  10. jwagner010 posted a topic in UD Mobile
    @JaviIf its not already on the list, would it be possible to have a selectable filter when looking at the All Devices and Scenes view, where you can select only On or only Off (or variations of that) devices and scenes to show? Would be handy to be able to see all Devices and Scenes that are on quickly for example. Similar to email I guess where you can just see your unread emails.
  11. Back. Thanks UDI.
  12. 5/2/24 @ 9:20AM ET still unable to connect remotely via UDMobile. @Javi
  13. @Michel Kohanim @Javi I hope everyone is well. Would it be possible to get an update and target date/time for when things may be restored for users affected by this OAuth error? Thanks for all the hard work and support.
  14. @btreinders It only charges you after the 1,000 calls have been made at that rate. You can also put a.limit on your plan of 1000 calls and it will reject (not process the call therefore no bill you) should you go above the 1000 in case you accidentally configure things that way.
  15. @Javi I am at work so cannot check local but some data points: UD mobile connects to my Polisy (5.8.0) fine remotely UD mobile does not connect remotely to my ISY 994i (5.3.4) - oAuthPortal Error UD portal shows both systems online with the green light. Portal web access works on POLISY Portal web access does not work on the ISY994i Running latest UD mobile .60 Appears to be portal and ISY 994i related?
  16. Same issue cannot connect remotely. Following.
  17. I understand you can use the graph.microsoft.com API to append rows of data to excel 365 workbooks but have never invested the time to better understand the API and whether it’s something that could be used for this use case leveraging an IOX network resource or an IOX network resource that calls a php script on the web server or something like that. Lots of info at url above and specific examples here: https://learn.microsoft.com/en-us/graph/excel-write-to-workbook
  18. Perhaps something like this behind your current manual shutoff valve. Pricey but would fit the use case: https://www.homecontrols.com/Greenfield-Z-Wave-Automatic-Security-Valve-Kit-GFASVxZ?quantity=1&custcol2=25
  19. @Goose66Thank you Thank You this is what I was looking for. Based on a look at the launcher JNLP it is now isyfinder-3.5.jar which I was able to download and execute per your guidance above. I guess the trick is to just periodically download the latest jar file as it changes. @RPerraultUnfortunately I am on the naughty list so no PC from Santa this year.
  20. Long story for another day, but my Laptop (Windows 11) is restricted by my employer from loading and running Oracle JAVA on it. We are limited to Azul Zulu being our Java JRE/JDK environment, and it does not include Java web start (javaws) being part of the standard Zulu install (I believe it is Azul IceTea but that is also restricted). I know nothing about JAVA so go easy on me, my questions are: Can I run the Admin Console another way than launching the JNLP file from windows web environment? If not, will the EISY ever get a non JAVA interface and if so the best guess what year? This question is not meant to inflame a debate on the AC and JAVA, just curious, I am still on my 994 and I have been a UDI fan and user since the ISY-26 days, but with a large Z-wave based installation I really don't want to upgrade to EISY until the AC interface is sorted out. I am happy to keep the 994i for the next 2 to 3 years (I have a POLISY running PG3), but if a new interface isn't on the cards in the next 2 maybe 3 years I might as well bite the bullet now and look at alternatives, not that I want to or necessarily will, just looking at my options.
  21. Is there anything I can do on Polisy/PG3x side to fix the certificate issue? Eg install a let’s encrypt certificate?
  22. Interesting, thanks. I learned something today!!!!
  23. I thought port 3000 was for https only. So you can use http or https over port 3000?
  24. I upgraded my POLISY from PG3 to PG3X over the weekend. A few issues with a couple of the Node Servers not converting correctly that I was able to resolve and get up and running. The one thing I cannot resolve is after the upgrade I cannot login into PG3X from my work computer (I have always used my work computer for logging into PG3 in the past). Now when I go to log into PG3X I get an error in the browser telling me my connection is not private that when Chrome tried to connect the website sent back unusual and incorrect credentials. NET::ERR_CERT_INVALID I also tried Microsoft Edge and I get a similar error to the above. My employer locks down the browser security levels and certificates on the PC. Seems like something changed with PG3X as I cannot get past the errors above, under PG3 I was able to get to login to the PG3 portal. What would have changed and can I change anything on the PG3X/POLISY side as I cannot make changes to security settings on my PC and Chrome as its locked down? My backup is my iPad and Safari which allows me to access to PG3X still without issue but I would prefer to access PG3X on my work PC versus an iPad. Anyone got thoughts on what is going on with PG3X that is different from a certificate/access access perspective for the PG3X web interface?
  25. Yes it is enabled. Works without fault from Home Screen just not from favorites.
