larryllix
  1. I noticed the Save button was not there but later it was again. Not sure why the change but I originally thought the save may have become automatic in ISY eisyui.
  2. Too much vertical spacing most web pages. This makes programs with many lines hard to follow. Changing screen magnification does not help as the font becomes too small to read. In FireFox the text to line size ratio is about 25%. Way too much space between text lines. For a decent readable font size, I can get about 6-8 line of program on a 4K monitor. Many If sections cannot display all the conditional lines.
  3. My wife says my frittatas are obscene.
  4. I use the best plug-in...The Fliiper. It not only beats the eggs and turns the pan on, but it pours just the right amount of batter for each pancake. The sensor need s a bit of tuning so it doesn't overflow or burn. The upgrade will actually flip the pancakes over based on sample colours that you can set in you eisy-ui webpage. I find a combination of time and colour for the pancake the best in case something goes ajar in the software. Highly recommended, specially when you find yourself lost on the Internet. It is a handle on sanity at times.
  5. It appears that vacation mode shows up in Climate Type as Smart1 and it's changes will not trigger through HomeKitHub. Changing the mode from Heat to Off or back triggers an update in the Vacation status though. Was this an intended style of operation or is this a bug to be fixed yet? (PG3x)
  6. @Jimbo.Automates I have ecobee stat via HomeKitHub working now. How do I get Vacation status from the ecobee stat? I have monitored the Smart7 climate status and it doesn't change. However I did find the Smart1 Climate status changing and modified the configuration of smart2 to say "Vacation". It does report through in IoX and eisy-ui with that nomenclature. However, it will not trigger a program and does not come through without Querying the stat status. Smart7 node is labeled "Vacation" by default installation but would never function. Is there something I am missing here, or is getting Vacation status possible and coded for yet?
  7. Mine were all working fine and the offer came to delete the ones from the OLD system PG3x. It also deleted the nodes from IoX as well and they ceased to exist completely in programs and node lists.
  8. All sounds familiar. I have restored my PG3x plug-ins and have hesitated to try again with eisy-ui. Nice I/F but caused too many problems. Now I am trying to install the HomeHubKit along with ecobee but it seems PG3x plug-ins are none existent will not even respond with a negative message. I am just about to just give up. IoX spews a lot of garbage messages to be cleared, on the screen now, every boot-up. Nonsense messages about new Insteon devices and old events, repeated several times. Very frustrating.
  9. Others, including myself, and @oberkc have had some problems with eisy-ui plug-ins deleting PG3x plug-ins from IoX completely. Still some migration bugs there.
  10. larryllix replied to oberkc's topic in eisy
    My three plug-ins were working fine with them installed in both places. The trouble only started when I agreed to delete them from PG3x.
  11. larryllix replied to oberkc's topic in eisy
    Same thing happened here. I have since deleted the eisy-ui plug-ins and re-installed them back in PG3x. Of course all programs involved with these devices had to be updated (with fake edits) and re-saved to make them function again.
  12. larryllix replied to ErikN's topic in eisy
    West of Thunder Bay was always Central Time along with Manitoba but still switched back to standard. An example of being past the logical time zone boundary..... Neighbours, previously from Thunder Bay, complained about putting the kids to bed at 10:00 PM while the sun was still shining on their beds.
  13. larryllix replied to ErikN's topic in eisy
    This will be coming to Ontario some year soon. Applied and approved in 2020 but some board is waiting for Quebec and NY to co-operate also.
  14. I like colour for On and Off devices and possible Lighter green for partially ON (1-99%) but don't want to see 15 different colours for temperatures, and other analogue things. Too much becomes a garden of visual nonsense. Alarms needs their own colours and that demands a plain background, again, so they don't disappear in a sea of colours. Of course there are blinking colours for alarm levels too.
  15. larryllix replied to larryllix's topic in eisy-ui
    Looks like it came back. My polisy is a mess now and needs PG3 nodes re-installs along with refreshing programs to use the rebuilt labels. I've had worse but this is annoying to have to recheck every node parameter. Thanks to whomever fixed it.
