Everything posted by builderb
		Question about the "unifi_siteid" variable
		Got this up and running, and it works great. I'm curious about the "unifi_siteid" variable, though. I got the node server running by leaving that variable on "default", and as long as the devices I'm trying to track are on the original network my UDM created, it works fine. But I have several VLANs, and I would like one of those to be where the family phones connect to. I'm not sure what ID value to use to get this node server to look at that. Network name didn't work. VLAN ID didn't seem to work either. Is there an example of how to manipulate that variable? Is that even what that variable is set up to do? Ideally I would like to specify multiple VLANs for the node server to watch for various devices. Is that possible?
		Help on gate program and time
		Did you use a separate program to reset it at dawn? As I recall, I put it on a timer because it was as easy as adding a couple lines to the "then" statement.
		Ring doorbell to ISY using Alexa routine
		Apparently Ring has been letting their Ukrainian AI team access customer videos with little oversight or control. Yikes.
		I’ll offer this as an example of an override I use. Might be helpful in your situation. My porch lights turn on via motion sensor, and after a minute not sensing motion, the ISY turns them off. However, there are times when I want to keep the porch light on (guests coming, etc.). So if someone uses the physical switch to turn on the porch light, I also have the ISY disable the one minute timer program that turns the light off. The motion sensor still sends on commands when it senses motion, but that’s fine, the light is already on. Then, when the switch is physically turned off, the timer program is reactivated. I also have a 6 hour timer on the on/disable command to ensure that even if someone *ahem* forgets to turn the porch light back off, it will restore itself to normal function without intervention.
		0-10v led dimmer
		I looked into this for an aquarium light I have that works the same way: line voltage to the LEDs, and a 0-10v control wire regulating the voltage of the lights. You can DIY a controller using the PWM outputs of an Arduino or Pi type device and a voltage doubling circuit. Add a wi-fi shield, and you can have it interact with the ISY REST interface, and back at the light via network resources. With the right skill set, it’s not too difficult. Depends how valuable your time is.
		0-10v led dimmer
		Swimming pool water level control
		The auto top off on my fish tank is a scaled down version of this. It uses an optical level sensor to turn on a pump to replace evaporated water with RODI water to maintain water parameters. The water surface is pretty turbulent too. The trick is that the sensor doesn’t trigger the pump until the sensor is open for two seconds. For a pool, I’m sure you could stretch that to a minute or more. That keeps the pump from coming on every time a wave trough passes by.
		Is this possible? (Auto play Music when touchdown)
		Thinking about this a bit more, you may want to consider wiring up a separate speaker just for this. Presumably you’ll be using your receiver to watch the game. Having it automatically switch to a different input while the replays are being shown might not be ideal. It would also cut down on latency, since you won’t have to switch inputs, pause, play sound, etc. Unless the receiver can automatically overlay an audio track over an already-playing audio stream?
		Don’t know about the Denon. If it stores files locally, and that is exposed to the network commands, then it should be possible. I did something similar, but I used my computer to handle the music portion. I wrote a script that switched the receiver input to the media player, then streamed a playlist from my computer based on a network resource call.
		Water pressure PSI data to ISY ??
		Not cheap, but good quality and well-supported: https://www.atlas-scientific.com/product_pages/pressure/a-10_pressure.html
		Wind sensor for Insteon controlled awning
		If you’re so inclined, the Davis wind sensor (speed and direction) is pretty easy to connect to an arduino or RPi. Then either have it continuously report, or only report over a threshold. Highly accurate, localized, and instantaneous. Oh yeah, links. I use this: https://www.amazon.com/Davis-Instruments-Anemometer-vantage-Pro2153/dp/B076H3HCYX Pulse counter for the wind speed, analog input for the direction. This one is like half the cost of the Davis one, but it’s got lots of support. https://shop.switchdoc.com/collections/sensors/products/weatherrack-anemometer-wind-rain-for-weatherpiarduino-weatherplus-raspberry-pi-arduino
		ISY on a UPS
		My ISY is connected to the same UPS that powers my modem, router, IP cameras, NVR, and the Pi I use as a web server. We get a decent amount of power flickers here, and I don't want all this stuff rebooting every time that happens. Had a couple just yesterday with this blasted heat.
		Bathroom Fan Control Solution
		Easy to approximate! I set up the formula for my weather station, and the dew point formula was a bit of a puzzle for a while. Granted, I needed to use RPN, but still! dewPoint=243.12,humidity,.01,6.112,17.62,5,9,/,tempF_BME,32,-,*,*,5,9,/,tempF_BME,32,-,*,243.12,+,/,EXP,*,*,*,LOG,*,440.1,-,19.43,humidity,.01,6.112,17.62,5,9,/,tempF_BME,32,-,*,*,5,9,/,tempF_BME,32,-,*,243.12,+,/,EXP,*,*,*,LOG,-,/,1.8,*,32,+ [emoji23] Personally, I just use humidity to shut off my bathroom fans. Lights too. If the humidity is up, someone is in the shower. We don't get excessive outdoor humidity here during the day.
		Monitor water softener regeneration
		Atlas Scientific has saltwater capable flow sensors, just FYI. Not the cheapest solution, but if the cheap stuff fails ya... https://www.atlas-scientific.com/flow-meters.html
		Network went down after storm and now can't find ISY
		Did the IP address change when the power came back on? IOW, are you using DHCP for it?
		Google Home on sale
		Guaranteed to drive Apple haterz nutz! [emoji23]
		Save Boot Time To Variable?
		I've got a Pi that sends the 'minutes this year' to the ISY every minute. When the power goes out, I have a program that sends me the amount of time the power was out, and what time it booted up. Problem is, I also have the ISY plugged into a UPS. So the power only "goes out" an hour or so after the power actually goes out. Which is still plenty useful, since it warns me I need to restart my server and check some other stuff. I've been building a weather station that has a battery back up, though. My plan is to read the voltage from the power controller. If it's 5v, the power is on. If it's 4.3v or less, the battery is powering the weather station. Wouldn't be too hard to update an ISY variable letting me know.
		Repeat On and Off Water Pump Switch
		Depending on how mission-critical this pump schedule is, a heartbeat program with a notification may be a good addition.
		ISY and Phillips Hue Integration Step-By-Step (For dummies...like me)
		Everything with an API, or that I plan to send or receive data to/from, or that I plan to monitor gets a static IP here.
		Serial Cable Length
		First time I needed to make a cable, I bought a crappy combo termination kit with a very cheap crimp tool. Tons of failed cables, and much frustration. I have since bought a much nicer crimp tool, and have had zero failures since. My current installation has a fairly short custom CAT 6 cable of about 36", but I have previously had it as far as 24' (of cable) away from my ISY with no ill effects.
		luminance/brightness detectino
		Are we arguing? I didn't think so. There are a lot of ways to skin the proverbial cat, the "best" way is highly subjective. I simply stated one way that I personally have used for light detection. YMMV.
		True enough, but a tag manager is $40, so that tag actually costs $65. Toss in the fact that I had a Pi, power supply, case and SD card laying around, and it's not a bad deal. Also, you could get a Pi Zero W for $10. Plenty of horsepower for a sensor reading. Plus there's the whole 'I'm a DIY type'. Telling me I don't have to code it or build it isn't a selling point. [emoji12]
		I'm a diy type, so I use a Pi and a $7 Lux sensor from Adafruit to measure light levels. I also use ~$1 resistive sensors for a verification of light on/off in a few places.
		Boot-Time Notification?
		Heck, with the new $10 wifi Pi Zero, it's a no-brainer.
		setting a static ip
		There was a Python script posted here a while back that broke your IP address into 4 parts, and sent them to variables on your ISY every so often. If they change, the ISY sends an alert with the new address to you so you can make the change. I also found a script that uses the AWS API to change your IP address automatically if you use AWS Route 53 as your DNS.
