DaveStLou
  1. Migrating to PG3x did indeed fix the problem. Volumio reinstalled.
  2. Since I use this daily, I fired up the Volumio integration in Home Assistant. Still have some bugs getting the Pandora stations to show up correctly as input selections but it's workable. So at least I have a viable workaround via Home Assistant.
  3. So what's the next step in troubleshooting?
  4. Good thought but alas, no difference. On a whim I tried disabling Pi-hole while installing. Also, no difference. I have a backup of Polyglot from a few days ago, should I try restoring that? Any downside or risk?
  5. I had tried that a couple of times before posting. I've also tried rebooting and installing it in a different slot. Same results. Very strange. Any other thoughts?
  6. This week Volumio was not responding properly so I decided to delete and reinstall my Volumio nodeserver. However, it never shows "connected". I am running PG3 3.1.21, Frontend 3.1.21 and IoX 5.6.0 on my Polisy. When I attempt to view the nodeserver logs is get this message: Looking into Polyglot log file (relevant piece attached) I found this line which complains about not being able to find volumio.py: 5/28/2023, 12:26:10 [pg3] error: [Volumio(1)] :: STDERR: python3: can't open file '/var/polyglot/pg3/ns/000db952bf24_1/./volumio.py': [Errno 2] No such file or directory Is there something I need to do differently to install nodeservers under the new PG3 version? log_excerpt.txt
  7. I don't think it was always this way but the Triggered state on my two PTZ cameras is showing as a 0 when False and 1 when True. All of my other Fixed cameras are showing correctly. Is anyone else seeing this? I'm not sure if it's a bug or something in the way I have them set up in Blue Iris.
  8. Very interesting. I had 3 or 4 "reboots" of my Polisy earlier this week. I have a program that sends me a Pushover notice - very similar to your email. I have not opened a ticket but I have reviewed the logs and haven't found anything obvious. In the meantime I've ordered a new power supply from UDI. It's on its way.
  9. That was it. Thanks!
  10. I noticed this some time yesterday that my WeatherPoly Node Server was offline. On the dashboard, I found it's displaying a notice "Failed to start weather monitoring service." Looking at the log, I found "Web server failed to start: [Errno 48] Address already in use" I haven't changed anything on my configuration and I confirmed the port is correctly configured as "8188" I use this NS to receive information from my weewx software and also, haven't made any changes over there. Via ssh, I found this in the port list which looks correct to me: USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS polyglot python3.9 77205 5 tcp4 *:8188 *:* What's the correct way to recover from this? Restarting the Node Server hasn't worked. Thanks!
  11. You can find the PG3 version on GitHub here: https://github.com/exking/udi-mqtt-pg3
  12. Not sure what you mean by "source code for the node servers" but the configuration page on PG3 is the same as PG2. I use devlist but devfile is listed as an option - I've just never used it.
  13. Currently, the NS groups my Pandora stations first and then my Playlists. Would it be possible to place the Playlists first (which change less often) and then the Pandora stations? Since this may not be everyone's preference maybe via a configuration option? In my case, when Pandora stations are created (sometimes accidentally) outside of Volumio, any programs that reference a playlist are affected (since the NS inserts the station above the playlists). If I'm not making this clear, I can provide an example.
  14. I had already tried moving then closer to my Polisy. Factory reset was the key. These are white label plugs I bought from Monoprice so long ago, I didn't remember how to do so on them but plugging them in while pressing the on button seemed to do the trick.
