cyberk
Everything posted by cyberk
  1. Hello team! Can someone help me figure out why the next scheduled run time shows up as tomorrow and not today? I was able to fix it by changing the logic to 24-hours before sunset…..
  2. Thanks for the feedback, no backup so I guess i'll just start from scratch.
  3. Hello Team, For various reasons, we had to do a factory reset on our Polisy. I got it back up and running, installed my old polys, but now I have no idea how to link them to the existin entries in ISY After connecting the Polisy to the ISY, it imported the node server entries that were configured on the ISY, as unmanaged. How do I get these back in a managed state and link them to the Polisy? Many thanks in advance
  4. so i figured i'd post in here in case anyone has a solution before I continue to troubleshoot with UDI. Short story, after updates I can no longer ssh in with admin/admin These are the steps I followed - ssh into Polisy - run command curl -s https://pkg.isy.io/script/update121.sh | sudo bash sudo shutdown -r now - reboot Polisy - run command cat /usr/local/etc/udx.d/static/update13.sh | sudo bash sudo shutdown -r now - reboot Polisy - run command sudo pkg update && sudo pkg upgrade - reboot Polisy - no longer able to SSH in, admin/admin no longer works. No web page on port 80 or port 3000
  5. Has anyone on the 500-series chipset tried to receive primary back to the ISY, as in you have another primary controller, and you're trying to make the ISY primary...?
  6. Pretty sure the ISY can only support one active portal at a time. Have you tried disabling the mobilink portal and seeing if that re-enables the ISY portal? Sent from my iPhone using Tapatalk
  7. @blueman2 Review the documentation for your Z-wave devices. Each device has its own set of parameters and association groups. Different association groups do different things, but usually, every zwave device has at least one association group, and that is the lifeline group. The nodes in that group are the ones that will receive instant status of changes, although from what I understand, they’re no longer needed in zwave+ (500) devices since they all support HAIL by default. So it’s possible your devices have 2 association groups, and that each association group does something else. But we won’t know for sure until we see the documentation for that specific device. Sent from my iPhone using Tapatalk
  8. Thanks for the heads up, I went ahead and enabled the “Freeze ISY Nodes” option, hopefully that helps alleviate the issue. I guess my issue is happening with Aeotec Multisensors, I was going to test more but you saved me time Sent from my iPhone using Tapatalk
  9. Not from what I've seen or read, UDI has confirmed this is an issue in the past, however, it could be with openzwave and not necessarily UDI. There's an experiment I need to perform to see if i can view the ISY secure key in the other controller, I need to get around to it. On other news, I am seeing that for every "Synchronize nodes All" that I initiate, random ghost sensors get created each time, not a lot, just a few each time. I'll have confirmation on this from another ISY sometime tomorrow, but if anyone cares to test in the meantime, that'd be cool
  10. Just a heads up, although this was an existing issue for us prior to the beta, it looks like joining the ISY to an existing z-wave network still doesn't allow communication with already existing secure z-wave devices. If anyone has the ability to test this, I'd like to see if the issue is widespread, or just limited to open-zwave.
  11. I didn't see an entry for the 500 series beta in the wiki, so I went ahead and created one. Those of you with access to maintain the wiki, please feel free to update it as needed.
  12. If you ask me, if it’s going to help development, the price should be increased. Michel, charge me $50 a year! Sent from my iPhone using Tapatalk
  13. Ah ok, I figured it had to do with amazon, google, and Microsoft deploying those fixes on the bare metal hosts, and the compounding effects of the same fixes on the virtual server. The biggest performance hits are to database servers and others with heavy file-Io. I also believe network IO is taking a hit in some cases. Thanks for making sure out Alexa/Google Home calls keep working! Sent from my iPhone using Tapatalk
  14. Sounds like specter and meltdown are to blame! Lol Sent from my iPhone using Tapatalk
  15. Thanks Benoit! Any chance you can make it so that the default on function for a fanlinc motor is “high”. If I tell Alexa to turn on the motor on a fanlinc, she replies without an error, but nothing happens to the motor. If I tell her to set it to 100%, it goes high. Sent from my iPhone using Tapatalk
  16. You might need to rediscover devices, maybe even forget and rediscover. Sent from my iPhone using Tapatalk
  17. cyberk replied to DrLumen's topic in ISY994
    Yes it is, using the network module and the REST interface. Obviously it has to be a parameter that is supported by the ZWave device. If you do a search for zwave parameter rest, you should find everything you need on the forums. Sent from my iPhone using Tapatalk
  18. I had a similar issue before, somehow the switches lost the route back to the PLM. A reset device from the ISY console should fix it, if not, try removing the device, reset the device locally, re-add to ISY. If all that fails, then yeah, switch could be bad. Sent from my iPhone using Tapatalk
  19. Is there a device type for fans in the new api? Sent from my iPhone using Tapatalk
  20. Great write up, I've been doing the same thing with Z-Wave multisensors. I didn't worry too much about placement of the sensors and instead focused on what the readings looks like at times I knew the exhaust should be on...like during baths and showers. Dew point is interesting for sure, I've looked at it in the past, may need to look at it again. Sent from my iPhone using Tapatalk
  21. I also have my exhaust fans turning on based on humidity levels. The humidity levels are taken from Zwave Multi-sensors. Sent from my iPhone using Tapatalk
  22. Although it did work at one point, Open/Close has apparently been reserved, an excluded from the Amazon Smart Home API. Last I checked, the only way to get Open/Close to work is to use the ISY skill by "Tell Izzy to open blah". This is old info, so I don't know if it's still accurate. Can you share what system you used to motorize those pocket doors? Sent from my iPhone using Tapatalk
  23. cyberk replied to G W's topic in Amazon Echo
    Nice! The drop in feature was advertised on the "echo show" for Video, makes sense it would get added for voice only. On the Show, I believe it was advertised that you could "drop in" on any of your friends/family. I guess I'll be able to test as soon as my echo shows get here Sent from my iPhone using Tapatalk
  24. cyberk replied to MWareman's topic in Google Home
    Great news from Apple, they're taking the connected home business a little more seriously now. Sent from my iPhone using Tapatalk
