zmarty
  1. I keep seeing this dialog when working with Z-Wave (not Insteon!) devices:
  2. I am unhappy to report that now I cannot add my Bali Spring Fashions Autoview mini remotes. They used to work just fine with the previous version through the ZMatter board. Now I can remove them from the network but never add them back. Ok I went and found the log. Removing the remote Sat 12/17/2022 01:41:16 PM : Z-Wave Listening for Z-Wave devices to remove from the network Sat 12/17/2022 01:41:21 PM : Z-Wave Z-Wave device detected, start removing from network Sat 12/17/2022 01:41:21 PM : Z-Wave Z-Wave device removed Sat 12/17/2022 01:41:21 PM : Z-Wave Idle Sat 12/17/2022 01:41:21 PM : Z-Wave Idle Adding the remote Sat 12/17/2022 01:41:28 PM : ---- Start Adding Devices - S2 Standard --- Sat 12/17/2022 01:41:28 PM : [ZWAVE-INCL-S2STD] Start Include S2 Standard highpower=true Sat 12/17/2022 01:41:28 PM : [ZWAVE-INCL-S2STD] Added 'CommandAdded' callback 0x802be7468 Sat 12/17/2022 01:41:28 PM : Z-Wave Listening for Z-Wave devices to add to the network Sat 12/17/2022 01:41:35 PM : Z-Wave Z-Wave device detected, start adding to network Sat 12/17/2022 01:41:35 PM : Z-Wave Z-Wave device detected, retrieving info Sat 12/17/2022 01:41:35 PM : Z-Wave Z-Wave device added Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x20 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x59 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x5A Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x5B Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x5E Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x72 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x73 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x80 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x84 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x85 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x86 Sat 12/17/2022 01:41:35 PM : [ZWAVE-INCL-S2STD] 'CommandAdded' callback: ccId=0x26 Sat 12/17/2022 01:41:35 PM : Z-Wave Idle Sat 12/17/2022 01:41:35 PM : Z-Wave Idle Sat 12/17/2022 01:41:35 PM : Z-Wave Idle Sat 12/17/2022 01:41:39 PM : [Device 12] Waiting on interview complete (374 ticks remaining) Sat 12/17/2022 01:41:41 PM : [Device 12] All interviews are done Sat 12/17/2022 01:41:41 PM : ZWAVE-WORKQ-34 Queue sync device 12 Sat 12/17/2022 01:41:41 PM : ZWAVE-WORKQ-34 Start sync device 12 Sat 12/17/2022 01:41:41 PM : [ZWAVE-SYNC 12] Device mismatch, Removing all existing ISY files/objects for Z-Wave device Sat 12/17/2022 01:41:41 PM : [SYNC-DEVICE 12.0] Set commands will now be accepted by the controller Sat 12/17/2022 01:41:41 PM : [ZWAVE-SYNC 12] Not multichannel Sat 12/17/2022 01:41:41 PM : ZWAVE-WORKQ-34 Finished sync device 12
  3. I have UD Mobile version 0.177 on Android. Should this fail with ZMater and v5.5.0?
  4. FYI: I had a Z-Wave network working just fine with the ZMatter board and v5.4.5, but when I upgraded to v5.5.0 through SSH my Z-Wave devices stopped working (nodes visible, but no status update and no action happened for on/off etc). I then went and pressed the move to ZMatter button as per instructions, which then happily went on and nuked my Z-Wave network. Nobody thought of my corner case and I guess the assumption was that everybody had this Zooz dongle. I didn't. Good thing I only had <10 devices moved over.
  5. I don't have a dongle at all, just the ZMatter board. Maybe they mean that in the next update ZMatter will get prioritized if you also have the dongle? I don't know, I'm lost.
  6. From the latest mail: "All this said, we are going to spend the weekend and Monday to finalize migration/routing, with or without which we’ll release a version on Tuesday the 13th. This way, those who do not need migration can start playing and enjoying ZMatter while we fix migration or SiLabs comes up with an updated firmware." Now I am really scratching my head on this one. Was I supposed to NOT be using the board yet all this time? I am using it just fine in a brand new Z-Wave network.
  7. Thanks. I think this works. However, does this turn the scene into a one command scene, compared to a scene that can accept both On and Off? I was hoping to create a single virtual blind that controls both.
  8. You mean this? Individual Blinds Scene with both
  9. This is the only related reply I found on this forum about a similar problem:
  10. I don't know if this is a ZMatter specific issue since I don't have much experience with previous UDI Z-Wave solutions. I am using Polisy Pro + the ZMatter board in a brand new Z-Wave network. I have two Bali Z-Wave blinds side by side in the same room. I want to group them in a Z-Wave scene so that I can control them at the same time. Both blinds show up as Class C Motor Control. ISY can control both blinds just fine individually (On, Off work as expected), but when I group them in a Z-Wave scene and hit On, the only both open half way (exactly 50%). What am I doing wrong? Thanks!
  11. Sadly the GE Enbrighten Z-Wave ones are garbage. 3 of mine already failed. I regret putting them in all over the house. No idea how they have decent reviews.
  12. zmarty started following Michel Kohanim
  13. Unfortunately, this is my main request And the question I posed originally on this thread, which is fast going off topic.
  14. New smart home standard Matter is finally officially official with 190 certified devices https://www.androidpolice.com/matter-official-amsterdam-launch-event/ Maybe @Michel Kohanim knows?
  15. I would like for other Matter devices to see my Insteon lights as Matter, can Polisy + ZMatter do that? Bonus question: If yes, what about X-way light switches?
  16. I don't get how that would solve my problem. My query to set lights brightness to X% would still affect both the real lights and the blinds that are exposed as "lights". Google added a separate device type for shades/blinds in their Google Home API earlier this year. It would be great if Universal Devices team would add support for it.
