Everything posted by photogeek54
Introducing eisy-ai !!!
FYI here's some stats on token usage for the development of a plugin The SolarEdge MB plugin (plugin 25, version 1.5.0) has 1,902 lines of Python in its top-level modules. Its tests add another 1,170 lines. Totals for the entire development session (all but the last 2 turns were with pre v2.4 eisy-ai before the major efficiency improvements): Session stats (claude-sonnet-5-5) /session-stats session totals: 47 requests, 6,706,896 input (85% read from cache), 965,037 written 1h / 0 written 5m, 389,131 output, ~$8.92 Compactions: 7 recorded; latest (fork) ~21,034 -> ~3,954 tokens Mid-turn over-budget events: 10 (latest at round 10, ~226,130 tokens) Totals for the final version update which took 2 turns (from anthropic billing site): describing the changes: input tokens 158k, output tokens : 95 generating the updated code and installing: input tokens: 1.39M, output tokens 94.6K sonnet 5.5 costs: cache Read $0.10 / MTok cache Write $2.50 / MTok Input $2 / MTok Output $10 / MTok
Look out humanity the AIs are winning 😝
Eisy-UI usability Suggestions
After working on several plugins and Programs the last week I have some suggestions to make the UI more efficient: Is there any way to specify more compact rows in programs, nodes and variables, they take so much more screen real estate than in admin console When is the new more flexible widgets/main page coming that was shown at the roadmap webinar? I'd like to be able to see and set valiables on the main page not just nodes in tiles. maybe that will allow this? When you go back into the node selector while editing a program, it should remember what node you closed the selector on in a previous edit so you don't have so many lines to go past to find the correct node. also it could open at the node you last selected Would be nice when in sub-windows like the property selector window and edit variable window, if the window could be moved with the mouse so you can see see what's behind it. When viewing nodes and scrolling in eisy-ui you have to use the side scroll bar, normally the center wheel on my mouse allows scrolling It would be helpful to be able to replace things like ${var.2.138} and ${sys.node.ZY081_118.CLITEMP} in the notifcation templates with friendlier names they have in programs. Allow sorting the notification templates into alphabetical order. It would be helpful when using the search function in programs that it would also search inside the programs so I can find who uses what variables. It would be helpful to have an option to keep the 3 bar (hamburger icon?) main menu open all the time which avoids having to use the mouse to find the menu every time. or at least a keyboard shortcut or open it when you hover over something on the left side. I'm anxious to hear other's thoughts.
HOW TO ADD FILE UPLOAD TO A PLUGIN IN EISY-AI My Solaredge Modbus plugin needs to read a complex json file. The version in the store had this functionality Custom Typed Configuration ParametersZIP File UploadThis will upload the zip file and extract it to the "data" directory of the plugin. Please see plugin help for more details on file upload. and a "select file to upload" button here I've asked eisy-ai to add this same functionality to my plugin but it doesn't seem to know how. Any suggestions how I get eisy-AI to add this?
Do we have control over the context window? Does it need to be a certain size to handle most development tasks? Is 20000 the correct number to put in the json? Any other suggestions?
Token usage is shown if you purchased your own tokens. I bought Claude tokens so I can get working but understanding how to keep it cost effective would be very important. Cost me $15 for a very simple fix of an error eisy-ai made. Seems like each time you give eisy-ai a developer command it might have to re-send every file in a plugin plus info on all your programs/devices/variables. That’s a lot. I asked eisy-ai about ways to conserve tokens but mostly it gave suggestions that would be useful to eisy-ai itself.
Looking for ways to lower the cost if I get my own Claude developers account. Do it not work?
The json says history_token_budget is 20000. You said mine was 500k? Should I change something? I’m thinking of using haiku 5.5.
Michel said I had used up my API allocation so I’m investigating the API options available. Are there any statistics on how large the context windows are on typical eisy-ai tasks? Are there favorite models for cost conscious users? Are there examples of prompts that minimize token usage? I’ve been reading about the most productive ways to use LLM APIs since I’ve only been a casual chat type user up until now. I was surprised to learn that the LLM sends all the input and output information from a full session in each subsequent turn (each command you give). I’m wondering if EISY-AI uses any techniques to minimize token usage. such as model routing, more frequent compaction, caching, flex service tier.
Same here
Still having problems with Ecobee climate programs
Thanks for your help Jimbo, Here's what I'm now seeing. I cleared the contents of every heat and cool setpoint in the comfort settings. I restart homekit and then ecobee. The heat and cool setpoints are still clear. I click "save" under the comfort settings and all the heat and cool setpoints suddenly fill in but they don't match those stored in the ecobee setpoints. I have the comfort settings as shown below home is correct. Away has the sleep setpoints, sleep has the away setpoints,wakeup has setpoints that are not in any of mine, I don't use smart2 but it filled in with some values, hotDay filled in with values I don't use. If I go to the ecobee node and choose the away comfort setting the ecobee shows away 67 which is correct.. if I select sleep it shows 68 which is correct, I select home and I get 73 which is correct. So far so good! I select wakeup and the ecobee shows holding 73 not 71 and the node shows sleep 79, both incorrect. I choose retiring and the ecobee still shows 73 holding not 71, the node shows sleep 71 still seems to have problems. I hope all this detail helps
Lots of eiay-ai sucess! Yesterday ai helped me create a solaredge cloud/API based plugin that works around many of the new limitations of the new v2 API. We also created a plugin for my Hyundai Ionic 5 which show its charging status, climate status and windows/doors status and it accepts commands. Today we completed a plugin for the solaredge which connects locally via ethernet using the modbusTCP protocol and avoids all the new API limits and can be polled every few seconds rather than every 15 minutes. I never got the modbusTCP plugin in the store to work so I had eisy-ai build its own. The issues with the context window overflow are now gone! A suggestion: ai needs to be able to read and modify notification templates. With the new plugins I am faced with finding and replacing lots of ugly old node and variable definitions with new ones. seems like the perfect job for AI.
Ring drone and rover cams with my SolarEdge setup —
How do you connect your solaredge monitoring to Universal devices? I ask because solaredge just deprecated their v1 API and put limits on their free monitoring. I don’t have ring cameras but do have several Dahua cameras connected to my eisy.
Clock on top bar of Eisy UI
I agree
solaredge plugin shutdown today by the company
If your code uses modbusTCP to access a solaredge inverter then absolutely , I'd love to see it. I've put examples of the problem I'm seeing in the modbusTCP forum. Thanks
@Jimbo.Automates I've loaded the latest homekit and ecobee 4.2. I've read the latest readme but still can't explain the behavior I'm seeing. I blanked out the heat and cool setpoints in the configuration for home, away and sleep. I set the display name for smart1-6 to my custom names and the heat and cool setpoints to what they are set to in the ecobee schedule page I then restart homekit and then restart ecobee. I looked in the debug log to see if it read my configurations correctly. The log shows comfort home heat set to 73 in one place which is correct 2026-11-08 17:35:50.214 Thread-32 (handler_typed_data) udi_interface.custom DEBUG custom:load: CUSTOM: load {'climate_programs': [{'thermostat_id': '532526877380', 'name': 'Main', 'device_id': '5d:1a:eb:a5:3c:3e', 'climates': [{'climateRef': 'home', 'name': 'Home', 'heat': '73.0', 'cool': '78.0'}, {'climateRef': 'away', 'name': 'Away', 'heat': '68.0', 'cool': '75.0'}, {'climateRef': 'sleep', 'name': 'Sleep', 'heat': '67.0', 'cool': '82.0'}, {'climateRef': 'smart1', 'name': 'Wakeup', 'heat': '71', 'cool': '78'}, {'climateRef': 'smart2', 'name': 'Smart2', 'heat': '68.0', 'cool': '75.0'}, {'climateRef': 'smart3', 'name': 'HotDay', 'heat': '60', 'cool': '73'}, {'climateRef': 'smart4', 'name': 'Retiring', 'heat': '71.0', 'cool': '78.0'}, {'climateRef': 'smart5', 'name': 'EnergySave', 'heat': '60', 'cool': '82'}, {'climateRef': 'smart6', 'name': 'PreCool', 'heat': '45.0', 'cool': '66.0'}, {'climateRef': 'smart7', 'name': 'Smart7'}]}], 'hk_id_overrides': [], 'hk_sensor_overrides': []} 2026-11-08 17:35:50.214 MQTT udi_interface.interface INFO interface:_message: Successfully set rs_mbr :: GV1 to 1 UOM 25 but later it shows home heat set to 78 which is incorrect. now the ecobee configuration page that had blank setpoints is now filled in and shows heat set to 78 and the node itself in eisyui says heat set to 78 but the ecobee itself is set to away with setpoint 67 from me changing the comfort program manually about 30minutes ago. 2026-11-08 17:35:50.941 Thread-34 (handler_typed_data) udi_interface.custom DEBUG custom:load: CUSTOM: -- typed data {'climate_programs': [{'thermostat_id': '532526877380', 'name': 'Main', 'device_id': '5d:1a:eb:a5:3c:3e', 'climates': [{'climateRef': 'home', 'name': 'Home', 'heat': '78.0', 'cool': '81.0'}, {'climateRef': 'away', 'name': 'Away', 'heat': '68.0', 'cool': '75.0'}, {'climateRef': 'sleep', 'name': 'Sleep', 'heat': '67.0', 'cool': '82.0'}, {'climateRef': 'smart1', 'name': 'Wakeup', 'heat': '71', 'cool': '78'}, {'climateRef': 'smart2', 'name': 'Smart2', 'heat': '68.0', 'cool': '75.0'}, {'climateRef': 'smart3', 'name': 'HotDay', 'heat': '60', 'cool': '73'}, {'climateRef': 'smart4', 'name': 'Retiring', 'heat': '71.0', 'cool': '78.0'}, {'climateRef': 'smart5', 'name': 'EnergySave', 'heat': '60', 'cool': '82'}, {'climateRef': 'smart6', 'name': 'PreCool', 'heat': '45.0', 'cool': '66.0'}, {'climateRef': 'smart7', 'name': 'Smart7'}]}], 'hk_id_overrides': [], 'hk_sensor_overrides': []} now I use eisyui to set the comfort to sleep and the node and thermostat correctly change to 68 but the sleep heat label in the config says 67 like the away comfort setting now I use eisyui to set the comfort to wakeup and the node correctly changes to 71 but the ecobee is still showing 68 now I use eisyui to set the comfort to home and the node correctly changes to 73 and the ecobee correctly shows 73 now I use eisyui to set the comfort to retiring and the node correctly changes to 71 but the ecobee is still showing 73 and the climate type went to wakeup briefly on the node but then went back to home . I checked and I don't see any programs that could set the climate type to home. I appreciate all the work you are doing on these plugins! but I still can't seem to make it work correctly. If I'm misunderstanding how to use it correctly, please let me know. I've included the debug package too. Thanks, Ken Ecobee_11-8-2026_62658_PM.zip
Ecobee not communicating
Ignoring the eisy-ui issue My biggest problem remains how to set the comfort programs and have them stay in PG3. They keep resetting to smart1,2,3,4 etc. This seems to be a PG3 Ecobee issue
udi-poly-homekit-hub is running with mqtt_enable true, and its MQTT status is connected (hub GV1 = 2, bridge GV0 = 1). says homekit hub - connected mqtt transport - connected bridge status - running hub error code - no error node server online - connected Both sides use the same broker. Ecobee hk_mqtt_host / hk_mqtt_port (normally port 1884) must be the broker the hub is using. ecobee hk_mqtt_host - localhost ecobee hk_mqtt_port - 1884 those parameters not set in homekit hk_mqtt_hub_slug matches the hub mqtt_hub_slug (usually both default). A mismatch puts hello on a topic the hub never subscribes to. ecobee sets hk_mqtt_hub_slug to default not set in homekit hk_mqtt_client_slug is udi-poly-ecobee unless they intentionally set a unique slug. The hub answers on that same slug. in ecobee hk_mgtt_client_slug is udi-poly-ecobee Restart the HomeKit Hub node server first, then Ecobee, if both look configured and the count is still climbing. after I checked all above I looked at log again and the ack not received is no longer showing! Go figure. My biggest problem remains how to set the comfort programs and have them stay. They keep resetting to smart1,2,3,4 etc. Even though I can't view them currently after migrating the plugin to eisy-ui, I'm assuming they would get transferred there if I could set them in pg3 and them migrate?
The solaredge v2 API comes along with a new tiered price structure for monitoring. The free tier only allows 2000 credits per month which would only allow polling the inverter about once per hour. the next tier would allow polling every 15 minutes for $100/mo. This is worthless for my applications. I used eisy-ai to generate a v2 plugin but in addition to the limited polling with the free or even the $100/mo tier it is missing many of the previous fields My use of the mySolaredge app is also due to cease next May so I need to find a better way to poll the inverter. I am working on a plugin for local connection to the inverter via the built in wired ethernet port on my SE7600-H inverter.
how to upload modbus.iox_plugin.json in eisy-ui
I deleted the eisy-ui plugin and installed the pg3 version. There I can see the place to upload a .zip file that was missing in eisy-ui plugins. unfortunately I get an error when I start the pg3 plugin. 2026-11-07 17:25:51.014 MainThread iox_p_logger INFO plugin:validate_json: fastjsonschema does not currently support file references ... ignoring validation request.2026-11-07 17:25:51.014 MainThread iox_p_logger INFO plugin:validate_json: fastjsonschema does not currently support file references ... ignoring validation request. 2026-11-07 17:25:51.014 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b9026068_30.cert key: 0021b9026068_30.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2026-11-07 17:25:51.014 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b9026068_30.cert key: 0021b9026068_30.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2026-11-07 17:25:51.014 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2026-11-07 17:25:51.014 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2026-11-07 17:25:51.015 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026068_30/modbus.py", line 40, in <module> 2026-11-07 17:25:51.015 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9026068_30/modbus.py", line 40, in <module> 2026-11-07 17:25:51.015 MainThread udi_interface ERROR udi_interface:write: plugin = Plugin(PLUGIN_FILE_NAME) 2026-11-07 17:25:51.015 MainThread udi_interface ERROR udi_interface:write: plugin = Plugin(PLUGIN_FILE_NAME) here's my modbus.iox_plugin.json. any ideas? { "device": { "name": "SolarEdge SE7600H", "host": "10.10.1.49", "port": 1502, "unit_id": 1, "address_base": 0, "poll_interval_s": 10, "word_order": "big" }, "inverter": [ {"name": "sunspec_did", "address": 40069, "count": 1, "type": "uint16"}, {"name": "ac_current_a", "address": 40071, "count": 1, "type": "uint16", "scale_register": 40075}, {"name": "ac_voltage_an_v", "address": 40079, "count": 1, "type": "uint16", "scale_register": 40082}, {"name": "ac_power_w", "address": 40083, "count": 1, "type": "int16", "scale_register": 40084}, {"name": "ac_frequency_hz", "address": 40085, "count": 1, "type": "uint16", "scale_register": 40086}, {"name": "ac_apparent_va", "address": 40087, "count": 1, "type": "int16", "scale_register": 40088}, {"name": "ac_energy_wh", "address": 40093, "count": 2, "type": "uint32", "scale_register": 40095}, {"name": "dc_current_a", "address": 40096, "count": 1, "type": "uint16", "scale_register": 40097}, {"name": "dc_voltage_v", "address": 40098, "count": 1, "type": "uint16", "scale_register": 40099}, {"name": "dc_power_w", "address": 40100, "count": 1, "type": "int16", "scale_register": 40101}, {"name": "heatsink_temp_c", "address": 40103, "count": 1, "type": "int16", "scale_register": 40106}, {"name": "status", "address": 40107, "count": 1, "type": "uint16"}, {"name": "status_vendor", "address": 40108, "count": 1, "type": "uint16"} ], "meter1": [ {"name": "meter_did", "address": 40188, "count": 1, "type": "uint16"}, {"name": "meter_current_a", "address": 40190, "count": 1, "type": "int16", "scale_register": 40194}, {"name": "meter_voltage_an_v", "address": 40196, "count": 1, "type": "int16", "scale_register": 40203}, {"name": "meter_frequency_hz", "address": 40204, "count": 1, "type": "int16", "scale_register": 40205}, {"name": "meter_power_w", "address": 40206, "count": 1, "type": "int16", "scale_register": 40210}, {"name": "meter_power_a_w", "address": 40207, "count": 1, "type": "int16", "scale_register": 40210}, {"name": "meter_power_b_w", "address": 40208, "count": 1, "type": "int16", "scale_register": 40210}, {"name": "meter_apparent_va", "address": 40211, "count": 1, "type": "int16", "scale_register": 40215}, {"name": "meter_pf", "address": 40221, "count": 1, "type": "int16", "scale_register": 40225}, {"name": "grid_exported_wh", "address": 40226, "count": 2, "type": "uint32", "scale_register": 40242}, {"name": "grid_imported_wh", "address": 40234, "count": 2, "type": "uint32", "scale_register": 40242}, {"name": "meter_events", "address": 40293, "count": 2, "type": "uint32"} ] }
eisy-ai helped me generate a .json file for my soledge inverter but the documentation is no help explaining how to upload that file. do i add a custom configuration parameter? do I use the "files" tab?
also i'm seeing this in the log: mqtt_client:_hello_retry_loop: HomeKit hub MQTT: hello ack not received yet; retrying hello (16). could this have anything to do with my lost climate program labels?
Here's some more feedback on eisy-ai: when setting a variable to a state variable value in eisy-ui the state variables are not sorted alphabetically so they are hard to find Many times when eiasy-ai describes a program in the chat it calls it somethiung like "program 360" rather than its friendly name, also may do this with variable names some times Ai still puts text in white on white boxes In one case ai asked me "I need to know whether the host has the Python modules for an offline test, and what the plugin's small docs files say". don't have a clue what that means Ai doesnt seem to like eisy programs that don't do meaningful work in the then or else parts. Since I can use the state of a program in other if statements I sometimes leave them blank I asked ai to review some of my eisy programs for issues. It is cool that AI reads the comments also and tries to check if my program logic matches the intent described in the comments I haven't figured out how to multiple lines in a chat window before sending the whole thing to ai Yesterday solaredge shut down the v1 API my plugin uses so I'm using ai to convert it to the v2 API, no results yet.
Much to my surprise, Solaredge shut down the V1 API today. I am investigating options to access the v2 API. So far it looks like free use of the new API will only allow much less frequent calls (maybe 1/hour) without paying $100+/mo for an upgraded rate plan. Stay tuned
Matter thread devices lost connections
Two times now I’ve had all of my matter thread devices ( 5 ikea devices and a Aqara lock) suddenly be disconnected and require resets and re-pairing to get them back on the network. I realize EISY and the Z matter are not a thread border router but act as a bridge to the matter network. I can’t come up with any explanation for this issue, so I’m just inquiring if anyone can think of any reason the EISY could cause this kind of an error.
