glacier991
Everything posted by glacier991
  1. I put in a ticket and the suggestion was to remove and reinstall the Yolink plug in. It was in slot 8, and I reinstalled it in slot 8. Is solved my issue as it recognized my purchase of 1.27 and reinstalled running that version.
  2. I have been successfully using EISY since its introduction and last spring added Yolink to my Polyglot, at that time to introduce their key fob. Worked without issue. Fast forward to yesterday. My Yolink setup has expanded considerably, but I had never felt a need to integrate any of that into EISY, so never checked the nodes or anything. Last night I decided to do that and saw that only my initial nodes were in existence, and also saw that there was an upgrade for purchase. I purchased the upgrade, it shows as purchased, but when I try and install it, nothing happens. I still show as running the old version, not the upgraded version. My credentials have not changed are still match up between those previously entered into the prior Yolink version in the configuration tab. Checking in the Yolink portion of PG3 does show my additional yolink devices. However, I do not see the new devices in EISY. Auto discover hasn't helped and I suspect I need to be running the upgraded version of the Yolink plug in and that's why. Not sure what my next steps are. Have restarted, rebooted and done all that, with no avail.
  3. Thanks..That is my choice for replacement leak detection if and when I get there. The rest of my CAO system I will keep..though I am increasingly using Yolink where it makes sense.
  4. I use wireless tag as my primary leak reporting sensor network ( 6 locations). Twice now in the past several weeks I have had events where all my wireless tag sensors report a leak simultaneously - and of course the water valve indeed turns the water off. Anyone else encounter this? Appears to perhaps be some kind of issue with the wireless tag manager. I guess I can just program around it, but it makes me rethink my continued use of wireless tag for this function.
  5. Fantastic. The sensor itself offers incredible possibilities, unmatched by mere motion sensors. I plan to explore this along with you. Question? In use how is the device latency? At the price, it is much cheaper than many motion sensors, but latency might be a key concern.
  6. My other option would be to wait until I have my Pi5 up and running and install (hopefully,) windows 11 on that - then see if I can get the AC to run on that OS..which as I understand it is ARM based.
  7. Recently I have experimenting with using a Pi based computer as a light duty general purpose computing platform. Obviously what I run is not app based, but usually cloud based ( like Microsoft 365, for example). For email and other light duty tasks it seems to be satisfactory. It may be a bridge too far, but I was curious whether there is a way to run the UD Administrative Console on a Pi. Currently I have a Pi 4 doing the work but plan on a Pi 5 based system with NVMe, so eventually it will be a little beefier.
  8. As I look at this a little closer, a couple things come to mind. First, the "policy" you reference makes sense to me. Second, I have online access to their stations dashboards anyway. (Seems to run contrary to policy?) Third. I am liking their product(s) and might seriously consider adding one. That said, I realize you are a node developer and not responsible for either 1 or 2. Or 3. Thanks for all your great work. Chris Have you ever considered writing a node for lacrosse weather stations. They have web access and a fairly deep market penetration. Sort of a "poor man's" Ambient Weather.
  9. My program looks something like this: IF Time is 12:20 AM (I have a bunch of things that happen around midnight so I decided to let things settle down) AND 'Time Data Ephemeris is / Time Data' Day of Month is 1 Day (In other words, the 1st. This is right in the drop downs in the programming tab) THEN: Whatever it is you want to accomplish on the wee hours of the 1st of the month. The program will only run at 12:20 on the 1st of any given month.
  10. I set up a real simple program using The TimeData node server in PG3x. I do a schedule in IF sometime just after midnight, with an AND IF which asks if (from TimeData) day of the month equals 1st If it runs, it ensconces my previous monthly total into a separate variable register, and cleans everything else to zero to start over. Super clean and easy. I knew TimeData would come in handy.
  11. Okay. All makes sense. Like I said, naive.🙃
  12. Well, after a little effort I managed to get the API key and get the plug in working. Now, color me naive, but I have used Ambient Weather, even though I do not own or operate any of their devices. Is that a requirement for this plugin to operate successfully ( turning my station or sensors into nodes?) Can I enter nearby stations somehow?
  13. I had not thought about this, but what if you could some how print out of the AC or Eisy itself!
  14. I have logged into my account and do not see anything like that. That includes through the frum and through the Universal devices website. I do not doubt you, I guess I just an not coming through the right door. May need a little more detail in how to get there.
  15. The joys of node servers and PGX(3) is that you get "outside data" into EISY to use in programming, triggering, etc. The next logical question is how do you get the results of some of that data needed elsewhere after EISY, back to the "outside cyber world"? I have seen a few suggestions, and decided to start a thread to address how folks are doing just that. How do you get data inside Eisy (like, as an example, from an integer variable) to programs outside EISY?
  16. Interested, can you tell more about the ability to post to a "Google sheet? Getting data outside EISY where it can be otherwise used and manipulated seems possible, but elusive. This sounds intriguing. So much so I am wondering is a separate topic addressing just that might be appropriate and welcomed! (From besides me.)
  17. Just signed up a while ago for Ambient Weather and finally getting back to it. Not sure where I obtain the API key, which it wants.
  18. So far it seems I spend my time trying to get data INTO EISY, now flipping the coin trying to figure out how to get data OUT of it ! Keeping the old brain young.
  19. Definitely interested. Interestingly the Yolink thermometers keep their data for months or longer, and enable downloading it in comma delimited format for your stated date range. Not applicable in my situation, but interesting.
  20. Whew. That means I am safe, for now.😉 On another matter, I followed your suggestion for creating a monthly register. For the total I approached it a little differently. On a daily basis I add the current day value to a variable I call Cumulative DD. I increment a counter at the same time. When the counter reaches 30 (or 31 depending on the month) following that days addition I move the Cumulative DD value into a state variable. Ka-ching.. I just saved 29 variables from a fate worse than math.
  21. Is there any numeric limit on the number of variables Eisy can have (and support)?
  22. I did a previous post in which I learned how to get custom messages into the Yo link Speaker hub via Eisy and PG3x config. Worked fine, and appreciated the help. Now I am interested in doing the same thing with audio (MP3) files. The solution is not intuitively obvious to me. Can it be done? I know I can do it in the Yo link app, but that doesn't work for programming in Eisy.
  23. Larry thanks. I suspected this would be a "brute force" solution kind of task. I had set up a weeks worth of defined integer variables for the test. Is something like that what you are referring to a block of memory locations?
  24. Okay.... I am working on program which will, each day, produce a mathematical result measured in terms of a variable (to be explicit, degree days, stored in an integer variable by the same name). I would like to store those in a way that would let me later compile a total for a stated time period.. (again to be explicit from march 1 until a specified total number is reached.... basically from mar 1 until June 30) Has anyone tackled something like this? I am eyeing the TimeDate plug in as a part of the solution, but before I go searching for a champagne solution to a beer project thought I might solicit views on this problem. Thank for looking and I solicit any and all thoughts...
  25. Thanks, my suspicions are no longer just suspicions!
