lgilsenberg started following Insteon Dimmer Outlet 2472DLAL , How To: Automate a bathroom exhaust fan based on room humidity , Alexa and EISY - random lights on and 3 others
I noticed that three lights came on at random times. I have been able to remedy this by removing the spoken name for each of those devices. The rest of the house (a lot of devices) are still working flawlessly. When I reconnect with a spoken name, the devices will randomly turn on again. Dopes anybody have a suggestion other than keep the spoken name off? Thank you.
Curious about I/O Error: ProxyDevice
Thank you, I thought my system might be corrupted. I appreciate the insight.
I was doing some work in the admin console and left for a while. When I came back, I saw this error. This is the second time it has happened. Does anybody have any insight into it? Thanx
Insteon Motion Sensor V1 Messing Up
Thank you @paulbates. The restore after the factory wipe did the trick.
I have the 4814 Rev 2.6 Insteon Motion Sensor which has been working fine for many years. Recently it has not been accepting scene modifications, so I tried viewing the links table to compare it to the PLM. I got the following error: I tried removing the device and got this error: Is it time to scrap it and buy a new motion sensor or is there a fix? I tried a factory reset and that did not help. If it is time to get a new motion sensor, any recommendations?
@larryllix You nailed it. It was a 0 that looked like an 8. Thank you @Brian H and @paulbates
I've been trying to add the Insteon Dimmer Outlet 2472DLAL to the EISY and keep getting the message "Cannot determine Insteon engine". Any suggestions on getting it to work?
Program Logic Assist Pls
I would likely write it like this just for clarity North Gate OPEN - [ID 0019][Parent 0031] If ( 'Main House / Sensors / North Gate' is switched On Or 'Main House / Sensors / ZY 033 North_Gate' Access Control is Window/door is open ) And $Gates_ProgON is 0 Then $North_Gate_Open = 1 Run Program '_North Gate' (If) Else - No Actions - (To add one, press 'Action')
lgilsenberg started following Current Release Announcements
lgilsenberg started following Change EISY Admin Console Timeout
Is there a way to change the time allowed before the Admin Console times out?
Can no longer delete old scenes within Alexa.
I found an alternative way to delete scenes in the Alexa app . . . You would need to add the scene to a Group, then delete it from there. Open the Alexa App. Select Devices, then select a Group and hit "Edit" in the top right corner. Scroll all the way down and add these extra Scenes to the Group and save. While looking at the Group, scroll down and tap on the Scene and then you'll see the trash can icon to delete it. Not elegant, but it works
Scene On Levels ignored when scene activated by keypad button
In version 4.x, I believe there was a checkbox in the scene that would "Apply changes to all devices" and copy the attributes to controllers [on page 103 in the Cookbook]. Was that capability removed in v5.x?
Error Log is filling up
@Geddy I did change the network configuration, swapping from one wireless router to another. I just turned off port forwarding and everything has quieted down. I appreciate the guidance. @Techman I would have opened a ticket, but I'm still on 994 until the ZWave and Matter board are back in stock.
Just a bump. Does anybody have any suggestions on how to get rid of the errors popping up in the log? Is this somebody trying to hack me or did I mess up the network configuration or ?????
Below is my error log from today. Am I being hacked or just being stupid? Any thoughts on how to clean it up? Sun 2023/11/05 01:16:07 AM System -5011 uuid:0 Sun 2023/11/05 01:46:18 AM System -170001 [Auth:-10104] 68.69.185.50:50950->80, Num=7 Sun 2023/11/05 01:46:18 AM System -10108 Check log Sun 2023/11/05 01:49:06 AM System -170001 [Auth:-10104] 2.57.122.233:51112->80, Num=8 Sun 2023/11/05 01:49:06 AM System -10108 Check log Sun 2023/11/05 01:00:07 AM System -7123 ID 000F :err=0, tag='status', num=44, nest=4, o Sun 2023/11/05 01:00:07 AM System -7115 ID 0022 :err=0, tag='cmd', num=4, nest=4, offse Sun 2023/11/05 01:00:08 AM System -7115 ID 0034 :err=0, tag='cmd', num=4, nest=4, offse Sun 2023/11/05 01:00:10 AM System -7115 ID 0096 :err=0, tag='cmd', num=4, nest=4, offse Sun 2023/11/05 01:00:11 AM System -7123 ID 00AB :err=0, tag='status', num=44, nest=4, o Sun 2023/11/05 01:00:11 AM System -7123 ID 00BA :err=0, tag='status', num=44, nest=4, o Sun 2023/11/05 01:39:34 AM System -170001 [Auth:-10104] 64.226.98.14:43958->80, Num=9 Sun 2023/11/05 01:39:34 AM System -10108 Check log Sun 2023/11/05 01:39:37 AM System -170001 [Auth:-10104] 64.226.98.14:43962->80, Num=10 Sun 2023/11/05 01:39:37 AM System -10108 Check log Sun 2023/11/05 02:05:22 AM System -170001 [Auth:-10104] 184.105.139.70:16952->443, Num=1 Sun 2023/11/05 02:05:22 AM System -10108 Check log Sun 2023/11/05 02:05:51 AM System -170001 [Auth:-10104] 184.105.139.70:34834->443, Num=1 Sun 2023/11/05 02:05:51 AM System -10108 Check log Sun 2023/11/05 02:16:05 AM System -5011 uuid:0 Sun 2023/11/05 03:22:36 AM System -170001 [Auth:-10104] 107.175.212.32:49180->80, Num=13 Sun 2023/11/05 03:22:36 AM System -10108 Check log Sun 2023/11/05 04:16:06 AM System -5011 uuid:0 Sun 2023/11/05 04:37:14 AM System -170001 [Auth:-10104] 209.201.15.190:38322->80, Num=14 Sun 2023/11/05 04:37:14 AM System -10108 Check log Sun 2023/11/05 04:37:14 AM System -170001 [Auth:-10104] 209.201.15.190:38354->80, Num=15 Sun 2023/11/05 04:37:14 AM System -10108 Check log Sun 2023/11/05 05:20:02 AM System -170001 [Auth:-10104] 192.241.236.81:39558->443, Num=1 Sun 2023/11/05 05:20:02 AM System -10108 Check log Sun 2023/11/05 06:16:07 AM System -5011 uuid:0 Sun 2023/11/05 06:17:43 AM System -170001 [Auth:-10104] 34.78.54.63:38046->443, Num=17 Sun 2023/11/05 06:17:43 AM System -10108 Check log Sun 2023/11/05 07:40:49 AM System -170001 [Auth:-10104] 69.162.243.124:60896->80, Num=18 Sun 2023/11/05 07:40:49 AM System -10108 Check log Sun 2023/11/05 07:40:49 AM System -170001 [Auth:-10104] 69.162.243.124:60914->80, Num=19 Sun 2023/11/05 07:40:49 AM System -10108 Check log Sun 2023/11/05 07:42:08 AM System -170001 [Auth:-10104] 147.78.103.170:60019->80, Num=20 Sun 2023/11/05 07:42:08 AM System -10108 Check log Sun 2023/11/05 07:42:08 AM System -170001 [Auth:-10104] 147.78.103.170:60019->80, Num=21 Sun 2023/11/05 07:42:08 AM System -10108 Check log Sun 2023/11/05 07:42:08 AM System -170001 [Auth:-10104] 147.78.103.170:60019->80, Num=22 Sun 2023/11/05 07:42:08 AM System -10108 Check log Sun 2023/11/05 07:42:09 AM System -170001 [Auth:-10104] 147.78.103.170:60954->80, Num=23 Sun 2023/11/05 07:42:09 AM System -10108 Check log Sun 2023/11/05 07:42:10 AM System -170001 [Auth:-10104] 147.78.103.170:61570->80, Num=24 Sun 2023/11/05 07:42:10 AM System -10108 Check log Sun 2023/11/05 07:42:10 AM System -170001 [Auth:-10104] 147.78.103.170:62189->80, Num=25 Sun 2023/11/05 07:42:10 AM System -10108 Check log Sun 2023/11/05 07:42:10 AM System -170001 [Auth:-10104] 147.78.103.170:62189->80, Num=26 Sun 2023/11/05 07:42:10 AM System -10108 Check log Sun 2023/11/05 07:42:11 AM System -170001 [Auth:-10104] 147.78.103.170:62189->80, Num=27 Sun 2023/11/05 07:42:11 AM System -10108 Check log Sun 2023/11/05 07:42:11 AM System -170001 [Auth:-10104] 147.78.103.170:62189->80, Num=28 Sun 2023/11/05 07:42:11 AM System -10108 Check log Sun 2023/11/05 07:42:11 AM System -170001 [Auth:-10104] 147.78.103.170:62189->80, Num=29 Sun 2023/11/05 07:42:11 AM System -10108 Check log Sun 2023/11/05 07:42:11 AM System -170001 [Auth:-10104] 147.78.103.170:62189->80, Num=30 Sun 2023/11/05 07:42:11 AM System -10108 Check log Sun 2023/11/05 07:42:11 AM System -170001 [Auth:-10104] 147.78.103.170:62189->80, Num=31 Sun 2023/11/05 07:42:11 AM System -10108 Check log Sun 2023/11/05 07:51:30 AM System -170001 [Auth:-10104] 94.142.138.104:45722->443, Num=3 Sun 2023/11/05 07:51:30 AM System -10108 Check log Sun 2023/11/05 07:51:46 AM System -170001 [Auth:-10104] 94.142.138.104:44362->443, Num=3 Sun 2023/11/05 07:51:46 AM System -10108 Check log Sun 2023/11/05 08:16:07 AM System -5011 uuid:0 Sun 2023/11/05 09:56:46 AM System -170001 [Auth:-10104] 164.92.232.89:53526->443, Num=34 Sun 2023/11/05 09:56:46 AM System -10108 Check log Sun 2023/11/05 09:56:49 AM System -170001 [Auth:-10104] 164.92.232.89:56792->443, Num=35 Sun 2023/11/05 09:56:49 AM System -10108 Check log Sun 2023/11/05 10:16:08 AM System -5011 uuid:0 Sun 2023/11/05 10:57:38 AM System -7123 ID 000F :err=0, tag='status', num=44, nest=4, o Sun 2023/11/05 10:57:38 AM System -7115 ID 0022 :err=0, tag='cmd', num=4, nest=4, offse Sun 2023/11/05 10:57:39 AM System -7115 ID 0034 :err=0, tag='cmd', num=4, nest=4, offse Sun 2023/11/05 10:57:41 AM System -7115 ID 0096 :err=0, tag='cmd', num=4, nest=4, offse Sun 2023/11/05 10:57:42 AM System -7123 ID 00AB :err=0, tag='status', num=44, nest=4, o Sun 2023/11/05 10:57:42 AM System -7123 ID 00BA :err=0, tag='status', num=44, nest=4, o Sun 2023/11/05 12:01:09 PM System -170001 [Auth:-10104] 78.153.140.221:32814->80, Num=36 Sun 2023/11/05 12:01:09 PM System -10108 Check log Sun 2023/11/05 12:16:03 PM System -5011 uuid:0 Sun 2023/11/05 01:00:49 PM System -170001 [Auth:-10104] 83.97.73.87:43642->80, Num=37 Sun 2023/11/05 01:00:49 PM System -10108 Check log Sun 2023/11/05 02:16:03 PM System -5011 uuid:0 Sun 2023/11/05 03:05:01 PM System -170001 [Auth:-10104] 83.97.73.87:41304->80, Num=38 Sun 2023/11/05 03:05:01 PM System -10108 Check log Sun 2023/11/05 04:11:01 PM System -170001 [Auth:-10104] 107.170.253.36:49884->80, Num=39 Sun 2023/11/05 04:11:01 PM System -10108 Check log Sun 2023/11/05 04:16:03 PM System -5011 uuid:0 Sun 2023/11/05 04:29:28 PM System -170001 [Auth:-10104] 207.154.194.231:34266->443, Num= Sun 2023/11/05 04:29:28 PM System -10108 Check log Sun 2023/11/05 04:29:30 PM System -170001 [Auth:-10104] 207.154.194.231:34278->443, Num= Sun 2023/11/05 04:29:30 PM System -10108 Check log Sun 2023/11/05 04:29:42 PM System -170001 [Auth:-10104] 207.154.194.231:52664->443, Num=
I hosed the network settings
paulbates, you are my hero. I'm back in the saddle. Thank you
lgilsenberg
Joined
Last visited
