4481hoods
Everything posted by 4481hoods
  1. 4481hoods replied to Panda88's topic in YoLink
    Receiving this error: --when I sync with UD Mobile I do get errors: yolink 1.6.2 0. Notify Node Server Dev!!! Status name is missing for : ST. Node Server Instance: 6 Anything to worry about. Everything seems to work fine??
  2. thank you worked
  3. Need command line to retrieve cong.txt from polisy. TY
  4. That explains it . TY
  5. Definitely not like yours. I'm using Polisy with a 700 stick.
  6. Don't see anything that says backup under the Zwav menu????
  7. Does z-wav get backed up in Polisy after Iox backup.
  8. Actually, it was not a big problem adding key and value. Once the problem was identified it was a very easy fix. Could the problem be remnants from the previous MQTT installation. I did try two ratgdos, thinking one was bad, installed in two different slots. neither did the trick. Things are working very well. Thank You
  9. Did this: Key: gdodevice Value: <ip address of ratgdo>;<Name of ratgdo modified as per the release notes> All works!!
  10. Could you send the value line. Ty. Got it! Thanks
  11. Getting the following error: "There was an error attempting to connect to the device at ratgdov25i-4b1a56.local. Please check the log files and correct the issue before restarting the plugin." ratgdo_6-15-2024_72340_PM.zip
  12. So the big question. Should you upgrade. If everything is working good. Should you take a chance and mess everything up. What are the benefits.
  13. Here is the log! ratgdo_6-9-2024_73351_AM.zip
  14. When I try to discover it pops up. It will not load the nodes in IOX. MQTT loads just fine and responds and reports the door status
  15. Ratgdo had been working fine. Did a reinstall and now I get this message: " A Discover or device command was attempted with no MQTT connection established. Wait for the plugin to establish a connection to the MQTT broker before attempting Discover or device commands."
  16. Sync option now located under network resources.
  17. Found nothing. Baffling.
  18. 4481hoods posted a topic in UD Mobile
    Unable to sync ud mobile, no option available.
  19. Seems like the portal is not working properly. Favorites are not responding. Anyone else seeing this?
  20. Well I have tried everything I can think of. ratgdo is the only spoken that behaves this way! What setting should I look for? I have a switch (Zoos) wired to a remote opener and it works perfectly, but I lose the open- close function that Ratgdo has. Any suggestions?
  21. Open/close seems to work fine when I am at home. If I leave say for work and return later "open"' does not work from my Alexa enabled Lincoln app on the first try. Seems like it takes two times to get the door to respond. I have tried several different things, and nothing seems to work. Close does not seem to be a problem! Any thoughts?
  22. 4481hoods posted a topic in ratgdo
    Should the ratgdo firmware be updated? Current is 2.57 ?? Any benefit?
