4481hoods
Everything posted by 4481hoods
  1. 4481hoods replied to 4481hoods's topic in Polisy
    ty
  2. 4481hoods posted a topic in Polisy
    What size is this SSD????
  3. 4481hoods posted a topic in Polisy
    What will be the advantages of upgrading? My polisy seems to be working just fine??
  4. 4481hoods posted a topic in Ecobee
    II it possible to setup Ecobee in UDI if I don't have any Apple devices. I have setup Homekit node but I am still confused. I need one of those for Dummies manuals really bad!
  5. Sent in a ticket! No response?
  6. Yes I am on the latest firmware.
  7. I have synced several times. Not solving problem.
  8. Device Properties / Commands are not reading correctly on Mobile App. Some examples: DON FOR ON DOF FOR OFF FDUP FOR FADE UP FDDOWN FOR FADE DOWM ETC. ETC
  9. 4481hoods replied to Panda88's topic in YoLink
    Receiving this error: --when I sync with UD Mobile I do get errors: yolink 1.6.2 0. Notify Node Server Dev!!! Status name is missing for : ST. Node Server Instance: 6 Anything to worry about. Everything seems to work fine??
  10. thank you worked
  11. Need command line to retrieve cong.txt from polisy. TY
  12. That explains it . TY
  13. Definitely not like yours. I'm using Polisy with a 700 stick.
  14. Don't see anything that says backup under the Zwav menu????
  15. Does z-wav get backed up in Polisy after Iox backup.
  16. Actually, it was not a big problem adding key and value. Once the problem was identified it was a very easy fix. Could the problem be remnants from the previous MQTT installation. I did try two ratgdos, thinking one was bad, installed in two different slots. neither did the trick. Things are working very well. Thank You
  17. Did this: Key: gdodevice Value: <ip address of ratgdo>;<Name of ratgdo modified as per the release notes> All works!!
  18. Could you send the value line. Ty. Got it! Thanks
  19. Getting the following error: "There was an error attempting to connect to the device at ratgdov25i-4b1a56.local. Please check the log files and correct the issue before restarting the plugin." ratgdo_6-15-2024_72340_PM.zip
  20. So the big question. Should you upgrade. If everything is working good. Should you take a chance and mess everything up. What are the benefits.
  21. Here is the log! ratgdo_6-9-2024_73351_AM.zip
  22. When I try to discover it pops up. It will not load the nodes in IOX. MQTT loads just fine and responds and reports the door status
  23. Ratgdo had been working fine. Did a reinstall and now I get this message: " A Discover or device command was attempted with no MQTT connection established. Wait for the plugin to establish a connection to the MQTT broker before attempting Discover or device commands."
