RemoteLinc
I have a Remotelinc that is 3 to 4 years old and has always been very temperamental about going into linking mode so I can program it. I've always just tried a several times and it would eventually work.
But tonight after replacing PLM, I can't get the d%^& thing to talk to ISY. Are there any tricks others have discovered? I placed it near an access point that just flawlessly updated two other Remotelincs.
Using the Dim/Bright buttons to put RemoteLinc into linking mode?
Only thought I have is try a new set of batteries.
Lee. Yes I'm using dim& bright and have Replaced batteries.
Hello hart2hart,
Do you have any of those old SignaLincs?
And, how far are you from the nearest dual band device, access point, or PLM?
And, finally, when you click the button on the RL do you see any of the LEDs on those devices blink?
Michel:
I was luck and never purchased any of the SignalLincs.
I've tried distances from 6 inches to 20 feet.
Yes, accesspoints show activity with remotelinc. In fact, even after mutiple factory resets the all lights on and off buttons still control lights in that room but the individual buttons do not work.
As I mentioned, this particular RL has always been tempermental but within 10 minutes I could get it to communicate. It is more like that even though I press and hold buttons until it blinks to say in linking mode -- it is not in linking mode.
I'll just buy replacement if I can find one. My wife hates the RemoteLinc2 and I was not impressed either.
Paul
It just worked. Go figure.
