ISY Finder Error
I was hoping to do a little work on my ISY programs on my laptop this evening but I cannot get the console to open.
Whenever I try to open the Admin Console, I get a 'Not Found' error in the ISY Finder. I updated my Java version (v7.21), cleared the cache and used the jnlp links from this site. NADA.
Oddly, I can find the console from my desktop computer, and I can access the ISY from my android phone. For some reason, I can't get my laptop to find it. Anybody have suggestions on what I am missing?
Edit: Correction, I can no longer access the ISY from my desktop. I checked the ISY and the blue and red leds were blinking. I rebooted the ISY and it seems as soon as the thing resets, it reverts back to the blue and red blink. I assume red can't be good.
So I can't access it for control. And it looks like some sort of malfunction. However the programs that are in it seem to execute. Hmmm.
Hello sanders2222,
This means that ISY has a hard time getting on the network. Two causes:
1. Communications with the router including the cable and the possibility that the router is not letting ISY get an IP address
2. If you have setup your ISY with a static IP address, then the issue is probably IP conflict with something else
1. Communications with the router including the cable . . . is not letting ISY get an IP address
That was it. I discovered the network cable fitting was a bit worn. Consequently, it could not 'click' into its proper place. I think as I unplugged the power source with one of my re-boots, I moved the network cable just enough to loose the connection. DUH!
A new cable fixed that problem. Thanks Michel for the quick and correct answer to solving my issue.
  • 1 year later...
I am facing the same problem. What's the best solution to fix this?
You have the same problem sanders2222 had back in April 2013, a bad internet cable that would not lock in connector?   Use a new cable.
I suspect that is not your issue.  Are there LEDs besides the Power LED On the face of the ISY On?
