Why would I get a notification if the Then should not run?
       Time is  3:00:00PM
   And $iEvery.Other.Day.Counter is 0
       Set 'EzFlora - 6 Greenhouse' On
       Wait  15 minutes
       Set 'EzFlora - 6 Greenhouse' Off
       Send Notification to 'Alan_Only.email' content 'Irrigation Cycle'
Greenhouse should be Valve 5, run for 15 minutes every other day
I get a notification every day instead of every other day. There is no reason the Then should run every day. I get the Notification at 3:00 if it does not run, and 3:15 if it does.
Alan
There is some other Program that is producing the 3 PM Notify or perhaps this Program Else clause from a variant that has not been overlaid with a Save of the posted version.
I agree. This program cannot, in my mind, produce a notification at 3pm, as written, regardless of which day it is.
Another program notification? Another program calling this one then path at 2:45?
It sounds like ievery.other.day.counter is working correctly since it sounds like it is only irrigating every other day. You might just check to be certain that indeed the variable is alternating 0/1 at midnight every day.
Check your program summary page for any programs that run or are running at 3:00 and 3:15. This should narrow done the potential culprit.
