Control on Outside Inside Temperature Difference
I would like to turn a whole house fan on when the temperature outside is lower by 5 degrees than inside. So if the outside is 75 degrees and inside is 80 I want the fan to turn on. But I also want the fan to turn on if outside is 87 and inside is 92 (for example) so I really need to control the fan on the difference of the temperatures. Also, I want to turn the fan off if the temperature outside and inside is within 2 degrees.
Is there anyway to calculate a temperature difference and turn things on or off? I'm new at this. Are variables something that could be used?
Unfortunately you cannot yet assign status values to variables. This is something we are working on for our 5.x version.
Great to hear! I'll refrain from asking how long, I know better. :) Is this likely to include arithmetic on variables?
By arithmetic you mean more than
Assign        $x  = a
Add           $x += a
Subtract      $x -= a
Multiply      $x *= a
Divide        $x /= a
Remainder     $x %= a
And (binary)  $x &= a
Or (binary)   $x |= a
Xor (binary)  $x ^= a
store the result of :
x-y in z
x+y in z
Program conditions,
If x-y > z then...
Etc etc..
Especially where one or more operators came from module output from modules like weatherbug or irrigation - or even the current light level of a dimmer, light level etc etc.
