I just changed over my PC to a MAC But I can not get the ISY99I to work on the MAC.
I also use a Remotelinc And it still works.
Is there a program that I can control items on the ISY99I?
Is there a Mac program that will work
Thanks for the help
Dodger
Hi Dodger-
I can assure you that the ISY works just fine with the MAC. I use all MAC's at work and home and access the ISY all the time with them.
What exactly seems to be the problem? What version of MAC OS are you using? Do you have Java 7 installed? What version of the ISY firmware do you have running on your ISY?
I'm sure we can get you up and running once we know what the problem is.
If you have not had a chance yet.
You may want to see what is in the MAC Section of the forums.
viewforum.php?f=19
What exactly seems to be the problem? When I start the program I get to the place were you ad the user name and password but the blue screen is blue
What version of MAC OS are you using? OSX Verision 10.8.3
Do you have Java 7 installed? were do I find that information
What version of the ISY firmware do you have running on your ISY?were is that
-Dodger
Hi Dodger,
Does this mean that you are not getting prompted for userid/password?
If so, would you please reboot ISY, observe the pattern of LEDs on the front of the unit and let me know what the pattern is? i.e. do you see any of the lights continuously blinking especially error/mem or both?
Correct just a blue screen
If so, would you please reboot ISY, observe the pattern of LEDs on the front of the unit and let me know what the pattern is? i.e. do you see any of the lights continuously blinking especially error/mem or both?Power on
RX TX M blink then stay on for w few seconds then off
Power on.
Dodger
Michel,
I do not understand what you want me to do. Not good on this type of stuff.
Dodger
Hi Dodger,
Please do be kind enough to submit a ticket (links below) and we'll schedule a remote session to walk you through it. The main issue is that your MAC is blocking UDP packets and thus we do not know where ISY is. In case you find ISY's IP address, then everything will be easier.
Are you using your browser in Full Screen? I get the same problem in Full Screen. Try using safari in a normal window.
