Java errors when attempting to load admin console on OS X
Trying to get the Java Admin console to load on my OS X 10.8.4 box, and running into this:
ISY994 Administrative Console quit unexpectedly while using the libjvm.dylib plug-in.
This is the Java version my web plugin is using:
$ /Library/Internet\ Plug-ins/JavaAppletPlugin.plugin/Contents/Home/bin/java -version
java version "1.7.0_25"
Java(TM) SE Runtime Environment (build 1.7.0_25-b15)
Java HotSpot(TM) 64-Bit Server VM (build 23.25-b01, mixed mode)
Any thoughts? This seems to work fine on another OS X box with the same version of OSX and JRE...
  • 1 year later...
I'm running into this as well.  I literally just the other day ran the admin console (because my PowerLinc died) and now I'm replacing it and I get this error.  I've got the 1.7.0_60 version of Java.  Anybody know how to go back to 1.6?
Hello pmarcos,
Please do make sure that:
1. You have cleared all your Java cache
2. You use http://isy.universal-devices.com/994i/4.2.5/admin.jnlp to get to ISY
3. Upgrade to 4.2.5
If you are still having problems, please do not hesitate to contact our tech support (links below).
