Locked Up ISY/PLM
This morning I noticed that programs were not working & the iSY was locked up. I unplugged the ISY and plugged it back in & the ISY was still locked up. I then noticed that the LED on the PLM was solid orange which I thought was unusual. So I unplugged both, the ISY & the PLM & that fixed it.
Any ideas why this would happen & what a solid orange LED on the PLM means?
Sent from my SPH-D710 using Tapatalk 2
See the logs below. Note, that the last time I successfully controlled a device before I noticed that it was locked up was at 4:24 AM on 7/28. I restarted the ISY & PLM at 12:14 PM.
Also I see quite some errors in the error log. I am including a little more than what you requested so you can perhaps tell me what's going on overall as some error codes are not mentioned in the wiki.
I am currently on a ISY-99 & still on version 3.2.6. I actually bought an ISY-994 but didn't get around to do the upgrade yet.
Thank you
Log:
FanLinc-Light-14.F5.A8 Status 30% Sun 2013/07/28 04:17:20 AM System Log
MBR Bedside 19.23.38.1.1 Status 100% Sun 2013/07/28 04:17:20 AM System Log
MBR Door 1A.1D.2F.1.1 Status 100% Sun 2013/07/28 04:17:20 AM System Log
M. Bed Light 19.34.19.1.D Status 100% Sun 2013/07/28 04:17:20 AM System Log
FanLinc-Light-14.F5.A8 Status 0% Sun 2013/07/28 04:24:27 AM System Log
MBR Bedside 19.23.38.1.1 Status 0% Sun 2013/07/28 04:24:27 AM System Log
MBR Door 1A.1D.2F.1.1 Status 0% Sun 2013/07/28 04:24:27 AM System Log
M. Bed Light 19.34.19.1.D Status 0% Sun 2013/07/28 04:24:27 AM System Log
A. Bed Light 19.31.52.1.B Status 100% Sun 2013/07/28 04:24:28 AM System Log
A. Bed Light 19.31.52.1.1 Beep 5 Sun 2013/07/28 04:24:28 AM Program Log
A. Bed Light 19.31.52.1.D Status 0% Sun 2013/07/28 04:24:30 AM System Log
MBR AC On 255 Sun 2013/07/28 04:24:30 AM Program Log
MBR AC Status 100% Sun 2013/07/28 04:24:31 AM System Log
14.67.0A - Cool Control Status On Sun 2013/07/28 04:52:40 AM System Log
14.67.0A - Main Heat/Cool State Cool On Sun 2013/07/28 04:52:40 AM System Log
14.67.0A - Main Status 72â–‘ Sun 2013/07/28 04:53:22 AM System Log
14.67.0A - Cool Control Status Off Sun 2013/07/28 05:03:23 AM System Log
14.67.0A - Main Heat/Cool State Off Sun 2013/07/28 05:03:23 AM System Log
0 null Sun 2013/07/28 12:14:42 PM System Start
Scene:My Lighting Status Query Sun 2013/07/28 12:14:48 PM System Log
Error Log:
Sat 2013/07/27 03:58:17 AM System -170001 [Auth] 199.68.230.204:57127->80, Num=3
Sat 2013/07/27 09:06:29 AM System -100 No network connection
Sat 2013/07/27 09:06:34 AM System -170001 [Network] Established
Sat 2013/07/27 03:26:07 PM System -170001 [Auth] 37.46.193.104:40646->80, Num=4
Sat 2013/07/27 08:28:16 PM System -170001 [Auth] 178.255.87.241:45685->80, Num=5
Sun 2013/07/28 06:51:47 AM System -5 Start
Sun 2013/07/28 06:52:07 AM System -170001 [Network] Established
Sun 2013/07/28 06:52:10 AM System -60001 pool.ntp.org
Sun 2013/07/28 09:01:20 AM System -100 No network connection
Sun 2013/07/28 12:11:20 PM System -5 Start
Sun 2013/07/28 12:11:40 PM System -170001 [Network] Established
Sun 2013/07/28 12:13:45 PM System -170001 [uDSockets] RSub:39 error:6
Sun 2013/07/28 12:13:50 PM System -170001 [uDSockets] RSub:39 error:6
Sun 2013/07/28 12:14:42 PM System -5 Start
Sun 2013/07/28 12:14:48 PM System -170001 [Network] Established
Sun 2013/07/28 12:15:50 PM System -5012 26
Sun 2013/07/28 12:15:51 PM System -5006 uuid:26
Sun 2013/07/28 12:16:08 PM System -5006 uuid:26
Sun 2013/07/28 12:16:11 PM System -5006 uuid:26
Sun 2013/07/28 12:16:14 PM System -5006 uuid:26
Sun 2013/07/28 02:37:58 PM System -170001 [uDSockets] RSub:39 error:6
Sun 2013/07/28 02:38:00 PM System -5012 27
Sun 2013/07/28 02:38:07 PM System -5006 uuid:27
Sun 2013/07/28 02:38:14 PM System -5006 uuid:27
Sun 2013/07/28 05:31:53 PM System -5012 28
Sun 2013/07/28 05:31:55 PM System -5006 uuid:28
Sun 2013/07/28 05:31:57 PM System -5006 uuid:28
Sun 2013/07/28 06:45:36 PM System -170001 [uDSockets] RSub:41 error:6
Sun 2013/07/28 06:45:41 PM System -5012 29
Sun 2013/07/28 06:45:42 PM System -5006 uuid:29
Sun 2013/07/28 06:45:48 PM System -5006 uuid:29
Sun 2013/07/28 06:55:54 PM System -5012 30
Sun 2013/07/28 06:55:58 PM System -5006 uuid:30
Sun 2013/07/28 06:56:02 PM System -5006 uuid:30
Sun 2013/07/28 07:48:17 PM System -170001 [uDSockets] RSub:39 error:6
Sun 2013/07/28 07:54:37 PM System -170001 [uDSockets] RSub:39 error:6
Sun 2013/07/28 07:54:42 PM System -170001 [uDSockets] RSub:39 error:6
Sun 2013/07/28 07:54:47 PM System -5012 32
Sun 2013/07/28 07:55:27 PM System -5006 uuid:32
Sun 2013/07/28 07:55:38 PM System -5006 uuid:32
Sun 2013/07/28 07:55:46 PM System -5012 33
Sun 2013/07/28 07:55:56 PM System -5006 uuid:33
Sun 2013/07/28 07:56:07 PM System -5006 uuid:33
Mon 2013/07/29 07:07:38 AM System -170001 [Auth] 93.174.93.213:60807->80, Num=3
Mon 2013/07/29 07:07:39 AM System -170001 [Auth] 93.174.93.213:60821->80, Num=4
Mon 2013/07/29 07:07:39 AM System -170001 [Auth] 93.174.93.213:60852->80, Num=5
Mon 2013/07/29 07:07:39 AM System -170001 [Auth] 93.174.93.213:60869->80, Num=6
Mon 2013/07/29 07:07:39 AM System -10108 Check log
Mon 2013/07/29 07:07:39 AM System -170001 [Auth] 93.174.93.213:60884->80, Num=7
Mon 2013/07/29 09:01:45 AM System -100 No network connection
Mon 2013/07/29 09:01:50 AM System -170001 [Network] Established
I am using the port forwarding settings in my router & not the "enable internet access" option, if that makes a difference. I will upgrade to 3.3.10 as soon as I get a chance & see if that helps.
While it's on my todo list to switch to the ISY-994 for my home, I was still planning to use the ISY-99 for my office.
Hi hbsh01,
File | Enable Internet Access does not have any bearings on this issue UNLESS you have recently changed your router.
You can certainly use 99 in the office since most of these issues are related to UPnP media server/streaming.
I don't know much about UPNP, but I don't have any media server/streaming devices at home.
