Programming a simple light timer program?
Hi,
I have a new LED bulb & I was thinknig it would be nice to have it come on each night at 515pm & shut off at 1115pm.
This is what I have so far:
Program1:
       Time is  5:15:00PM
       Set 'Main: Living Room LED Bulb' On
Program2:
       Time is 11:15:00PM
       Set 'Main: Living Room LED Bulb' Off
Rich
Thanks, the single program seems cleaner!
It probably is a bit cleaner, if this meets your needs.
My only observation is that there are times when separating the two programs make sense. Keep this in mind as your needs and desires evolve.
This does become the case with multiple conditions besides on at one time off at another time.
For example, if you want it to turn on at one time only if the status of another light is off.
If from 8pm to 10pm same day
and status light x is off
set light y on
set light y off
The above program will run every time someone changes the status of light x. The result will by that light y turns off every time light x changes and the time is not 8 to 10. Also, if someone turns light x on between 8 to 10, light y will turn off.
