Network Module Rules
Where are the Network Module Rules defined.
I am getting a Net Module Rule 2:715 when I execute a Network Resource Post command.
Where can I find these messages defined?
Charles Seiler
Hello,
There must be some DOC on how to setup and use the Network Resources to POST a REST command from one ISY to another? No matter what I do I cannot seem to get it to work, and I still cannot find the Error Messages Documented anywhere.
Is this a Security Issue? I have a Self Signed Server CA for Both ISY's. Is there additional Windows or Router Setup needed? Both ISY's are on the same local Router both using PORT 80.
I am trying to set up a Network Resource to POST from ISY#1 to ISY#2 a /REST/X10/C12/3 command.
POST / HTTP/1.1
Host: 192.168.1.245:80
User-Agent: Mozilla/4.0
Connection: Close
Content-Type: application/x-www-form-urlencoded
Content-Length: 15
Authorization: Basic XXXXXXXXXXXXXXXXXXXXXX==
/rest/X10/C12/3
When I Test this I get a TCP client request Failed (Net Module Rule 1:715) I tried with and without Basic Authorization in the request. (XX'd Out the BASE64 in the above.)
I would not think this would be all that complicated. I am already using REST commands to send REST commands from Camera Devices to the ISY and that works great. I would think I should be able to send a REST command from one ISY to another just as easily?
Any Ideas what this error is, and what I need to do to get this working? Is this a Security Error or is something else wrong? Is this a SSL CA Certificate Issue and if so what do I need to fix this? This is critical to my continued use of ISY.
Charles Seiler
Hi Charles,
Unfortunately not. Network resources assumes that you already know about basic HTTP/TCP communications (unfortunately).
Not as long as you follow Basic64 encoding.
POST / HTTP/1.1
Connection: Close
Content-Length: 15
/rest/X10/C12/3
The problem is that that the POST to ISY does not have a body. So, you should put /rest/X10/C12/3 in the Path and NOT the Body.
Thanks Michel for all the help with Network Resources Rest Interface. I seem to have it working now as far as using Network Resources to set values of Variables on the second ISY, and also issuing DON/DOF/Beep etc. directly to devices and Scenes on the second ISY so that's progress, and I am learning which is always a great thing.
Just a couple of additional questions if I may?
Q#1 Is it possible to have ISY#1 send a rest/vars/set Command to set a variable on ISY#2 to the value of another variable on ISY#2? If so how would this be coded?
Q#2 Similarly is it possible to have ISY#1 send a rest/vars/set command to set a variable on ISY#2 to the value of a variable on ISY#1? Thus far I do this by encoding the variables value in the rest command as a literal value but I wasn't sure how to code it to use a variable name from the ISY#1 in the command being sent to ISY#2.
Q#3 Could you also provide an example of how to code the rest/vars/set command to set the value to a string Value?
Thanks Again for your help. You saved me as an ISY User and allowed me to move forward with several projects I am in the midst of.
Charles Seiler
It has been mentioned in the past that an upcoming update may allow the use of variables within network resources. I'm hopeful that we will see this in the next release. If so, then the answers to Q1 & 2 will be yes. For the moment however, we cannot do that.
  • 1 year later...
Can you tell me why I am getting this error
TCP Client DNS error
api.aerisapi.com
TCP client Request Failed
{Net Module Rule:42:500}
My request looks iike this
POST /sony/IRCC HTTP/1.1
Host: 192.168.1.24:80
User-Agent: TVSideView/2.0.1 CFNetwork/672.0.8 Darwin/14.0.0'
Connection: keep-alive
Content-Type: text/xml; charset=UTF-8
SOAPACTION: urn:schemas-sony-com:service:IRCC:1#X_SendIRCC
Content-Length: 316
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Encoding: gzip, deflate
<?xml version="1.0"?>
  <s:Body>
    <u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1">
      <IRCCCode>AAAAAQAAAAEAAAAvAw==</IRCCCode>
    </u:X_SendIRCC>
  </s:Body>
</s:Envelope>
The turns off the TV, a Sony Bravia KDL 48w600B
Thanx
Mike
Hi Pazium,
{Net Module Rule:42:500} => you are getting a status code of 500 which means internal server error. So, it does not like something in the payload.
My suggestions in order of priority:
1. The contents of SOAPACTION must be in quotes ... i.e. "urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"
2. Remove user-agent or use the default
3. Remove accept-encoding
4. Remove accept
5. Change connection to close
i have hamweather installed
thanx, in will try each.
the contents works great with my kdl 32w650a. it has the nginx server
i dont know if the kdl 48w600b has the same. i understand it runs debian linux.
i'll let you know how it works out
Thanx Michel for your help.
None of those worked. I still get the same error with of the suggestions The 42:500 error
Well it looks like this now:
Host: 192.168.1.18:80
SOAPACTION: "urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"
Content-Length: 316
Content-Type: "text/xml; charset=UTF-8"
  <s:Body>
    </u:X_SendIRCC>
  </s:Body>
</s:Envelope>
it is based on this link
Which has this python code:
headers = { 'User-Agent': 'TVSideView/2.0.1 CFNetwork/672.0.8 Darwin/14.0.0', 'Content-Type': 'text/xml; charset=UTF-8', 'SOAPACTION': '"urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"', 'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8', 'Accept-Encoding': 'gzip, deflate', 'Connection': 'keep-alive', } content = """<?xml version="1.0"?> <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"> <s:Body> <u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1"> <IRCCCode>AAAAAQAAAAEAAAAvAw==</IRCCCode> </u:X_SendIRCC> </s:Body> </s:Envelope>""" url = 'http://this-is-the-ip-of-the-tv/sony/IRCC' response = requests.post(url, data=content, headers=headers) print(response)
Like I said I know it works for the other Bravia
Thank you very much.
i did have the quotes off at one point. I'll take them off and get back to you.
The IRCCode comes form the xml as this
<av:X_IRCCCode command="Power OFF">AAAAAQAAAAEAAAAvAw==</av:X_IRCCCode>
I copied the content using the copy command from the line that works for the other Bravia.
Both Bravias use nginx web servers
i used Magpe on the bravia and got all of this:
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
<friendlyName>BRAVIA KDL-48W600B</friendlyName>
<manufacturer>Sony Corporation</manufacturer>
<modelName>KDL-48W600B</modelName>
<modelNumber>MINT1.7.0.1</modelNumber>
<UDN>uuid:00000000-0000-1010-8000-fcf152f5f8dd</UDN>
<dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC>
<microsoft:magicPacketWakeSupported xmlns:microsoft="urn:schemas-microsoft-com:WMPNSS-1-0">1</microsoft:magicPacketWakeSupported>
<iconList>
<icon>
<mimetype>image/png</mimetype>
<width>32</width>
<height>32</height>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_32x32.png</url>
</icon>
<icon>
<width>48</width>
<height>48</height>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_48x48.png</url>
</icon>
<icon>
<width>60</width>
<height>60</height>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_60x60.png</url>
</icon>
<icon>
<width>120</width>
<height>120</height>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_120x120.png</url>
</icon>
<icon>
<mimetype>image/jpeg</mimetype>
<width>32</width>
<height>32</height>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_32x32.jpg</url>
</icon>
<icon>
<width>48</width>
<height>48</height>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_48x48.jpg</url>
</icon>
<icon>
<width>60</width>
<height>60</height>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_60x60.jpg</url>
</icon>
<icon>
<width>120</width>
<depth>24</depth>
<url>/MediaRenderer_HM_ME_120x120.jpg</url>
</icon>
</iconList>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
<SCPDURL>/RenderingControlSCPD.xml</SCPDURL>
<controlURL>/upnp/control/RenderingControl</controlURL>
<eventSubURL>/upnp/event/RenderingControl</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<SCPDURL>/ConnectionManagerSCPD.xml</SCPDURL>
<controlURL>/upnp/control/ConnectionManager</controlURL>
<eventSubURL>/upnp/event/ConnectionManager</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
<serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
<SCPDURL>/AVTransportSCPD.xml</SCPDURL>
<controlURL>/upnp/control/AVTransport</controlURL>
<eventSubURL>/upnp/event/AVTransport</eventSubURL>
</service>
<service>
<serviceType>urn:dial-multiscreen-org:service:dial:1</serviceType>
<serviceId>urn:dial-multiscreen-org:serviceId:dial</serviceId>
<SCPDURL>/DIALSCPD.xml</SCPDURL>
<controlURL>/upnp/control/DIAL</controlURL>
<eventSubURL />
</service>
<service>
<serviceType>urn:schemas-sony-com:service:IRCC:1</serviceType>
<serviceId>urn:schemas-sony-com:serviceId:IRCC</serviceId>
<SCPDURL>/IRCCSCPD.xml</SCPDURL>
<eventSubURL />
</service>
<service>
<serviceType>urn:schemas-sony-com:service:ScalarWebAPI:1</serviceType>
<serviceId>urn:schemas-sony-com:serviceId:ScalarWebAPI</serviceId>
<SCPDURL>/ScalarWebApiSCPD.xml</SCPDURL>
<controlURL>/upnp/control/ScalarAPI</controlURL>
<eventSubURL />
</service>
</serviceList>
<av:X_MaxBGMCount xmlns:av="urn:schemas-sony-com:av">64</av:X_MaxBGMCount>
<av:X_StandardDMR xmlns:av="urn:schemas-sony-com:av">1.1</av:X_StandardDMR>
<av:X_ScreenResolution xmlns:av="urn:schemas-sony-com:av">2K</av:X_ScreenResolution>
<av:X_IRCCCodeList xmlns:av="urn:schemas-sony-com:av">
<av:X_IRCCCode command="Power">AAAAAQAAAAEAAAAVAw==</av:X_IRCCCode>
<av:X_IRCCCode command="Power ON">AAAAAQAAAAEAAAAuAw==</av:X_IRCCCode>
</av:X_IRCCCodeList>
<pnpx:X_compatibleId>MS_DigitalMediaDeviceClass_DMR_V001</pnpx:X_compatibleId>
<pnpx:X_deviceCategory>MediaDevices</pnpx:X_deviceCategory>
<pnpx:X_hardwareId>VEN_0106&DEV_0007&REV_01</pnpx:X_hardwareId>
<df:X_deviceCategory>Display.TV Multimedia.DMR</df:X_deviceCategory>
<av:X_TrackID_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
</av:X_TrackID_DeviceInfo>
<av:X_DIALEX_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
<av:X_DIALEX_DeviceID>B0:00:03:52:77:34</av:X_DIALEX_DeviceID>
<av:X_DIALEX_DeviceType>CoreTV_DIAL</av:X_DIALEX_DeviceType>
</av:X_DIALEX_DeviceInfo>
<av:X_ScalarWebAPI_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
<av:X_ScalarWebAPI_Version>1.0</av:X_ScalarWebAPI_Version>
<av:X_ScalarWebAPI_ServiceList>
<av:X_ScalarWebAPI_ServiceType>guide</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>system</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>videoScreen</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>audio</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>avContent</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>appControl</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>browser</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>notification</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>cec</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>accessControl</av:X_ScalarWebAPI_ServiceType>
<av:X_ScalarWebAPI_ServiceType>encryption</av:X_ScalarWebAPI_ServiceType>
</av:X_ScalarWebAPI_ServiceList>
</av:X_ScalarWebAPI_DeviceInfo>
<av:X_RDIS_DeviceInfo xmlns:av="urn:schemas-sony-com:av">
<av:X_RDIS_Version>1.0</av:X_RDIS_Version>
<av:X_RDIS_SESSION_CONTROL>false</av:X_RDIS_SESSION_CONTROL>
<av:X_RDIS_ENTRY_PORT>20677</av:X_RDIS_ENTRY_PORT>
</av:X_RDIS_DeviceInfo>
</device>
</root>
&ssdp=HTTP/1.1 200 OK
CACHE-CONTROL: max-age=1800
EXT:
SERVER: Linux/2.6 UPnP/1.0 KDL-48W600B/1.7
ST: upnp:rootdevice
USN: uuid:00000000-0000-1010-8000-fcf152f5f8dd::upnp:rootdevice
X-AV-Physical-Unit-Info: pa="BRAVIA KDL-48W600B";
X-AV-Server-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-48W600B"; mv="1.7";
The other BRAVIA return this to Magpie
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<device>
<friendlyName>BRvKDL32W650A bdrm</friendlyName>
<modelName>KDL-32W650A</modelName>
<UDN>uuid:00000000-0000-1010-8000-d8d43c8fe38f</UDN>
<iconList>
<icon>
<width>32</width>
<height>32</height>
<depth>24</depth>
<url>/MediaRenderer_LW_32x32.png</url>
</icon>
<icon>
<width>48</width>
<height>48</height>
<depth>24</depth>
<url>/MediaRenderer_LW_48x48.png</url>
</icon>
<icon>
<width>60</width>
<height>60</height>
<depth>24</depth>
<url>/MediaRenderer_LW_60x60.png</url>
</icon>
<icon>
<width>120</width>
<depth>24</depth>
<url>/MediaRenderer_LW_120x120.png</url>
</icon>
<icon>
<width>32</width>
<height>32</height>
<depth>24</depth>
<url>/MediaRenderer_LW_32x32.jpg</url>
</icon>
<icon>
<width>48</width>
<height>48</height>
<depth>24</depth>
<url>/MediaRenderer_LW_48x48.jpg</url>
</icon>
<icon>
<width>60</width>
<height>60</height>
<depth>24</depth>
<url>/MediaRenderer_LW_60x60.jpg</url>
</icon>
<icon>
<width>120</width>
<depth>24</depth>
<url>/MediaRenderer_LW_120x120.jpg</url>
</icon>
</iconList>
<serviceList>
<service>
</service>
<service>
</service>
<service>
</service>
<service>
<eventSubURL />
</service>
<service>
<eventSubURL />
</service>
<service>
<eventSubURL />
</service>
</serviceList>
<pnpx:X_hardwareId>VEN_0106&DEV_0006&REV_01</pnpx:X_hardwareId>
<av:X_ScalarWebAPI_ServiceType>irCommandProxy</av:X_ScalarWebAPI_ServiceType>
</device>
</root>
&ssdp=NOTIFY * HTTP/1.1
HOST: 239.255.255.250:1900
NT: upnp:rootdevice
NTS: ssdp:alive
SERVER: Linux/2.6 UPnP/1.0 KDL-32W650A/1.7
USN: uuid:00000000-0000-1010-8000-d8d43c8fe38f::upnp:rootdevice
X-AV-Physical-Unit-Info: pa="BRAVIA KDL-32W650A";
X-AV-Server-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-32W650A"; mv="1.7";
I don't see any meaningful differences, do you?
ok
I used CHROME POSTMAN
put in the headers and the content andsent it
got this response, a 606 error
<s:Envelope
    <s:Body>
        <s:Fault>
            <faultcode>s:Client</faultcode>
            <faultstring>UPnPError</faultstring>
            <detail>
                <UPnPError
                    xmlns="urn:schemas-upnp-org:control-1-0">
                    <errorCode>606</errorCode>
                    <errorDescription>Action not authorized</errorDescription>
                </UPnPError>
            </detail>
        </s:Fault>
    </s:Body>
</s:Envelope>
No. but I read about this header thing in a couple of places
X-CERS-DEVICE-ID
How do I add this to the list of headers in ISY?
did this and still got the 500 error in isy
POST /sony/IRCC/ HTTP/1.1
Host: 192.168.1.16:80
Content-Length: 316
X-CERS-DEVICE-INFO: Pazz Remote
X-CERS-DEVICE-ID: 11-38-11-38-11-38
  <s:Body>
    </u:X_SendIRCC>
  </s:Body>
</s:Envelope>
