questions on toggling events
I am executing toggle events via voice and would like a check on the way I am doing it.
I am using three programs to control the toggling. It is working reliably .
Is my use of disables and waits sensible? I can't remember how I got to this point and I am wondering if there is a better way.
MASTER PROGRAM - the only one that I call directly (typically from SIRI -> ProxyServer -> Ruby -> ISY99)
Status 'Fire-Relay' is Off
Run Program 'fireOn' (Then Path)
Run Program 'fireOff' (Then Path)
TURNS IT ON
Disable Program 'fire'
Set 'Fire-Relay' On
Wait 5 seconds
Enable Program 'fire'
TURNS IT OFF
Set 'Fire-Relay' Off
Wait 5 seconds
Since your triggering the master program manually, you might as well just leave it disabled. No need to disable/re-enable.
How about this instead:
MASTER PROGRAM (DISABLED ALWAYS) - the only one that I call directly (typically from SIRI -> ProxyServer -> Ruby -> ISY99)
Run Program 'fireOn' (Else Path)
TURNS IT ON/OFF (ALWAYS DISABLED)
Set 'Fire-Relay' On
-Xathros
Thank you. Much cleaner!!! Converting everything over. Not sure why I was doing that.
Its way faster to program this way.
Rihc S.
Actually, now that I look at it again, you only need the master program:
FireToggle (ALWAYS DISABLED)
Set 'Fire-Relay' On (Then Path)
Set 'Fire-Relay' On (Else Path)
-Xathros
Set 'Fire-Relay' On
-Xathros
While it is fine to disable the second program, it isn't necessary. A disabled program blocks the "if" section from self triggering. When the "if" is empty, it can't self trigger anyway.
But I do agree, it is better to merge the programs into 1 anyway.
